please look at this first: http://en.wikipedia.org/wiki/DBm
30dbm is quite a bit
you may set it that high, but the power supply can't handle that I guess...
also, direct input settings don't work for me, when I try to save them with nvram they also don't work...
so... I have no idea, maybe you need to search a bit on the forums
