Page 3 of 3 FirstFirst 123
Results 31 to 45 of 57
Thread: FAQ: часто задаваемые вопросы
    Exclamation RT-N-1.9.2.7-rtn-r4667
    Новый релиз: RT-N-1.9.2.7-rtn-r4667 (2012-10-08)
    https://code.google.com/p/wl500g/wiki/News
    Detailed revision history
    • kernel
      • enable LBD (disks > 2Tb)
      • backports from upstream - MIPS, fs(ext3, ext4, udf), net(ipv4{6} raw), netfilter(xt_limit)
    • pppd MSCHAPv2 fix (issue 355)
    Lightbulb 1.9.2.7-rtn-r4772
    Новый релиз прошивки 1.9.2.7-rtn-r4772
    http://code.google.com/p/wl500g/ (2012-12-23)
    * kernel
    o backports from upstream - MIPS, fs(ext4, udf), net(udp, raw), netfilter(rtcp, ACK), usb(usbip)
    o cdc-acm: fix info for /proc/bus/usb/devpath
    * dnsmasq 2.65
    o upstream patches
    * 3g/cdma
    o usb-modeswitch 1.2.5 + usb-modeswitch-data-20121109
    o modem status scripts update
    o new ZTE modems in modems.conf
    o dial scripts update (excluded options: nopcomp, noaccomp due to ZTE MF195 support)
    * busybox
    o bugfixes (ntpd)
    * misc
    o miniupnpd: fix memory & socket leaks
    o rp-pppoe: update to 3.11 & fixes
    o pppd: workaround for negotiated bad peer addresses
    o inadyn: fix HE ipv6
    http://code.google.com/p/wl500g/wiki/News
    Lightbulb RT-N-1.9.2.7-rtn-r4923
    Новый релиз прошивки RT-N-1.9.2.7-rtn-r4923
    FW_RT-N-1.9.2.7-rtn-r4923 (2013-03-16)
    • kernel
      o backports from upstream - MIPS, core (idr, softirq, genirq, wait, lockdep), fs (writeback, splice, ext2, ext3, ext4, udf, isofs), tty,
      ...net (sock, tcp, arp, ipv6), netfilter (nf_conntrack, xt_TEE, xt_CONNMARK), usb (EHCI, usb-storage, usbnet, usb-serial, usbip), scsi/sd
      o cdc_ncm, cdc_wdm, qmi_wwan drivers backport (EXPERIMENTAL)
    • 3g/cdma
      o new ZTE, HUAWEI modems in modems.conf
      o uqmi - utility to manage QMI speaking modems from OpenWRT
    • ntfs-3g 2013.1.13AR.1
    • miniupnpd 1.8.20130207
    • udpxy 1.0.23-7
    • ipset 4.5
    • bugfixes
      o busybox (ntpd, mdev, libbb)
    Lightbulb RT-N-1.9.2.7-rtn-r5066
    Новый релиз прошивки RT-N-1.9.2.7-rtn-r5066
    FW_RT-N-1.9.2.7-rtn-r5066 (2013-04-27)
    • kernel
      o backports from upstream - MIPS, mm(Slab API change), irq(genirq, softirq), sched(workqueues), fs(epoll),
      ...net(ipv4, ipv6, udp, tcp), netfilter, usb(usbnet, cdc_wdm, cdc_ether, cdc_ncm, qmi_wwan, usbip, serial)
      o fastnat: fix throughput degradation when url filter enabled
      o option: Updates from 3.8 & blacklist fixes, thanks to Vampik
      o driver core: convert "struct class_device" to "struct device"
    • 3g/cdma
      o CDC NCM, QMI modems support (EXPERIMENTAL)
      o add ZTE MF190J
    • dnsmasq 2.66
    • dropbear 2013.58
    • misc
      o igmpproxy: eliminate use of second raw socket
      o netfilter/iptables: Add xt_iface & xt_condition matches from xtables-addons project
      o tcpdump 4.2.1
    • pppd
      o revert auth-down call to gentoo's auth-fail
      o request/suggest mschapv2 first, also fix unsynced bitmasks/defs
    • bugfixes
      o web-UI fixes, thanks to Vampik
      o busybox (vi)
      o iptables (ipset)
      o iproute2 (ip)
    Lightbulb RT-N-1.9.2.7-rtn-r7510
    Новый релиз прошивки RT-N-1.9.2.7-rtn-r7510
    https://github.com/wl500g/wl500g/commits/master
    http://asus.vectormm.net/rtn/7510
    Latest release r7510
    · @lly-dev lly-dev released this 13 days ago
    · 8 commits to master since this release
    • uClibc 0.9.33.2
    • dnsmasq 2.77
    • busybox 1.24.2
    • dropbear 2016.74
    • miniupnpd 2.0
    • vsftpd 3.0.3
    • usb_modeswitch 2.3.0
    • many other bugfixes & backports
    https://github.com/wl500g/wl500g/releases/tag/r7510
    Exclamation RT-N-1.9.2.7-rtn-r4330
    Новый релиз: RT-N-1.9.2.7-rtn-r4330 (2012-06-12)
    • uClibc 0.9.32: Implement tiny /etc/gai.conf - to change default names resolution order to IPv4 first,
      IPv6 second, create /etc/gai.conf containing single line "precedence ipv4"
    • Broadcom SDK
      • emf/igs backports from 5.110
      • fix igmpv3 snooping
      • minor cleanups
    • kernel
      • backports from upstream - MIPS, mm(slub), softirq, net(tcp, ipv4, ipv6, ppp, netlink), netfilter,
        fs(writeback, bdi, fuse, fat, ext4, sysfs), vfs, usb(ehci, usbnet, cdc_ether), tty, debug(softlockup)
      • netfilter backports, fix for issue 308
      • Decrease hardcoded limits - max swapfiles 2, max inet protos 64
      • Disable AIO support
      • usbip fixes
      • fastnat: fix openvpn and other headerless net devices
    • rc/www: bugfixes
    • 3g/cdma
      • usb-modeswitch-data 2012-05-31
    • dnsmasq 2.62
      • enable slaac & dhcpv6, not used yet
    • usbip userspace daemon 1.1.1 (usb.ids should be in /opt/share)
    • miniupnpd 1.7
    • pppd
      • preserve linkname pid file on lcp termination
    • misc
      • busybox: bugfixes from upstream (udhcp, hwclock, busybox, mdev)
      • libusb: bugfixes from upstream
      • rp-pppoe: upstream patches
      • rp-l2tp: fixes
      • pptp/l2tp: peer route improvements
    Nov 2006
    Exclamation RT-N-1.9.2.7-rtn-r4051
    Так как корпорация добра упразнила страничку Activity(Updates) для всех проектов на гуглкоде, анонс релиза r4051 продублирую здесь.
    RT-N-1.9.2.7-rtn-r4051 (2012-04-02)
    • ipkg: Switch to new OpenWRT-based repository http://wl500g-repo.googlecode.com , thanks to ryzhov_al at wl500g.info
    • kernel
      • backports from upstream - MIPS, mm, sched, net(udp/raw, tcp, af_unix, arp, ipv4/ipv6, neigh, pptp, tunnel),
        bridge, fs(ext3/ext4, cifs, ntfs, udf), usb(uvcvideo, gspca, usbnet, rndis_host, cdc_ether)
      • netfilter backports:
        • xt_iprange v1
        • xt_TOS/xt_tos v1 merged into xt_DSCP/xt_dscp
        • u32 match
        • xt_mark v1, xt_MARK v2, merge xt_MARK into xt_mark
        • xt_string v1
        • xt_connmark v1, merge xt_CONNMARK into xt_connmark
        • xt_owner v1
        • xt_connlimit v1
        • xt_addrtype v1 (EXPERIMENTAL)
        • xt_hashlimit v1 (EXPERIMENTAL)
      • kmemleak: backport memory leak detector support (EXPERIMENTAL)
      • unionfs 2.5.11 - contributed by VA_DOS at wl500g.info
    • rc
      • bugfixes
      • draft multiwan support(incomplete)
      • basic usbnet support
    • www
      • allow to disable ntfs support at all
      • split WAN and LAN pages
    • 3g/cdma
      • usb-modeswitch 1.2.3 + usb-modeswitch-data 2012-01-20
    • dropbear 2012.55
    • vsftpd 2.3.5
    • dnsmasq 2.60
    • ntfs-3g 2012.1.15AR.1
    • udpxy 1.0.21-2
      • patches by AlexeyS @ wl500g.info:
      • setup TCP_NODELAY on accept socket
      • call get_mstream_type() for F_CHECK_FMT case only
      • optimize multicast address internal passing
      • compile out UDPXY_FILEIO specific parts
    • miniupnpd 1.6.20120320
    • quagga 0.99.20.1
    • misc
      • busybox: bugfixes from upstream (mdev, read, httpd, test)
      • mjpg-streamer: output_http - redirect to stream automagically if no www folder configured
      • pppd: pppoe - workaround for buggy nas; mppe fixes
      • igmpproxy: support multiple multicast sources
      • iptables: fixes from upstream
      • scsi-idle: switch scsi-start/stop to use SG_IO
    Спасибо всем, кто помогал сделать прошивку еще лучше!
    3G USB Adapter Support List
    3G USB Adapter Support List:
    http://www.hub.ru/wiki/Поддерживаемые_3G/CDMA_модемы
    Поддерживаемые 4G/3G/CDMA модемы - список модемов, с которыми проверена работа прошивки энтузиастов
    № п/п Название модели Тип модема (3G/CDMA) Работа модема Проверенные операторы
    1 Airplus MCD-800 CDMA/EVDO Rev A V OK' SkyLink
    2 AnyDATA ADU-E100A CDMA/EVDO V OK' SkyLink
    3 AnyDATA ADU-300A CDMA/EVDO V OK' SkyLink
    4 AnyDATA ADU-310A CDMA/EVDO V OK' SkyLink
    5 AnyDATA ADU-500A CDMA/EVDO Rev A V OK' MTS Ukraina
    6 AnyDATA ADU-510A CDMA/EVDO Rev A V OK' MTS Ukraina
    7 AnyDATA ADU-520A CDMA/EVDO V OK' MTS Ukraina
    8 Axesstel MV110 CDMA/EVDO Rev A V OK' MTS Ukraina
    9 Cmotech CCU-550 CDMA/EVDO Rev 0 V OK' PeopleNet Ukraine
    10 Cmotech CDU-550 CDMA/EVDO Rev A V OK' InterTelecom Ukraine
    11 Cmotech CNU-680 CDMA/EVDO Rev A V OK' SkyLink, BWC (Irkutsk)
    12 Cricket A600 CDMA/EVDO V OK' Intertelecom Ukraine
    13 Huawei E150 GPRS/EDGE/HSDPA/UMTS V OK' MTS
    14 Huawei E156G GPRS/EDGE/HSDPA/UMTS V OK' MTS
    15 Huawei E160G GPRS/EDGE/HSDPA/UMTS ? MegaFon
    16 Huawei E169G GPRS/EDGE/HSDPA/UMTS ? ?
    17 Huawei E173 GPRS/EDGE/HSDPA/UMTS V OK' MegaFon, BeeLine, MTS
    18 Huawei E220 GPRS/EDGE/HSDPA/UMTS V OK' BeeLine, MTS Ukraina, Utel
    19 Huawei E1550 GPRS/EDGE/HSDPA/UMTS V OK' MegaFon, BeeLine, MTS, Utel
    20 Huawei E1750 GPRS/EDGE/HSDPA/UMTS V OK' MegaFon, MTS
    21 Huawei E1820 GPRS/EDGE/HSDPA/UMTS V OK' MegaFon, MTS
    22 Novatel U720 CDMA/EVDO Rev A V OK' PeopleNet Ukraine
    23 ZTE MF100 GPRS/EDGE/HSDPA/UMTS V OK' Megafon
    24 ZTE MF180 GPRS/EDGE/HSDPA/UMTS V OK' MTS
    25 ZTE MF626 GPRS/EDGE/HSDPA/UMTS V OK' BeeLine, MTS
    26 ZTE MF627 GPRS/EDGE/HSDPA/UMTS V OK' BeeLine, Tele2
    27 ZTE MF668 GPRS/EDGE/HSDPA/UMTS ? ?
    28 ZTE AC5710 CDMA/EVDO Rev A V OK' MTS Connect Ukraine
    29 ZTE AC5730 CDMA/EVDO Rev A ? SkyLink
    30 ZTE AC8710 CDMA/EVDO Rev A V OK' PeopleNet Ukraine
    31 WeTelecom WMU-100A CDMA/EVDO Rev 0 ? SkyLink
    32 WeTelecom WM-D200 CDMA/EVDO Rev A V OK' SkyLink
    33 Huawei E353 GPRS/EDGE/UMTS/HSDPA/HSUPA/HSPA+ V OK' MTS
    34 Huawei E392 4G-LTE/GPRS/EDGE/UMTS/HSPA/HSPA+ V OK' Megafon, MTS*, Yota*
    35 Huawei E398 4G-LTE/GPRS/EDGE/UMTS/HSPA/HSDPA+ V OK' -rtn-r4643 Megafon
    36 Yota One LU150 LTE 4G-LTE V OK' Yota
    Thumbs up VLANы на WL-500W (подключение STB приставки, второй провайдер)
    Нашлась свободная минута, решил написать, как это делается.
    Начну со следующей информации - нумерации портов (слева имя, справа физический номер):
    LAN1 - 0
    LAN2 - 1
    LAN3 - 2
    LAN4 - 3
    WAN - 4
    CPU - 5
    Интерфейсы: eth0 - LAN порты свитча, eth1 - WAN порт, eth2 - WiFi
    Мне так и не удалось до конца заставить WAN порт функционировать как часть свитча, поэтому конфигурацию, как на WL-500gP получить не удастся. Более того, прийдётся в качестве WAN порта использовать один из LAN. Я выбрал для этого LAN1.
    Старый WAN порт будет с помощью программного свитча соединён с LAN. Поэтому при обменах между проводными компьютерами внутри LAN он будет работать несколько медленее.
    Пример 1 (годится для корбины, qwerty neo, стрима): 1 ТВ приставка, кабель от провайдера подключается в LAN1, приставка в LAN2, порты LAN3, LAN4, WAN - ваша внутренняя сеть.
    nvram set boardflags=0x110
    nvram set vlan0ports="2 3 5*"
    nvram set vlan1ports="0 1 5"
    nvram set vlan0hwname=et0
    nvram set vlan1hwname=et0
    nvram set wan_ifnames=vlan1
    nvram set wan_ifname=vlan1
    nvram set lan_ifnames="vlan0 eth1 eth2"
    nvram commit
    reboot
    Пример 2: 2 ТВ приставки (LAN2, LAN3):
    nvram set vlan0ports="3 5*"
    nvram set vlan1ports="0 1 2 5"
    nvram commit
    reboot
    Пример 3: Если Вы хотите использовать роутер для подключения ко второму провайдеру, а ТВ приставки у Вас нет, то используйте такой конфиг:
    nvram set vlan0ports="1 2 3 5*"
    nvram set vlan1ports="0 5"
    nvram set lan_ifnames="vlan0 eth2"
    nvram commit
    reboot
    В результате основной провайдер - LAN1 (vlan1), второй WAN (eth1), компьютеры подключаете к LAN2-4.
    Либо такой:
    nvram set wan_ifnames=eth1
    nvram set wan_ifname=eth1
    nvram commit
    reboot
    В результате основной провайдер - WAN (eth1), второй LAN1 (vlan1), компьютеры подключаете к LAN2-4.
    Всё это можно комбинировать конечно.
    Как вернуть настройки назад: либо сбросить в дефолт, либо выполнить
    nvram set boardflags=0x10
    nvram set lan_ifnames="eth0 eth2"
    nvram commit
    reboot
    Пишите у кого получилось. http://wl500g.info/showthread.php?13...0%E9%E4%E5%F0)
  1. Вопросы по TTL =(
    By SBorovkov in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 12-02-2016, 08:51
  2. Вопросы по работе IPTV (EMF & WMF)
    Last Post: 29-03-2015, 13:18
  3. Вопросы по работе PHP на роутере
    By Jekl in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 21-10-2014, 12:45
  4. Вопросы по перепрошивке dir-320
    By gweri in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 29-10-2011, 10:36
  5. Вопросы по stupidftp
    By Klaus-Mary in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 30-10-2007, 21:18
