Hi All,
I need some thoughts on the problems I'm facing the last couple of days.
I think my power supply is defect (doesn't supply enough current), or worse, my wl500g premium is bricked.
The symptoms:
All LAN leds and AIR leds are continiously on. they don't blink, even though not a single cable is connected. the power-led is off.
When I take the power off, wait 15 secs, and put the power back on, the same symptoms occur. But. sometimes it 'boots', I stick a lan-cable in it and try to ping it, sometimes this works, but most of the time it doesn't.
Then, a couple of weeks ago, my harddrive (currently a 2,5' notebook) started having issues. The drive runs of the asus without an extra power supply. But now, all of a sudden the drive doesn't run off the asus anymore, I had to stick an extra powersupply to the drive in order to run it.
Then, a week or so later, the asus didn't recognize my Velleman K8055 usb-interface board anymore, it doesn't detect it when it's plugged in.
And now, it's just sitting there, staring at me with all those orange lights, but it doesn't work.
I checked the power supply with a multimeter and it supplies 5.24v
I guess this is correct, but could it be that it is not supplying enough current anymore so that the Asus can't boot up?
Would you think it's safe to test this with the 5v supply rail from a (running) pc. As I don't have a spare power-supply which can provide 5v@2,5a
Any thoughts on this are welcome.
TIA
