Results 181 to 195 of 283
Thread: alpha rt-n firmware releases
Threaded View
    The Netherlands - Eindhoven
    I already had a post with firmware releases from http://code.google.com/p/wl500g/
    but I tought that a new thread would be easier to find
    You can look through the changes in svn via this link: http://code.google.com/p/wl500g/sour.../branches/rt-n
    Also there is a download source from the Russian forum: ftp://core.dumped.ru/rt-n/
    it contains both firmware (RT-N16 and RT-N12) and additional modules
    so the list (which is updating):
    [B]From now on I can host the firmware on my website again.
    All the RT-N models: http://wpte.kicks-ass.net/downloads/...s/1.9.2.7-rtn/ also the wl models are available here with kernel 2.6
    The old kernel 2.4 wl models: http://wpte.kicks-ass.net/downloads/...lys/1.9.2.7-d/
    I don't build as regular as the nightly builds on ftp://core.dumped.ru/rt-n/ so keep in mind that you could download from there as well (with probably newer versions)
    or try my test nightly builds: http://wpte.kicks-ass.net/downloads/...ware/Nightlys/ (I'm not promising I can build every night tho)
    basic things you need to know about this firmware:
    • This firmware is still in alpha state, so it's experimental
    • it's pretty stable so far for me
    • wireless works in r1200 and higher for non-encrypted, WEP and WPA-AES encryption. WPA2 works since r1484
    • Back up your flasfs image before flashing the firmware. This will be ereased while flashing (in newer versions not likely, but still, it's always good to have a backup). After the flashing is complete you may restore the saved flashfs and everything should work again.
    • setting files from other router models can not be uploaded directly to the rt-n16, it's better to manually set up the webconfig
    • harddisks are not listed as /dev/discs/disc0... instead they are listed with character in alphabetic order: /dev/discs/disca. so mind that when setting up fstab
    • webcams don't work yet
    • printers should work from r1393
    problems you've found can be posted in the general firmware thread: http://wl500g.info/showthread.php?t=18004
    please post only real problems like "my router restarts every 5 minutes" or something like that
    Ofcourse mind the simple rules of describing a problem like that, to make it easier for the developers to fix it
    • Describe the problem clearly
    • Tell how you could possibly reproduce the same problems again.
    • If you've found a way to fix the problem, please write how
    general problems like "hey my harddrive doesn't mount" or "hey what settings should I use?" can be posted here
    that was all I guess
    Last Post: 14-10-2009, 11:10
    Last Post: 13-07-2008, 01:28
    Last Post: 17-04-2008, 23:34
  4. Visit WL-500g Firmware Releases forum
    By Oleg in forum WL-550gE Firmware Discussion
    Last Post: 18-09-2006, 10:22
    Last Post: 21-10-2004, 14:55
