Results 1 to 15 of 27
Thread: Please help: transmission does not work !
    Unhappy Please help: transmission does not work !
    Ok..here goes nothing or all..
    I followed this guide for my configuration using oleg firmware:
    http://wl500g.info/showthread.php?t=5909
    i installed gnuplot, logrotate and transmission:
    ipkg install gnuplot
     ipkg install logrotate
     ipkg install transmission
    (cron was already installed).
    since i used marcnesium tutorial, my directories are:
    /opt/share/torrent
     /opt/share/torrent/source
     /opt/share/torrent/work
     /opt/share/torrent/target
    my transmission.conf file has the following:
    #   Configuration
    #   NOTE: no spaces around the = sign
    #   the config will be sourced (eg. . transmission.conf)
    SOURCE=/opt/share/torrent/source
    WORK=/opt/share/torrent/work
    TARGET=/opt/share/torrent/target
    #MAILTO=torrent@somedomain.com
    #MAILFROM=torrent@somedomain.com
    MAILOPT="-smail.somedomain.com -f"
    USER=admin
    GROUP=root
    DATE_FORMAT="%d %h %H:%M"
    # Transmission daemon variables
    PIDFILE=/opt/var/run/transmission.pid
    ACTIVE=/opt/share/torrent/active-torrents.txt
    HOME=/opt/share/torrent
    WATCHDOG=300
    LISTENING_PORT=65534
    # set SPEED in kB/s or -1 for unlimited
    UPLOAD_SPEED=10
    DOWNLOAD_SPEED=-1
    #UPLOAD_SPEED=41
    #DOWNLOAD_SPEED=180
    # change SYSLOG from /tmp/syslog.log to
    SYSLOG=/opt/var/log/messages
    #Uncomment the following for UPNP NAT traversal
    #NAT_TRAVERSAL=--nat-traversal
    # Seed torrent after completition (YES or NO)
    AUTOSEED="YES"
    # If the following limit is reached watchdog will not enqueue new one
    MAX_ACTIVE_TORRENTS=10
    # Creating graphical log of transfer with gnuplot
    # can be very site specific issue. See transmission.cgi
    # how this variables are used.
    GNUPLOT=/opt/bin/gnuplot
    GNUPLOT_COMMAND=${WORK}/transfer.gnuplot
    GNUPLOT_DATA=${WORK}/transfer.data
    GNUPLOT_OUTPUT=/opt/share/www/transfer.png
    HTTP_IMG_LOCATION=../transfer.png
    #TZ offset in seconds. Use +- sign. DST manually
    TIMEZONE_OFFSET=+3600
    #Colors for command line. # comment out if not needed
    GREEN="\033[32;1m"
    #NC="\033[0m"
    #BACK_UP="\033[1K\033[0G"
    NORMAL="\033[0m"
    WARN="\033[33;1m"
    BAD="\033[31;1m"
    BOLD="\033[1m"
    GOOD="\033[32;1m"
    my crontab file has the following:
    SHELL=/bin/sh
    PATH=/sbin:/bin:/usr/sbin:/usr/bin:/opt/bin:/opt/sbin:/opt/usr/bin:/opt/usr/sbin
    MAILTO=""
    HOME=/
    # ---------- ---------- Default is Empty ---------- ---------- #
    # Syntax for lines is : minute hour day month dayofweek command #
    */5 * * * * admin run-parts /opt/etc/cron.5mins
    01 * * * * admin run-parts /opt/etc/cron.hourly
    02 4 * * * admin run-parts /opt/etc/cron.daily
    22 4 * * 0 admin run-parts /opt/etc/cron.weekly
    42 4 1 * * admin run-parts /opt/etc/cron.monthly
    */30 * * * * admin nice /opt/sbin/transmission_watchdog
    my S05syslogd has the following:
     # Startup script for syslogd
     # Stop myself if running
     if [ -n "`pidof syslogd`" ]; then
       killall syslogd 2>/dev/null
    /sbin/syslogd -m 0 -O /opt/var/log/messages -S -l 7
    i put a .torrent file on the source directory, i force watchdog to start, then i select the .torrent file and make it active.
    The .torrent file is copied to the work directory, but the torrent does not start downloading.
    Here is my transmission.cgi page
    I also get errors on the log page and no graphic. Here is a image:
    So can please somebody tell me why is this not working
    I'm getting mad
    Talking Now Working
    I followed the German guide of wengi (with some help from babelfish) and now everything is working finally
    Now i need to find out how to create ftp accounts with different directory access...
    Feb 2005
    Germany - Frankfurt
    Seems that i have to do a translation... if i have the time.
    wengi
    Quote Originally Posted by wengi View Post
    wengi
    Yes, you should
    Now, my fight is with the ftp server. I found out the configuration file stupid-ftp.conf on the /etc folder.
    I made changes to this file, save it, saved the flash and rebooted.
    However, after the reboot the changes i made are gone and the file is equal to what it was
    How can this be?
    Help help
    Hi I followed the instructions and I get the following error trying to start transmissiond:
    Jun 15 22:09:19 transmission_watchdog: Transmission daemon restarted!
    Jun 15 22:09:19 transmissiond[546]: Transmission daemon 0.80-svn (1874) started - http://transmission.m0k.org/
    Jun 15 22:09:20 transmissiond[546]: chdir - No such file or directory
    Again and again and again.
    The .torrent files are located in the source directory. Work directoru contains 3 directories with the same name like the torrents files, but transfer.data is empty. The conf file seems OK. Transmission.cgi works fine.
    Any clue?
    Regards
    can you attach your transmission.conf file?
    HEre it's:
    # Configuration
    SOURCE=/tmp/harddisk/torrent/source
    WORK=/tmp/harddisk/torrent/work
    TARGET=/tmp/harddisk/torrent/target
    #MAILOPT="-smail.somedomain.com -f"
    USER=admin
    GROUP=root
    ACTIVE=/tmp/harddisk/torrent/active-torrents.txt
    HOME=/tmp/harddisk/torrent
    WATCHDOG=300
    UPLOAD_SPEED=10
    DOWNLOAD_SPEED=80
    #UPLOAD_SPEED=41
    #DOWNLOAD_SPEED=180
    DEBUG=1
    AUTOSEED="YES"
    MAX_ACTIVE_TORRENTS=5
    GREEN="\033[32;1m"
    #NC="\033[0m"
    NORMAL="\033[0m"
    WARN="\033[33;1m"
    BAD="\033[31;1m"
    BOLD="\033[1m"
    GOOD="\033[32;1m"
    AND the output of mount command:
    none on /dev type devfs (rw)
    proc on /proc type proc (rw)
    ramfs on /tmp type ramfs (rw)
    /dev/discs/disc0/part1 on /opt type ext3 (rw)
    /dev/discs/disc1/part2 on /tmp/harddisk type ext3 (rw,noatime)
    disc0 is a 2GB USB pen where is also configured 512MB of swap
    disc1 is a 500GB MAXTOR USB HD.
    Hi everyone.
    Probably the problem is HOME variable?
    Trnasmission points to /tmp/harddisk/torrent but admin user has it's own HOME pointing to /usr/local/root.
    Can I use another user to start Transmission?
    Regards
    Jun 2005
    Slovenia
    daemon should be started with transmission_watchdog. And there HOME is set to $WORK.
    Hi.
    I've changed the HOME to $WORK but it doesn't work. I've tried to run transmissiond manually with this results:;
    [admin@ASUS torrent]$ transmissiond HUP active-torrents.txt -v 1
    Remove /usr, it's in the way.
    With the command transmission_watchdog also doesn't work.
    Any idea?
    Also tried:
    [admin@ASUS torrent]$ export HOME=/tmp/harddisk/torrent/work
    Remove /tmp, it's in the way.
    What does it means? --> Remove /tmp, it's in the way.
    Hi everyone.
    I removed the actual release and I installed this release --> transmission_0.6+r1320-1_mipsel.ipk and everything works fine.
    2171 admin 1428 S transmissiond -p 65534 -w 300 -u -1 -d -1 -i /opt/var
    2174 admin 1428 S transmissiond -p 65534 -w 300 -u -1 -d -1 -i /opt/var
    2175 admin 1428 S transmissiond -p 65534 -w 300 -u -1 -d -1 -i /opt/var
    2176 admin 1428 S transmissiond -p 65534 -w 300 -u -1 -d -1 -i /opt/var
    2177 admin 1428 S transmissiond -p 65534 -w 300 -u -1 -d -1 -i /opt/var
    2178 admin 1428 S transmissiond -p 65534 -w 300 -u -1 -d -1 -i /opt/var
    2179 admin 1428 S transmissiond -p 65534 -w 300 -u -1 -d -1 -i /opt/var
    Could be a bug in release 0.7+r1874-1?
    Regards
    I have better one ----> [752]: Could not open file XD and sup with that shit?
    Jun 2005
    Slovenia
    Setting HOME externally does not help as the $HOME is set by transmission.conf
    Stating that Transmission does not work is too little evidence to comment anything. I can fix it if I see that it really does not work for me. By now there was not such case, but for others milestone my vary.
    Transmission Graph not working
    For some reason the graph in the log tab does not show anything. I have attached it. It just displays this every time i click log also i am not sure if my log i sclearing itself out or not because it still has logs from the Jun 18 till today. I don't know whats going as I am still trying to understand how this program works. Thanks in advance
    1.9.2.7-9
    Transmission daemon 1.22+ (6196)
  1. Understanding and debugging Transmission [oleo?]
    By wengi in forum WL-500gP Q&A
    Last Post: 05-08-2007, 09:36
  2. Transmission ... seltsame Effekte im WEBIF ...
    By Martin1802 in forum German Discussion - Deutsch (DE)
    Last Post: 24-05-2007, 12:29
  3. Torrentflux mod, controls Transmission - can someone package it?
    By nant15 in forum WL-500g Custom Development
    Last Post: 14-11-2006, 19:49
  4. Password won't work!
    By sjdigital in forum WL-HDD Q&A
    Last Post: 21-01-2006, 00:40
