Results 1 to 2 of 2
Thread: Help to compile amule please
    Mar 2007
    Milano - Italy
    Finished my adventure with toolchain, now it's time to compile amule to run on WL-500gP.
    As I wrote in another thread, I successfully compiled aMule for Linux/Kubuntu, but I'm in trouble cross-compiling for WL-500:
    jars@jars-Kubuntu-7:/opt/slug/optware$ sudo make amule
    make wxbase-stage libstdc++-stage libcurl-stage zlib-stage libpng-stage libgd-stage readline-stage
    make[1]: Entering directory `/opt/slug/optware'
    make[1]: Nothing to be done for `wxbase-stage'.
    make[1]: Nothing to be done for `libstdc++-stage'.
    make[1]: Nothing to be done for `libcurl-stage'.
    make[1]: Nothing to be done for `zlib-stage'.
    make[1]: Nothing to be done for `libpng-stage'.
    make libpng-stage libjpeg-stage freetype-stage fontconfig-stage
    make[2]: Entering directory `/opt/slug/optware'
    make[2]: Nothing to be done for `libpng-stage'.
    make[2]: Nothing to be done for `libjpeg-stage'.
    make[2]: Nothing to be done for `freetype-stage'.
    make freetype-stage
    make[3]: Entering directory `/opt/slug/optware'
    make[3]: Nothing to be done for `freetype-stage'.
    make[3]: Leaving directory `/opt/slug/optware'
    make expat-stage
    make[3]: Nothing to be done for `expat-stage'.
    rm -rf /opt/slug/optware/builds/fontconfig /opt/slug/optware/builds/fontconfig
    tar -C /opt/slug/optware/builds -xzf /opt/slug/optware/downloads/fontconfig-2.3.2.tar.gz
    if test -n "" ; \
                    then cat  | \
                    patch -d /opt/slug/optware/builds/fontconfig -p1 ; \
    if test "/opt/slug/optware/builds/fontconfig" != "/opt/slug/optware/builds/fontconfig" ; \
                    then mv /opt/slug/optware/builds/fontconfig /opt/slug/optware/builds/fontconfig ; \
    (cd /opt/slug/optware/builds/fontconfig; \
                    AR=/opt/slug/optware/toolchain/mipsel-linux-uclibc/gcc-4.1.1-uclibc-0.9.28/bin/mipsel-linux-uclibc-ar AS=/opt/slug/optware/toolchain/mipsel-linux-uclibc/gcc-4.1.1-uclibc-0.9.28/bin/mipsel-linux-uclibc-as LD=/opt/slug/optware/toolchain/mipsel-linux-uclibc/gcc-4.1.1-uclibc-0.9.28/bin/mipsel-linux-uclibc-ld NM=/opt/slug/optware/toolchain/mipsel-linux-uclibc/gcc-4.1.1-uclibc-0.9.28/bin/mipsel-linux-uclibc-nm CC=/opt/slug/optware/toolchain/mipsel-linux-uclibc/gcc-4.1.1-uclibc-0.9.28/bin/mipsel-linux-uclibc-gcc CPP="/opt/slug/optware/toolchain/mipsel-linux-uclibc/gcc-4.1.1-uclibc-0.9.28/bin/mipsel-linux-uclibc-gcc -E" GCC=/opt/slug/optware/toolchain/mipsel-linux-uclibc/gcc-4.1.1-uclibc-0.9.28/bin/mipsel-linux-uclibc-gcc CXX=/opt/slug/optware/toolchain/mipsel-linux-uclibc/gcc-4.1.1-uclibc-0.9.28/bin/mipsel-linux-uclibc-g++ RANLIB=/opt/slug/optware/toolchain/mipsel-linux-uclibc/gcc-4.1.1-uclibc-0.9.28/bin/mipsel-linux-uclibc-ranlib STRIP=/opt/slug/optware/toolchain/mipsel-linux-uclibc/gcc-4.1.1-uclibc-0.9.28/bin/mipsel-linux-uclibc-strip \
                    CPPFLAGS="-O2   -pipe  -I/opt/slug/optware/staging/opt/include -I/opt/slug/optware/staging/opt/include/freetype2" \
                    LDFLAGS=" -L/opt/slug/optware/staging/opt/lib -Wl,-rpath,/opt/lib -Wl,-rpath-link,/opt/slug/optware/staging/opt/lib " \
                    PKG_CONFIG_PATH="/opt/slug/optware/staging/opt/lib/pkgconfig" \
                    PKG_CONFIG_LIBDIR="/opt/slug/optware/staging/opt/lib/pkgconfig" \
                    AUTOMAKE=automake-1.9 ACLOCAL=aclocal-1.9 \
                    ac_cv_prog_HASDOCBOOK=no \
                    ./autogen.sh \
                    --build=i386-pc-linux-gnu \
                    --host=mipsel-linux \
                    --target=mipsel-linux \
                    --prefix=/opt \
                    --with-default-fonts=/opt/share/fonts \
                    --without-add-fonts \
                    --with-freetype-config=/opt/slug/optware/staging/opt/bin/freetype-config \
                    --disable-docs \
                    --disable-static \
    You must have automake 1.4-p1 installed to compile Fontconfig.
    Get ftp://ftp.gnu.org/pub/gnu/automake/automake-1.4-p1.tar.gz
    (or a newer version if it is available)
    make[2]: *** [/opt/slug/optware/builds/fontconfig/.configured] Error 1
    make[2]: Leaving directory `/opt/slug/optware'
    make[1]: *** [/opt/slug/optware/builds/libgd/.configured] Error 2
    make[1]: Leaving directory `/opt/slug/optware'
    make: *** [/opt/slug/optware/builds/amule/.configured] Error 2
    Automake is correctly installed in Kubuntu, and it's reported as the latest version.
    Any help ?
    Thanks, Max
    Mar 2007
    Milano - Italy
    Problem solved replacing automake1.10 with automake 1.9.
    Amule correctly compiled.
    Max
  1. Need help to compile esniper
    By samoht in forum WL-500g Custom Development
    Last Post: 24-08-2010, 13:42
  2. How to compile Asus Source v1.9.7.0?
    By mik30 in forum WL-500gP Q&A
    Last Post: 04-06-2010, 23:44
  3. Help to compile toolchain please
    By QMax in forum WL-500gP Q&A
    Last Post: 15-10-2007, 13:30
  4. wl500gx custom appz, compile environment
    By gatsu in forum WL-500g Custom Development
    Last Post: 31-03-2007, 07:17
  5. How to compile c++
    By Elephantik in forum WL-500g Custom Development
    Last Post: 19-04-2006, 22:34
