Instant Bluetooth setup guide
(english version of this theme)
1. Install necessary packages:
ipkg install bluez-libs
ipkg install bluez-utils
ipkg install bluez-hcidump
2. Create /tmp/harddisk/bluez and /tmp/harddisk/bluez/module folders
mkdir /tmp/harddisk/bluez
mkdir /tmp/harddisk/bluez/module
3.Download modules from
http://wl500g.info/attachment.php?at...8&d=1183282939
4. Extract modules into /tmp/harddisk/bluez/module folder without saving archive folder structure
5. Download the bluez.tar.gz file from http://wl500g.info/attachment.php?at...7&d=1192483272 and extract contents of the bluez folder with saving folder structure.
6. Run the /tmp/harddisk/bluez/start-bluez script that starts everything we need.
7. Add following string to post-mount:
echo "/tmp/harddisk/bluez/start-bluez" >> /usr/local/sbin/post-mount
in order to start this stuff at startup.
8. Phone settings are as follows: lookup router device, pair phone with router, add internet account. DHCP works properly for Bluetooth devices.
