I've just finished reading all posts here about giFT.
I successfully installed KCeasy and Gnutella/FastTrack plugins on a Win PC. All works fine, lot of nodes/files available. Then I installed ipkg-opts for gift, gift-opennap, gift-gnutella, gift-fasttrack on WL500gP. I've manually configured all .conf files for giFT and plugins. giFT daemon starts, I can access it using giFTcurs on WL500 or KCeasy from Win PC (using remote server cfg), all networks are still in "Connecting" status,
0 users, 0 files and ... nothing more...
Can someone post me some working .conf files for daemon and plugins please ?
I've also read that some files are wrong placed during installation, can someone please clarify this ?
All I really need is an OpenNap or SlavaNap client to use on WL500, I really don't need all these plugs, but I installed for test pourposes.
Is there available an alternative OpenNap client ?
Many thanks in advance.
Max
EDIT
From my gift.log:
[22:02:00] *** GIFT-ERROR:
Your version of the Gnutella plugin is more than 1 year
old. In order to protect the Gnutella network from
older programs, this plugin has deactivated itself.
Please update the plugin with a new version from
http://www.giftproject.org/, or stop running the
plugin by runnning gift-setup or removing "Gnutella"
from the /main/plugins line in $HOME/.giFT/giftd.conf
manually.
Thanks, and sorry for the inconvenience.
It seems that Gnutella plugins actually available as ipkg is out of date...
Max
