Results 1 to 7 of 7
Thread: WL500G behind a WLAN-Ethernet bridge - how it works?
  1. Unhappy WL500G behind a WLAN-Ethernet bridge - No internet just errors
    Connection: Internet over Wlan --> Wlan/ethernetbridge --> Ethernet cable --> ASUS Router (for subrouting)
    After typing in all Data (IP[Static], gateway ...) it did not work I can not connect to internet Anybody know whats wrong? I told my ISP the mac adress which was printed on the router.
    But where is the MAC adress of the wlan interface
    ThanX for help
  2. Jan 1 01:01:54 WL500g user.warn klogd: ALERTIN=eth1 OUT= MAC=00:0e:a6:9f:06:80:00:02:dd:33:1e:fb:08:00 SRC=82.32.107.35 DST=212.21.75.100 LEN=48 TOS=0x00 PREC=0x00 TTL=113 ID=44028 DF PROTO=TCP SPT=4514 DPT=17300 WINDOW=16384 RES=0x00 SYN URGP=59783
    What does this error mean?
    00:0e:a6:9f:06:80 is the MAC adress of my Asus Router
    This one: neg fail
    and this one: Warning: unable to open an initial console.
    are shown by booting of my router
    Complet boot:
    Jan 1 01:00:13 WL500g syslog.notice klogd: klogd started: BusyBox v1.00-pre7 (2004.05.22-13:04+0000)
    Jan 1 01:00:13 WL500g user.warn klogd: CPU revision is: 00024000
    Jan 1 01:00:13 WL500g user.warn klogd: Loading BCM4710 MMU routines.
    Jan 1 01:00:13 WL500g user.warn klogd: Primary instruction cache 8kb, linesize 16 bytes (2 ways)
    Jan 1 01:00:13 WL500g user.warn klogd: Primary data cache 4kb, linesize 16 bytes (2 ways)
    Jan 1 01:00:13 WL500g user.warn klogd: Linux version 2.4.20 (root@omnibook) (gcc version 3.0 20010422 (prerelease) with bcm4710a0 modifications) #24 Mon May 3 20:52:46 MSD 2004
    Jan 1 01:00:13 WL500g user.warn klogd: Determined physical RAM map:
    Jan 1 01:00:13 WL500g user.warn klogd: memory: 01000000 @ 00000000 (usable)
    Jan 1 01:00:13 WL500g user.warn klogd: On node 0 totalpages: 4096
    Jan 1 01:00:13 WL500g user.warn klogd: zone(0): 4096 pages.
    Jan 1 01:00:13 WL500g user.warn klogd: zone(1): 0 pages.
    Jan 1 01:00:13 WL500g user.warn klogd: zone(2): 0 pages.
    Jan 1 01:00:13 WL500g user.warn klogd: Kernel command line: root=/dev/mtdblock2 noinitrd init=/linuxrc
    Jan 1 01:00:13 WL500g user.warn klogd: CPU: BCM4710 rev 0 at 125 MHz
    Jan 1 01:00:13 WL500g user.warn klogd: Calibrating delay loop... 82.94 BogoMIPS
    Jan 1 01:00:13 WL500g user.warn klogd: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
    Jan 1 01:00:13 WL500g user.warn klogd: Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Jan 1 01:00:13 WL500g user.warn klogd: Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
    Jan 1 01:00:13 WL500g user.warn klogd: Checking for 'wait' instruction... unavailable.
    Jan 1 01:00:13 WL500g user.warn klogd: POSIX conformance testing by UNIFIX
    Jan 1 01:00:13 WL500g user.warn klogd: PCI: Fixing up bus 0
    Jan 1 01:00:13 WL500g user.warn klogd: PCI: Fixing up bridge
    Jan 1 01:00:13 WL500g user.warn klogd: PCI: Fixing up bus 1
    Jan 1 01:00:13 WL500g user.warn klogd: Initializing RT netlink socket
    Jan 1 01:00:13 WL500g user.warn klogd: Starting kswapd
    Jan 1 01:00:13 WL500g user.notice klogd: NTFS driver v1.1.22 [Flags: R/O]
    Jan 1 01:00:13 WL500g user.warn klogd: pty: 256 Unix98 ptys configured
    Jan 1 01:00:13 WL500g user.notice klogd: Amd/Fujitsu Extended Query Table v1.1 at 0x0040
    Jan 1 01:00:13 WL500g user.warn klogd: Physically mapped flash: Swapping erase regions for broken CFI table.
    Jan 1 01:00:13 WL500g user.notice klogd: number of CFI chips: 1
    Jan 1 01:00:13 WL500g user.notice klogd: Flash device: 0x400000 at 0x1fc00000
    Jan 1 01:00:13 WL500g user.notice klogd: Physically mapped flash: squashfs filesystem found at block 949
    Jan 1 01:00:13 WL500g user.notice klogd: Creating 5 MTD partitions on "Physically mapped flash":
    Jan 1 01:00:13 WL500g user.notice klogd: 0x00000000-0x00040000 : "pmon"
    Jan 1 01:00:13 WL500g user.notice klogd: 0x00040000-0x003e0000 : "linux"
    Jan 1 01:00:13 WL500g user.notice klogd: 0x000ed760-0x003e0000 : "rootfs"
    Jan 1 01:00:13 WL500g user.notice klogd: 0x003f0000-0x00400000 : "nvram"
    Jan 1 01:00:13 WL500g user.notice klogd: 0x003e0000-0x003f0000 : "config"
    Jan 1 01:00:13 WL500g user.warn klogd: ip_conntrack version 2.1 (128 buckets, 1024 max) - 344 bytes per conntrack
    Jan 1 01:00:13 WL500g user.warn klogd: ip_conntrack_pptp version 1.9 loaded
    Jan 1 01:00:13 WL500g user.warn klogd: ip_nat_pptp version 1.5 loaded
    Jan 1 01:00:13 WL500g user.warn klogd: ip_tables: (C) 2000-2002 Netfilter core team
    Jan 1 01:00:13 WL500g user.warn klogd: ipt_time loading
    Jan 1 01:00:13 WL500g user.warn klogd: FAT: bogus logical sector size 7680
    Jan 1 01:00:13 WL500g user.err klogd: NTFS: Unable to set blocksize 512.
    Jan 1 01:00:13 WL500g user.warn klogd: VFS: Mounted root (squashfs filesystem) readonly.
    Jan 1 01:00:13 WL500g user.warn klogd: Warning: unable to open an initial console.
    Jan 1 01:00:13 WL500g user.warn klogd: Algorithmics/MIPS FPU Emulator v1.5
    Jan 1 01:00:13 WL500g user.warn klogd: eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.50.21.10
    Jan 1 01:00:13 WL500g user.warn klogd: eth1: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.50.21.10
    Jan 1 01:00:13 WL500g user.warn klogd: PCI: Enabling device 01:02.0 (0004 -> 0006)
    Jan 1 01:00:13 WL500g user.warn klogd: eth2: Broadcom BCM43XX 802.11 Wireless Controller 3.50.21.10 (Compiled in . at 20:53:00 on Jan 21 2004)
    Jan 1 01:00:24 WL500g user.warn klogd: lp driver: get device ID
    Jan 1 01:00:24 WL500g user.warn klogd: neg fail
    Jan 1 01:00:28 WL500g user.warn klogd: Register User Space Key Handler : 535 0
    Quote Originally Posted by Tele
    This is not an error, but firewall alert, which means what someone from 212.21.75.100 sends tcp connection request packet to your address.
    This one: neg fail
    Asus's kernel module unable to negotiate with LPT printer,
    it's ok.
    ThanX for help
    Were you able to connect to the internet without wl500g? Also, have you checked what your wlan/ethernet bridge established connection?
  5. Quote Originally Posted by Oleg
    Yes without the wl500g it works! And if i use the router behind this working PC
    the wl500g works too! The bridge is ok too!
  6. Quote Originally Posted by Oleg
    212.21.75.100 is my stastic IP ! I thought the firewall is off - I did not turn it on!
    And what does this address MAC=00:0e:a6:9f:06:80:00:02:dd:33:1e:fb:08:00 means?
    Is this the real address of my router?
  7. Some DATA of mine from my ISP: 212.21.75.100 is my static IP / 255.255.255.224 is my Subnetmask / 192.168.74.1 is my gateway and then the 2 dns adresses
    If I try to ping for example 212.21.75.93 there is shown an error: Destination Network can not be reached ( in Windows - cmd) HELP
    WHY CAN I NOT CONNECT to THE INTERNET?????
  1. WL-HDD as wireless ethernet bridge
    By dony71 in forum WL-HDD Q&A
    Last Post: 27-06-2005, 15:29
  2. ethernet bridge
    By tonia in forum WL-500g Q&A
    Last Post: 24-05-2005, 09:51
  3. Bug with Station/Ethernet Bridge?
    By the Henglaender in forum WL-500g Q&A
    Last Post: 20-05-2005, 21:08
  4. WL HDD as a bridge from LAN to WLAN (Internet)?
    By jpritzkat in forum WL-HDD Q&A
    Last Post: 02-05-2005, 08:02
