installed now, here more screenis
I upgraded last night.
+Cool new interface.
-Lost all WAN access.
?NFS works with tvix machines now? (Hopefully)
?BT downloads over 4GB work now?
Unfortunately trying to fix the internet access, I changed from Gateway to AP and now cannot access the router
Tonight will be spent debugging the problems I now have (Self inflicted)
hey guys, i got trouble uploading this new firmware....can´t do it via webinterface neither via firmware restauration....both it says there was an error...tryed to yank it out, press the ez button and tryed it again..didn´t work...well, got xp and put a static ip on it
any ideas?
It looks like I'm lucky. I was installed without any problem and it's working well.
Problem easily fixed. After factory reset to defaults, I just had to re-enter my dsl username/pw in the start setup "wizard" and I am back surfin the web.
I like this new firmware.
I will try NFS tonight. Keeping my finger crossed.
In the absence of the GPL code, has anyone tried the telnet hack on this?
http://wl500g.info/showpost.php?p=42807&postcount=1
LK
This new firmware looks cool. Can someone post step-by-step instructions on how to update to it for us dummies :-)
Can you also confirm all functionality, ie. Bittorrent, WiFi, is working?
Also, what about data on shares, is it necessary to backup data prior to firmware upgrade?
Regards,
D.
nobody an idea for my problem?
look here http://wl500g.info/showthread.php?t=6266
This firmware finally resolves, at least for me, the BT files. I can download torrents, it's slow but works.
I'm downloading a 4 Gb file. let's see if I have the old problems.
Installed, tested, perfect.
Performance still shit.
I lined up a 6 GB torrent last night and it appears that it created the 6 GB file, but I will not see until tonight if it ever started/completed/or where it has gotten to. Keeping my finger crossed.
