Решил usb винт заменить флешкой. Разметил, форматнул. После загрузки роутера получается вот что:
/tmp/local/root # fdisk -l
Disk /dev/scsi/host0/bus0/target0/lun0/disc: 2080 MB, 2080374784 bytes
64 heads, 62 sectors/track, 1024 cylinders
Units = cylinders of 3968 * 512 = 2031616 bytes
/dev/scsi/host0/bus0/target0/lun0/part1 1 1024 2031585 83 Linux
/tmp/local/root # mount
none on /dev type devfs (rw)
proc on /proc type proc (rw)
ramfs on /tmp type ramfs (rw)
/dev/discs/disc0/disc on /tmp/harddisk type vfat (rw,noatime)
/dev/discs/disc0/part1 on /tmp/harddisk/part1 type ext3 (rw,noatime)
Помогите разобраться с этой ерундистикой. что за хрень монтируется в /tmp/harddisk ?
В логе это:
Jan 1 03:00:08 kernel: SCSI subsystem driver Revision: 1.00
Jan 1 03:00:08 kernel: Initializing USB Mass Storage driver...
Jan 1 03:00:08 kernel: usb.c: registered new driver usb-storage
Jan 1 03:00:08 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Jan 1 03:00:08 kernel: Vendor: Flash Model: Drive AU_USB2.0 Rev: 8.07
Jan 1 03:00:08 kernel: Type: Direct-Access ANSI SCSI revision: 02
Jan 1 03:00:08 kernel: Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
Jan 1 03:00:08 kernel: SCSI device sda: 4063232 512-byte hdwr sectors (2080 MB)
Jan 1 03:00:08 kernel: sda: Write Protect is off
Jan 1 03:00:08 kernel: Partition check:
Jan 1 03:00:09 kernel: p1
Jan 1 03:00:09 kernel: USB Mass Storage support registered.
Jan 1 03:00:18 PPPoE: connect to ISP
Dec 22 06:59:06 kernel: VFS: Can't find ext3 filesystem on dev sd(8,0).
Dec 22 06:59:06 kernel: MSDOS FS: Using codepage 950
Dec 22 06:59:06 kernel: MSDOS FS: IO charset cp950
Dec 22 06:59:06 USB storage: vfat fs mounted to /tmp/harddisk
Dec 22 06:59:07 kernel: kjournald starting. Commit interval 5 seconds
Dec 22 06:59:07 kernel: EXT3 FS 2.4-0.9.19, 19 August 2002 on sd(8,1), internal journal
Dec 22 06:59:07 kernel: EXT3-fs: mounted filesystem with ordered data mode.
Dec 22 06:59:07 USB storage: ext3 fs mounted to /tmp/harddisk/part1
Dec 22 06:59:07 FTP server: daemon is started
Dec 22 06:59:16 ntp client: Synchronizing time with ru.pool.ntp.org ...
ЗЫ: Поиск юзал, ничего не нашел.
