For those with defective asus router power suplyes, there is a sollution.
Often the capacitors are poorly made and they will start to leak electrolyte until they get defective.
To change the defective capacitors open the defective power supply and change the bad capacitors, put the same µ F (micro farads) capacitors but higher voltage, for example if you have a capacitor that is rated at 1500 µ F and 10 V change with a 1500 µ F and 25 V capacitor, also there is a good ideea to drill holes in the top case of the power suply to help it cool down if you use your router 24/7, 365 days a year.
This Information is provided as is withowt any Implyed warranty, use at your own risk, I'm not responsable if you dammage your PSU, this information is provided in the hope that it will help somebody.
Best regards,
Renegate
