Results 1 to 2 of 2
Thread: Increase WLAN speed
    Increase WLAN speed
    When I transfer files over the WLAN I only get a maximum speed of approximately 1000 kBps even though my Wireless Mode is 54G Only. Should I check 54g Protection too or what? Are there any tweaks I can use to increase the speed?
    Thanks in advance for any help.
    Btw: The PCI-card has support for 108 MBps.
    Jun 2004
    Germany / NRW
    Trasfer you the file from a wlan pc to a wlan pc, or to a computer in the "normal" lan?
    What is with the signal?
  1. Safe radio power increase?
    By einarmr in forum WL-300g Q&A
    Last Post: 06-03-2006, 14:58
  2. Replies: 1
    Last Post: 20-05-2005, 07:57
  3. Replies: 4
    Last Post: 02-10-2004, 12:48
  4. WLAN Connection speed A716 / Wl500g
    By ceesmf in forum MyPal A620 / A620BT / A716 / A730 / A730W Q&A
    Last Post: 25-08-2004, 13:44
  5. Does Frame Bursting increase performance?
    By FIB in forum WL-500g Q&A
    Last Post: 02-01-2004, 10:18
