Gigabite
Model: WL500g
Firmware:1.9.2.7-7f (also tested with 1.9.2.7-7e)
Device: WORKING
Brandname: Gigabyte
Brandtype: GN-WI01GS
Driver: 1.1.2
Card type: MiniPCI
WLAN Connectivity inside: 54 Mbps very good reception.
Tested Encryptions: WEP (64 and 128bits), WPA-TKIP, WPA-AES, WPA2-TKIP, WPA2-AES
Computer OS: Microsoft Windows XP Pro SP2
URL to manufacturer : http://www.gigabyte.com.tw/
URL to product : http://www.gigabyte.com.tw/Products/...?ProductID=985
URL to chipset vendor : http://www.ralinktech.com/
Note : I'm not using the stock drivers, but those from Ralink. I had the best results with those. The card is fitted with a Ralink RT2501 Tubo chipset (RT61 + RT2500).
The Struggle Continues...
