Wirless DNS problem
I have my WL500g (1.7.5.6) configured to access to internet via WAN port. I have 2 LAN clients configured in 192.168.1.* network, DHCP manual address according MAC. In the same range I have added Wireless client. All firewalls are disabled.
All clients (LAN, Wireless) get correct IP according MAC and DNS entries. LAN clients working perfectly but Wireless client can connect to internet only via direct IP because DNS is not working. Equivalent problem is connection to LAN in Microsoft Network/SAMBA.
It seems that responses to DNS server are cut off on router-router blocking UDF packets going to back Wireless, see log below.
Note: All firewals are disabled, I don't want two local networks 192.168.1 and 192.168.2 that is to configure when Wireless firewall is enabled.
DNS request dump when connected using LAN (OK):
683.40631365 nslookup.exe:208 8240F6C8 IRP_MJ_CREATE UDP:0.0.0.0:0 SUCCESS Address Open
683.40637651 nslookup.exe:208 8240F6C8 TDI_SET_EVENT_HANDLER UDP:0.0.0.0:2443 SUCCESS Error Event
683.40639690 nslookup.exe:208 8240F6C8 TDI_SET_EVENT_HANDLER UDP:0.0.0.0:2443 SUCCESS Datagram Receive Event
683.40641394 nslookup.exe:208 8240F6C8 TDI_SET_EVENT_HANDLER UDP:0.0.0.0:2443 SUCCESS ErrorEx Event
683.40642959 nslookup.exe:208 8240F6C8 TDI_QUERY_INFORMATION UDP:0.0.0.0:2443 SUCCESS Query Address
683.40646982 nslookup.exe:208 8240F6C8 TDI_CONNECT UDP:0.0.0.0:2443 80.250.1.161:53 SUCCESS
683.40651926 nslookup.exe:208 8240F6C8 TDI_SEND UDP:0.0.0.0:2443 80.250.1.161:53 SUCCESS Length:23
683.42904252 nslookup.exe:208 8240F6C8 TDI_EVENT_RECEIVE_DATAGRAM UDP:0.0.0.0:2443 80.250.1.161:53 SUCCESS Bytes taken: 80 Flags:
683.42910118 nslookup.exe:208 8240F6C8 TDI_SET_EVENT_HANDLER UDP:0.0.0.0:2443 80.250.1.161:53 SUCCESS Datagram Receive Event: NULL
683.42912074 nslookup.exe:208 8240F6C8 TDI_SET_EVENT_HANDLER UDP:0.0.0.0:2443 80.250.1.161:53 SUCCESS ErrorEx Event: NULL
683.42913778 nslookup.exe:208 8240F6C8 TDI_SET_EVENT_HANDLER UDP:0.0.0.0:2443 80.250.1.161:53 SUCCESS Error Event: NULL
683.42916013 nslookup.exe:208 8240F6C8 IRP_MJ_CLEANUP UDP:0.0.0.0:2443 SUCCESS
683.42917857 nslookup.exe:208 8240F6C8 IRP_MJ_CLOSE UDP:0.0.0.0:2443 SUCCESS
DNS request dump when connected via wireless (badly):
521.60782418 nslookup.exe:327 82484CC8 IRP_MJ_CREATE UDP:0.0.0.0:0 SUCCESS Address Open
521.60788452 nslookup.exe:327 82484CC8 TDI_SET_EVENT_HANDLER UDP:0.0.0.0:2430 SUCCESS Error Event
521.60790519 nslookup.exe:327 82484CC8 TDI_SET_EVENT_HANDLER UDP:0.0.0.0:2430 SUCCESS Datagram Receive Event
521.60792224 nslookup.exe:327 82484CC8 TDI_SET_EVENT_HANDLER UDP:0.0.0.0:2430 SUCCESS ErrorEx Event
521.60793788 nslookup.exe:327 82484CC8 TDI_QUERY_INFORMATION UDP:0.0.0.0:2430 SUCCESS Query Address
521.60797699 nslookup.exe:327 82484CC8 TDI_CONNECT UDP:0.0.0.0:2430 80.251.1.161:53 SUCCESS
521.60802700 nslookup.exe:327 82484CC8 TDI_SEND UDP:0.0.0.0:2430 80.251.1.161:53 SUCCESS Length:23
Can anybody help me? Thanks in advance. Maybe can help firmware upgrade but there is no available change log.
Tomas
Hmm, I'm no master in this, but shouldn't your wireless and LAN networks be in a different range like 192.168.1.x and 192.168.2.x? This is because both networks are NATted AFAIK.
But I think there is no reason not get UDF response when TCP works. I can connect to Google via http://216.239.57.99/. It seems there is an unplanned firewall Router->Wireless.
Note the same problem when I setup router as first DNS server (192.168.1.1).
please upgrade to a newer firmware
i'm using wireless and wired in the same subnet for years
it has always worked for me since I have the wl500g
I have upgraded firmware 1.7.9.5-CR5 and it's absolutely the same - UDP responses are blocked.
I even try setup wireless to the same range of address (192.168.1.*) - it's really nonsense and I had to reset router to factory defaults promptly.
Finally I try setup two networks 192.168.1.* as LAN and 192.168.2.* as WLAN. 2 DHPCs, all firewals disabled. In this configuration WLAN card don't receive any packet, XP wireless notification periodically announces new network and interface don't obtain IP, gateway and DNS.
Tomas
So I switched wireless firewall and DHCP again to previous state and WLAN connects to internet. It's probably neccesary trigger by enable/disable a config options to write to etc?.
Tomas
- You may not post replies
- You may not edit your posts
Forum Rules
