I have a (jailbroken) iPhone 3G which will just not connect to my WL-500W. I know I using the correct security credentials. Other devices (my laptop, Nokia N95) have no problems connecting to the router. What's with the iPhone
That's what I've always wondered
Well, does your iphone connect at all to other hotspots?
if it does, you can try out 2 things:
1. test if it works without a password protected wifi
2. change the regulatory mode of the router: http://code.google.com/p/wl500g/wiki...egulatory_Mode
apart from that, I dunno
