Page 3 of 3 FirstFirst 123
Results 31 to 45 of 242
Thread: Firmware v1.9.2.7 CR6, updated to CR6a ... now CR6b [Oleg]
    Sep 2005
    Slovakia
    cpu probe
    prom init
    cpu report
    CPU revision is: 00024000
    Loading BCM4710 MMU routines.
    Primary instruction cache 8kb, linesize 16 bytes (2 ways)
    Primary data cache 4kb, linesize 16 bytes (2 ways)
    Linux version 2.4.20 (root@omnibook) (gcc version 3.2.3 with Broadcom modifications) #9 Thu May 26 23:29:45 MSD 2005
    Setting the PFC value as 0x15
    Determined physical RAM map:
    memory: 01000000 @ 00000000 (usable)
    On node 0 totalpages: 4096
    zone(0): 4096 pages.
    zone(1): 0 pages.
    zone(2): 0 pages.
    Kernel command line: root=/dev/mtdblock2 noinitrd init=/linuxrc console=ttyS0,115200
    CPU: BCM4710 rev 0 at 125 MHz
    !unable to setup serial console!
    Calibrating delay loop... 82.94 BogoMIPS
    Memory: 13868k/16384k available (1767k kernel code, 2516k reserved, 248k data, 72k init, 0k highmem)
    Dentry cache hash table entries: 2048 (order: 2, 16384 bytes)
    Inode cache hash table entries: 1024 (order: 1, 8192 bytes)
    Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
    Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
    Checking for 'wait' instruction... unavailable.
    POSIX conformance testing by UNIFIX
    PCI: Fixing up bus 0
    PCI: Fixing up bridge
    PCI: Fixing up bus 1
    Linux NET4.0 for Linux 2.4
    Based upon Swansea University Computer Society NET3.039
    Initializing RT netlink socket
    Starting kswapd
    Journalled Block Device driver loaded
    devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
    devfs: boot_options: 0x1
    NTFS driver v1.1.22 [Flags: R/O]
    pty: 256 Unix98 ptys configured
    Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
    loop: loaded (max 8 devices)
    PPP generic driver version 2.4.2
    PPP Deflate Compression module registered
    PPP BSD Compression module registered
    MPPE/MPPC encryption/compression module registered
    Amd/Fujitsu Extended Query Table v1.1 at 0x0040
    Physically mapped flash: Swapping erase regions for broken CFI table.
    number of CFI chips: 1
    Flash device: 0x400000 at 0x1fc00000
    Physically mapped flash: squashfs filesystem found at block 942
    Creating 5 MTD partitions on "Physically mapped flash":
    0x00000000-0x00040000 : "pmon"
    0x00040000-0x003e0000 : "linux"
    0x000eba00-0x003e0000 : "rootfs"
    0x003f0000-0x00400000 : "nvram"
    0x003e0000-0x003f0000 : "config"
    sflash: chipcommon not found
    NET4: Linux TCP/IP 1.0 for NET4.0
    IP Protocols: ICMP, UDP, TCP
    IP: routing cache hash table of 512 buckets, 4Kbytes
    TCP: Hash tables configured (established 1024 bind 2048)
    ip_conntrack version 2.1 (128 buckets, 1024 max) - 344 bytes per conntrack
    ip_conntrack_pptp version 1.9 loaded
    ip_nat_pptp version 1.5 loaded
    ip_tables: (C) 2000-2002 Netfilter core team
    ipt_time loading
    NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
    IPv6 v0.8 for NET4.0
    IPv6 over IPv4 tunneling driver
    NET4: Ethernet Bridge 008 for NET4.0
    802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
    All bugs added by David S. Miller <davem@redhat.com>
    FAT: bogus logical sector size 13056
    NTFS: Unable to set blocksize 512.
    VFS: Mounted root (squashfs filesystem) readonly.
    Mounted devfs on /dev
    Freeing unused kernel memory: 72k freed
    Warning: unable to open an initial console.
    Algorithmics/MIPS FPU Emulator v1.5
    eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.90.7.0
    eth1: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.90.7.0
    PCI: Enabling device 01:02.0 (0004 -> 0006)
    eth2: Broadcom BCM4301 802.11 Wireless Controller 3.90.23.0
    device eth1 entered promiscuous mode
    device eth0 entered promiscuous mode
    br0: port 2(eth0) entering listening state
    br0: port 1(eth1) entering listening state
    br0: port 2(eth0) entering learning state
    br0: port 1(eth1) entering learning state
    br0: port 2(eth0) entering forwarding state
    br0: topology change detected, propagating
    br0: port 1(eth1) entering forwarding state
    usb.c: registered new driver usbdevfs
    usb.c: registered new driver hub
    usb-ohci.c: USB OHCI at membase 0xb8004000, IRQ 2
    usb-ohci.c: usb-00:04.0, PCI device 14e4:4715
    usb.c: new USB bus registered, assigned bus number 1
    hub.c: USB hub found
    hub.c: 2 ports detected
    hub.c: new USB device 00:04.0-1, assigned address 2
    usb.c: USB device 2 (vend/prod 0x4e8/0x100) is not claimed by any active driver.
    lp0: using parport0 (polling).
    usb.c: registered new driver usblp
    printer.c: v0.13: USB Printer Device Class driver
    usb.c: registered new driver audio
    audio.c: v1.0.0:USB Audio Class driver
    Linux video capture interface: v1.00
    SCSI subsystem driver Revision: 1.00
    Initializing USB Mass Storage driver...
    usb.c: registered new driver usb-storage
    scsi0 : SCSI emulation for USB Mass Storage devices
    usb.c: USB disconnect on device 00:04.0-1 address 2
    eth1: no IPv6 routers present
    eth0: no IPv6 routers present
    br0: no IPv6 routers present
    hub.c: Cannot enable port 1 of hub 1, disabling port.
    hub.c: Maybe the USB cable is bad?
    usb_control/bulk_msg: timeout
    usb-ohci.c: unlink URB timeout
    Hi, it looks like you got some problems with your USB-Stick.
    Like you can see at the end of you Kernel Messgaes, the driver has problems to recognize your stick.
    Did you tried it at another Linux System ??
    Do there the same and post the dmesg output. May be the Kernel-Developers changed something (and they possibly did) in the younger Kernel Versions.
    Greetings from Berlin
    Andy
    Quote Originally Posted by yeager
    cpu probe
    prom init
    cpu report
    zone(1): 0 pages.
    zone(2): 0 pages.
    Starting kswapd
    ipt_time loading
    Greetings from 1XXXX (Berlin/Germany)
    Mar 2004
    Europe
    Question HFS+ support?
    hey,
    is there a chance that a HFS+ formatted hdd is supported by upcoming oleg's firmwares ... i've read somewhere in the forum that it's currently not supported and that hdds shall be formatted with ext3 or fat32, but as far as i know the kernel 2.4.x supports HFS+ ....is there a reason why it's not implemented?
    or can I add HFS+ support by myself? if yes, how?
    cheers, thomas.
    ps: searching the forum with =< 3 chars (like hfs, mac, osx etc.) gives a zero search result in the forum.... so maybe there is already an answer, but i was unable to find it
    I think the best way to get HFS+ is to compile it by your self by setting the right Kernel Parameter.
    Why it's not implemented, well I think ext3 and fat32 is the usual standard, that almost everybody has. If every Filesystem should be implemented ......
    I think you should better by a small tidy PC for this, the flash rom at this devices are not that big to keep every feature in it.
    To get to your question about a chance, I don't think so. Since most of us are PC-Users:
    Linux can read and write FAT32
    Windoose can at least read with an extra driver ext32
    So for those who know what Linux is will probably format with ext32, the others will use fat32 to switch the USB-Drive between Windows and the WL*** device.
    greetings from Berlin
    Quote Originally Posted by piri
    hey,
    cheers, thomas.
    what is a flashfs file.
    and i missing the option url filter what i need that is why i dont need this firmware. Or is it possible that i can put url filter in by flashfs.
    I wait for a reply (oleg?)
    Mar 2004
    Europe
    thanks for your reply!
    Quote Originally Posted by ankn99
    do you have a how-to how-to do that? :-)
    hmmm, to tell a mac user that he shall buy a pc ....
    well, osx can read/write ext32, fat32 and hfs/hfs+ .... but I really don't think that because "most" people are using intel, oleg will not incorporate hfs+ support in his firmwares.... this must be a technical issue....
    cheers, thomas.
    wl500g is running linux, so using ext3 as most logical approach. Other filesystems (fat32/ntfs) are used for compatibility with original firmwares only. No other filesystems would be supported, as there are not enough space available in the built-in flash to support everything.
    Feb 2005
    Australia
    1.9.2.7-6b still drops out with bigpond cable
    I have been chasing a solution to my Bigpond dropout problem for months. Every 28 minutes, there are time-outs on email send/receive and browsing and complete dropouts on VPN (client end via router with either ethernet or wireless) or VoiP. Casual users might not notice these problems. Every new FW I hope it is fixed. Asus 1.9.2.7 did not drop out but lost connection completely every couple of days and had to be manually reconnected. Since then, all FW versions have not needed to be reconnected manually, but all have had the same dropout problem (every 28 minutes). This includes Oleg's 1.9.2.7-4 (installed 21 March 05), Asus 1.9.4.0, 1.9.4.6, 1.9.5.0 and Oleg's 1.9.2.7-6b (using FW restoration tool; what a hassle!). Please help! Surely I am not the only one with this problem. Or have all Bigpond users given up on the Asus routers or Bigpond (I don't have the latter option). Surely there is a solution to this.
    SNMP not working
    Hello, i am new to this fórum.
    i own a WL-500g, and i made this firmware update for first time. everything installed correctly.
    the reason for the update was only this SNMP support, and is not working
    i am using MRTG with this command:
    perl cfgmaker public@10.0.0.1 asus.cfg
    SNMP Error:
    no response received
    i didn't found any information about how to activate SNMP, or define the comunity and port.
    thanx in advance, and sorry my bad english
    excelent work Oleg! great firmware, fórum and support
    Quote Originally Posted by nonnux
    just after posting this i found on the admin area that SNMP was inactive.
    IP Config > SNMP > Enable SNMP
    (on this menu we can also name the comunity!)
    sorry for posting garbage, maybe my error could help someone
    Jan 2005
    Nederland
    Upgrade from 1.9.2.7-3b fails ???
    Hi, I try to upgrade from 1.9.2.7-3b to 1.9.2.7-6b and for some reason I am unable to finish installation. Luckily I can restart the 500g by cycling the power but it is strange or am I forgetting something ?
    So I was lucky/forgetting something, just resetted all parameters and I was able to upload the software.
    Upgrade problems
    Hi Peter,
    I was faced a similiar problem. One and only one of several WL500g routers, could not be updated to every version of Olegs software. Unfortunately I never found the reason! Several 1.9.2.7- version ended after upload and reset in a continous reset loop. You can notice a short "flicker" of the power lead every 10 to 15 sec. and the WLAN LED was never activated! I stick up with this problem. The last know version updating and running was 1.9.2.7-5 all ...-6(a,b) did not update to this router. May be that's useful to you to save your time. By the way this behaviour started earlier. Perhaps you search this forum by my user name....
    Sigurd
  1. Firmware v1.9.2.7 CR5, updated: v1.9.2.7 CR5a [Oleg]
    Last Post: 18-06-2005, 12:07
  2. Firmware v1.8.1.7 CR2 [Oleg] - updated ( CR2a )
    Last Post: 08-12-2004, 10:01
  3. Firmware v1.7.5.6 CR3 [Oleg]
    Last Post: 28-07-2004, 21:11
  4. Firmware v1.7.5.6 CR4 [Oleg]
    Last Post: 30-05-2004, 15:56
    Last Post: 07-04-2004, 17:22
