Results 1 to 15 of 29
Thread: [WLAN] Wireless LAN Card PCMCIA/PCCARD
    Jan 2004
    Levanger, Norway
    Wireless LAN Card
    Tested @
    Model:WL-500g
    Firmware: 1.6.5.3
    Device: NOT WORKING!
    Brandname: Nokia
    Brandtype: D211
    Card Type: PC-Card (PCMCIA)
    WLAN Connectivity: 11 Mbps
    Computer OS: Microsoft Windows XP Pro
    Driver Version: 4.33 (English)
    URL To manufacturer: http://www.nokia.com
    URL To product: http://www.nokia.com/nfb/nD211.html
    Jan 2004
    Levanger, Norway
    Tested: WORKING!
    Model:WL-500g
    Firmware: 1.6.5.3
    Device
    Brandname: Cisco
    Brandtype: Aironet 350 Series
    Driver Version: 8.3.10.0
    URL To manufacturer: http://www.cisco.com
    URL To product: http://www.cisco.com/en/US/products/...448/index.html
    Jan 2004
    Levanger, Norway
    Tested: WORKING!
    Model:WL-500g
    Firmware: 1.6.5.3
    Device
    Brandname: Asus
    Brandtype: WL-100g
    WLAN Connectivity: 54 Mbps
    Computer OS: Microsoft Windows 98
    Driver Version: 1.8.2.8 (English)
    URL To manufacturer: http://www.asus.com
    URL To product: http://www.asus.com/products/communi...g/overview.htm
    Tested: WORKING!
    Model:WL-500g
    Firmware: 1.6.5.3
    Device
    Brandname: Kobishi
    Brandtype: Wireless LAN PCMCIA Card
    Driver Version: ??
    Tested: WORKING!
    Model:WL-500g
    Firmware: 1.6.5.3
    Device
    Brandname: Conceptronic
    Brandtype: C54i
    Card Type: PCI Card
    Driver Version: 1.0
    URL To manufacturer: http://www.conceptronic.net
    URL To product: http://www.conceptronic.net/product3.asp?g=9&p=*C54i
    Nokia D211
    Nokia D211 & Asus WL-500g works ok !!!!!!
    (Force WL-500g to 1-11Mbps)
    Wireless LAN Card
    Tested @
    Model:WL-500g
    Firmware: 1.6.5.3
    Device: WORKING!
    Brandname: Nokia
    Brandtype: D211
    Apple Airport Extreme
    Tested @
    Model:WL-500g
    Firmware: 1.6.5.3
    Device: WORKING!
    Brandname: Apple
    Brandtype: Airport Extreme
    Card Type: internal Card
    Computer OS: Mac OS X 10.3.2
    Driver Version: Airport 3.3
    URL To manufacturer: http://www.apple.com
    URL To product: http://www.apple.com/airport/
    Feb 2004
    Eindhoven
    Tested: Working
    Device: WLAN mini-PCI card
    Brandname: DELL TrueMobile 1300
    Brandtype: -
    URL To manufacturer: http://www.dell.com/
    Tested successfully in all encryption modes (WEP-128, WPA-PSK (TKIP and AES)
    Speed inside 7 meters area: 11-54 MBit/s
    Model: WL-500g
    Firmware: 1.6.5.3
    Tested @
    Model:WL-500g
    Firmware: 1.7.5.6
    Device: WORKING!
    Brandname: Dell
    Brandtype: TrueMobile 1300
    Card Type: Mini-PCI
    Tested in Dell Inspiron 8100 P3m-866 A15 BIOS
    Driver Version: A02
    LinkSys WCF-12 Compact Flash Card
    Tested: WORKING!
    Model:WL-500g
    Firmware: 1.7.5.6
    Device: WCF-12 Compact Flash Card
    Brandname: LinkSys
    Brandtype: WCF-12
    Card Type: CF Card
    Tested in Dell Axim x5 WM2003
    Computer OS: WM2003
    Driver Version:
    URL To manufacturer: http://www.linksys.com
    NB: With WEP enabled I had to set the Authentication Method to "Open or Shared Key" rather than just "shared key". Shared Key simply didn't work. "Open or shared key" With 64bit WEP worked fine.
    Completely Open with NO WEP Key also worked fine.
    Mar 2004
    Czech Republic, Europe
    Fujitsu Siemens CONNECT2AIR WLAN C-1100 CF
    Tested: WORKING!
    Model:WL-500g
    Firmware: 1.6.4.8
    Device
    Brandname: Fujitsu Siemens
    Brandtype: CONNECT2AIR WLAN C-1100 CF
    Card Type: CF (PC or PDA)
    URL To manufacturer: http://www.fujitsu-siemens.com
    URL To product: http://www.fujitsu-siemens.com/home/...0_cf_card.html
    Jan Lacina alias Laki
    Tested: WORKING!
    Model:WL-500g
    Firmware: 1.5.7.6 CR2
    Device 3CRWE154G72
    Brandname: 3COM
    Brandtype: OfficeConnect® Wireless 11g PC Card
    Card Type: PCMCIA
    Computer OS: Microsoft Windows 2000 Pro
    URL To manufacturer: http://www.3com.com
    URL To product:http://www.3com.com/prod/en_UK_EMEA/...ku=3CRWE154G72
    Sitecom WL-009 Wireless Network PC Card
    Tested: WORKING!
    Model:WL-500g
    Firmware: 1.7.5.6
    Device: Sitecom WL-009 Wireless Network PC Card
    Brandname: Sitecom
    Brandtype:WL-002/WL-009
    Card Type: PCMCIA Card
    Computer OS: XP Professional
    Driver Version:
    URL To manufacturer: http://www.sitecom.com
    NB: With WEP enabled I had to set the Authentication Method to "Open or Shared Key" rather than just "shared key". Shared Key simply didn't work. "Open or shared key" with 64bit WEP worked fine.
    Sitecom WL-012 USB Wireless adaptee
    Tested: WORKING!
    Model:WL-500g
    Firmware: 1.7.5.6
    Device: USB Wireless Adapter
    Brandname: Sitecom
    Brandtype: WL-012
    Computer OS: Windows XP Professional
    Driver Version:
    URL To manufacturer: http://www.sitecom.nl
    Thumbs up
    Tested @
    Model:WL-500g
    Firmware: 1.7.5.6
    Device: Intel 2200BG
    Brandname: Dell
    Brandtype: Intel 2200BG
    Card Type: Mini-PCI
    Tested in Dell Latitude D800
    Driver Version:
  1. PCI /PCMCIA wifi card with WMM( QoS) support
    By Antwerp in forum Dutch Discussion - Nederlands
    Last Post: 24-08-2005, 12:37
  2. wireless card cannot connect to WL-500G
    By mdn666 in forum WL-500g Q&A
    Last Post: 10-06-2005, 13:00
  3. Looking for PCMCIA CARD
    By britnet in forum WL-500g Q&A
    Last Post: 14-02-2005, 19:31
  4. Which PCcard works best with the WL-500G ?
    By gwl in forum WL-500g Q&A
    Last Post: 22-12-2004, 00:08
  5. [Wireless] Which PCI card works best with WL-500g?
    By Twofish in forum WL-500g Q&A
    Last Post: 04-09-2004, 00:50
