Results 16 to 30 of 32
Thread: no ftp connection from wan anymore
Threaded View
    Hi Folkes,
    I think I have been a littlebit too enthousiastic with busybox and telnet, eventhough I am a complete noob in these matters.
    So,.. I bought my wl500g after reading several websites and after reading what this thing was capable of.. I still think its great.
    But.... I bought it to us the ftp server for wan use. With the original firmware I did not manage to use this feature. so after first upgrading to a newer original firmware I still did not manage.
    Sollution? installing firmware from Oleg.. (I now have 1.9.2.7-4 installed) and it actually worked.
    Doing this I wanted more MORE MORE features!!!
    So,.. I used through telnet some options mentioned here in this forum. Some how I think I did not manage to use the virtual input in telnet the right way, though the other lines were updated. (I used for example the port 80 issue mentioned here in the forum).
    After doing this FTP aswell as webcam was not aproachable from wansite anymore...
    Knowing that I must have done something wrong,.. I figured just to go back in firmware (original) to delete the entries made by telnet. Apparently that did not the trick. So.... going back to firmware 1.9.2.7-4 now at least my webcam is working from wansite again,.. but ftp gives a message something like this:
    "Mar 27 12:46:31 kernel: DROPIN=eth1 OUT= MAC=bla bl blaSRC= bla bla DST= bla bla bla LEN=42 TOS=0x00 PREC=0x00 TTL=107 ID=42067 DF PROTO=TCP SPT=49763 DPT=2992 SEQ=2501708738 ACK=3834017422 WINDOW=65487 RES=0x00 ACK PSH URGP=0
    Mar 27 12:46:32 kernel: ACCEPT IN=eth1 OUT= MAC=bla bla bla :71:08:00 SRC=80.61.167.119 DST=bla bla blaLEN=48 TOS=0x00 PREC=0x00 TTL=116 ID=11616 DF PROTO=TCP SPT=25667 DPT=7776 SEQ=259557029 ACK=0 WINDOW=64512 RES=0x00 SYN URGP=0 OPT (020405B401010402)
    Mar 27 12:46:32 kernel: DROPIN=eth1 OUT= MAC=bla bla bla:08:00 SRC=67.170.5.29 DST=bla bla blaLEN=42 TOS=0x00 PREC=0x00 TTL=107 ID=42077 DF PROTO=TCP SPT=49763 DPT=2992 SEQ=2501708738 ACK=3834017422 WINDOW=65487 RES=0x00 ACK PSH URGP=0
    Mar 27 12:46:32 kernel: DROPIN=eth1 OUT= MAC=bla bla bla:08:00 SRC=205.188.8.236 DST=bla bla blaLEN=40 TOS=0x00 PREC=0x00 TTL=102 ID=12462 DF PROTO=TCP SPT=5190 DPT=2557 SEQ=2123700918 ACK=1687883417 WINDOW=16384 RES=0x00 ACK RST URGP=0 "
    I have no cleu, why it is blocking the ip adresses to connect to ftp. Also I dont know why it is not giving the normal message: FTP user denied or something.
    Is there somebody who knows how I can get my standard settings for busybox through telnet again?
    please help.. I AM a noob.. and I promise when it all works again,.. I will never touch this anymore..
  1. no access to the router anymore - what to do?
    By fogg in forum WL-500g Q&A
    Last Post: 20-12-2008, 16:21
  2. Router doesn't see USB disk anymore
    By Styno in forum WL-500g Q&A
    Last Post: 15-08-2006, 08:37
  3. Unable to use WL-500g anymore
    By phedny in forum WL-500g Q&A
    Last Post: 23-05-2005, 15:39
  4. Replies: 0
    Last Post: 10-12-2004, 12:28
