Quote Originally Posted by JOCKYW2001
I will switch that annoying "feature" off and add a mount
:-) cool...
PS: the stick should not be formatted in fat, since I had to disable fat support in the kernel due to the fact that it didn't compile with fat support enabled ...
..oh, that could be a problem because I think most of us use a USB-Stick for Dataexchange...or will the stick be readable on any PC?
cu,
peter
