Results 1 to 13 of 13
Thread: Loading probs with websites - MTU issue
    Feb 2005
    Germany - Cologne
    hi all,
    if you have lags when loading sites or when some sites never load in the webbrowser and you have a DESKTOP FIREWALL installed then this might be a solution:
    here is what i did to solve the probs: just open the regedit program (do this by pressing START - COMMAND - regedit).
    then search the value HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Tcpip\Parameters\Interfaces\[adapterid]
    adapter id is a very long unreadable string like this --> {DEA96A6F-43A6-479C-9F04-6B9DAXX699F}
    there should be several of these entries. choose the one which is showing your network settings at the right window pane. you can identify the 'right entry' by looking at the value DhcpIPAddress which hast to correspond with your own ip (check this by clicking START - COMMAND - cmd - ipconfig)
    all other entries just show 0.0.0.0 as ip or the value does not exist - only one shows your ip correctly.
    found
    then add a DWORD-Value, name it MTU and assign the value hex 5d4 (that's 1492 in dec).
    reboot and test again.
    for me it worked out probably.
    the firewalls affected by that are:
    kerio in any version
    outpost (only tested the last release downloadable at augnitum)
    hth
    alex (modnet25)
    Feb 2005
    Germany - Cologne
    Another Info
    hi all,
    another info on this can be found at the microsoft TECHNET
    Path Maximum Transmission Unit (PMTU) Black Hole-Router
    @oleg and antiloop: might this be THE explanation for the problem?
    anyway, it explains why some of us have the problem without a desktop firewall.
    please check the article carefully :-) thanks
    nice weekend all
    Could this be related?
    I'm having problems with random sites not responding every now and then and working fine after a retry. This is only happening on WiFi, wired I have no problems at all...
    I've added the MTU key and tried to detect the effective MTU using the ping method described in the article too, but I can't even get a 100% response with multiple tests on the lowest settings.
    Three ping rounds (= 12 pings) will always get me at least one time-out on WiFi.
    E.g. [ping www.google.com -f -l 548]
    Any suggestions?
    Cool Thanks!!!
    Quote Originally Posted by modnet25
    Thanks for this, I spent 2 nights trying to solve this before I've found your solution!
    Feb 2005
    Germany - Cologne
    Question Black Hole Router
    Hi all,
    i would like to discuss on how we can change the settings in the wl500g to get rid of this black hole thing described here
    http://wl500g.info/showthread.php?t=1920
    @oleg: may be you can explain something?
    @antiloop: you are also one of the hardcoders here...some idea?
    @all others: i can't believe that this issue not important...go - start your brains and let's find a solution
    so far
    alex
    Wl500g is not a blackhole. Your PC firewall blocks ICMP traffic.
    Feb 2005
    Germany - Cologne
    damn
    you're right but why the hack couldn't you answer a few days before
    changed the settings and now it seems to work.
    Strange, I've answered to you about a year ago about a PMTU discovery, which is done by the means of ICMP.
    Feb 2005
    Germany - Cologne
    Unhappy eh
    did it send a reply?
    hi all,
    hth
    alex (modnet25)
    That is just a workaround, not a solution. The problem is that somewhere on the way of the packets you send, a certain type of ICMP packets is dropped/filtered. Sonetimes, even companies do that. However, it is more likely that your desktop firewall is configured badly. Let it pass ICMP Destination Unreachable-Fragmentation Needed packets and it should work.
    Frank
    I had this time-out problem too, it was solved by switching to Oleg's latest firmware. I used to run 1.9.6.0 and tried the reg thing and adding ping stuff to windows firewall, to no avail...
    So thumbs up for Oleg .
    From a bunch of articles I read online, since I use PPPoE, The correct value for PPPoE should be 1454 (HEX=5ae).
  1. How to know the CPU loading of WL500g?
    By dolphin in forum WL-500g Q&A
    Last Post: 18-05-2005, 08:47
  2. WL500g connection issue
    By luso67 in forum WL-500g Q&A
    Last Post: 25-04-2005, 19:16
  3. Internet connection issue
    By mabirkinshaw in forum WL-500g Q&A
    Last Post: 02-10-2004, 22:43
  4. [A620] ISSUE - White Screen
    By Antiloop in forum MyPal A620 / A620BT / A716 / A730 / A730W Q&A
    Last Post: 13-06-2004, 03:50
