I have the exact same problem ... have you found the solution to this ?
Hi!
I've installed unrar from ipkg, but i've got a problem. I allways get a message: "-sh: unrar: not found". Why!? What' wrong?
Can somebody help me?
same problem here. unrar doesn't work.. doesn't matter which version is installed..
some people have it working.. others don't..
ok ... there's some contradiction in what you say .... if some people got it working then it can work ... and if it can work I want to know how ????
that's right.. there's some contradiction..
I better should say: It stopped working for me.. 'cause it has worked, but it stopped. don't know why.. And I really didn't have the time to look into it.. Will do that later...
If any-1 has a solution in the meantime ? hehe
I can confirm it working, works fine on my wl-500gp with latest oleg version.
I had some problems as well with it some month ago, but after i did "ipkg upgrade" it startet working for me again, at least i think it was related to the upgrade.
hey... what package did you install exactly ? because "ipkg install unrar" didn't work for me ... I garbed a package off the web with wget and just installed that ... I think it was from this server:
http://ipkg.nslu2-linux.org/feeds/op.../cross/stable/
I used version 3.6.8-2..
Would the persons who have unrar working might be so kind to post their list of installed packages..
We might be able to see differences in packages with those who don't have it working.Code:ipkg list_installed
Thanks in advance.
ok here are my installed packages, quite a lot
hope it helps in any way
Code:ipkg list_installed abook - 0.5.6-1 - Abook is a text-based addressbook program designed to use with mutt mail client. adns - 1.4-1 - Asynchronous resolver library and DNS resolver utilities. audiofile - 0.2.6-6 - Misc Audio Libraries. avahi - 0.6.21-1 - A system for multicast DNS service discovery, an implementation of Zeroconf. bash - 3.2.17-1 - A bourne style shell bitchx - 1.1a-final-1 - Text mode IRC client bitlbee - 1.0.4-1 - A gateway between IRC and proprietary IM networks bsdmainutils - 6.1.6-1 - Small programs many people expect to find when they use a BSD-style Unix system. buildroot - 4.1.1-12 - uClibc compilation toolchain coreutils - 6.9-4 - Bunch of heavyweight *nix core utilities cyrus-sasl - 2.1.22-2 - Provides client or server side authentication (see RFC 2222). cyrus-sasl-libs - 2.1.22-2 - Provides client or server side authentication (see RFC 2222). dbus - 1.1.1-1 - enhanced-ctorrent - dnh2-3 - expat - 2.0.1-1 - XML Parser library faad2 - 2.5-3 - Freeware Advanced Audio Coder flac - 1.1.4-1 - FLAC is a free lossless audio codec. This package contains the codec libraries and the command-line tools flac and metaflac. fontconfig - 2.3.2-5 - Font configuration library freetype - 2.1.10-4 - Free truetype library gconv-modules - 2.2.5-7 - Provides gconv modules missing from the firmware. These are used by glibc's iconv() implementation. gdbm - 1.8.3-2 - GNU dbm is a set of database routines that use extensible hashing. It works similar to the standard UNIX dbm routines. gettext - 0.14.5-2 - Set of tools for producing multi-lingual messages glib - 2.6.6-6 - The GLib library of C routines. gnuplot - 4.2.0-5 - Command-line driven interactive data and function plotting utility gnutls - 1.6.3-1 - GNU Transport Layer Security Library. grep - 2.4.2-6 - Global regular expression parser groff - 1.19.2-1 - front-end for the groff document formatting system icecast - 2.3.1-1 - A free server software for streaming multimedia. ipkg-opt - 0.99.163-9 - The Itsy Package Manager less - 394-3 - Less file browser libao - 0.8.8-1 - Cross Platform Audio Library. libart - 2.3.17-2 - 2-d graphics library. libbt - 1.05-5 - a C library implementing the core BitTorrent protocol libcurl - 7.16.4-1 - libdaemon - 0.11-1 - A lightweight C library that eases the writing of UNIX daemons. libdb - 4.2.52-3 - Berkeley DB Libraries libevent - 1.3d-1 - libevent to implement an event loop libgcrypt - 1.2.4-1 - GNU cryptography libray, needed by gnutls libgd - 2.0.35-1 - An ANSI C library for the dynamic creation of images libgpg-error - 1.4-1 - Error handling library for libgcrypt libid3tag - 0.15.1b-1 - The library used for ID3 tag reading libjpeg - 6b-2 - collection of jpeg tools libmad - 0.15.1b-3 - MPEG Audio Decoder library libmpcdec - 1.2.6-1 - Portable Musepack decoder library. libogg - 1.1.3-3 - Ogg is a multimedia container format. libpng - 1.2.19-1 - libtasn1 - 0.3.10-1 - ASN.1 structure parser library. libuclibc++ - 0.2.2-4 - C++ standard library designed for use in embedded systems libvorbis - 1.1.2-5 - Ogg Vorbis compressed audio format. libvorbisidec - cvs-20050221-2 - libvorbisidec is the integer-only ogg decoder library, AKA Tremor libxml2 - 2.6.29-1 - libxslt - 1.1.21-1 - logrotate - 3.7.1-4 - Rotates, compresses, removes and mails system log files. man - 1.5p-4 - unix manual page reader mp3blaster - 3.2.3-2 - interactive text-based program that plays MP3, Ogg Vorbis, wav, and sid audio files mpc - 0.12.1-1 - A command line tool to interface MPD. mpd - 0.13.0-1 - Music Player Daemon (MPD) allows remote access for playing music. nano - 2.0.6-1 - A pico like editor nanoblogger - 3.3-3 - A small weblog engine written in Bash for the command line. ncmpc - 0.11.1-1 - A curses client for the Music Player Daemon (MPD). ncurses - 5.6-1 - NCurses libraries ncursesw - 5.6-1 - NCurses libraries with wide char support. netatalk - 2.0.3-2 - Apple talk networking daemon. nethack - 3.4.3-3 - The best text based RPG of all time. openssl - 0.9.7m-2 - Openssl provides the ssl implementation in libraries libcrypto and libssl, and is needed by many other applications and librari palantir - 2.6-1 - Multichannel interactive streaming solution pcre - 7.3-1 - Perl-compatible regular expression library popt - 1.7-2 - A C library for parsing command line parameters. readline - 5.2-2 - The GNU Readline library provides a set of functions for use by applications that allow users to edit command lines as they are rsync - 2.6.9-2 - sctcs - 0.85b - sed - 4.1.5-1 - Stream editor. snownews - 1.5.7-7 - Text mode RSS newsreader for Linux and Unix speex - 1.2beta1-1 - Speex is an Open Source/Free Software patent-free audio compression format designed for speech. tethereal - 0.10.14-3 - Terminal based ethereal to dump and analyze network traffic transmission - 0.82-1 - lightweight BitTorrent client and daemon with WWW interface uclibc-opt - 0.9.28-12 - micro C library for embedded Linux systems unrar - 3.6.8-2 - unrar is an application that can decompress files and archives created using the RAR compression scheme vnstat - 1.4-4 - Network traffic monitor with log wakelan - 1.1-2 - send the magic wakeup package over the LAN xinetd - 2.3.14-6 - Highly configurable, modular and secure inetd zlib - 1.2.3-2 - zlib is a library implementing the 'deflate' compression system.
could you also tell us where you got the package from ? unrar I mean ... btw: when I list the installed packages I don't get a description for unrar ... I only get:
unrar - 3.6.8-2 -
so it might be installed from a different package ?
All packages installed from
http://ipkg.nslu2-linux.org/feeds/op...g/cross/stable
Latest oleg firmware (7g)
SABnzbd running without unrar problems.Code:adduser - 1.5.0-1 - a multi-call binary for login and user account administration bash - 3.2.17-1 - A bourne style shell buildroot - 4.1.1-12 - uClibc compilation toolchain bzip2 - 1.0.4-1 - Very high-quality data compression program cron - 4.1-6 - Standard vixie cron, with cron.d addition e2fsprogs - 1.40.2-1 - Ext2 Filesystem Utilities freetype - 2.1.10-4 - Free truetype library glib - 2.6.6-6 - The GLib library of C routines. ipkg - 0.99.149-2 - ipkg-opt - 0.99.163-9 - The Itsy Package Manager libart - 2.3.17-2 - 2-d graphics library. libdb - 4.2.52-3 - Berkeley DB Libraries libjpeg - 6b-2 - collection of jpeg tools libpng - 1.2.19-1 - libuclibc++ - 0.2.2-4 - C++ standard library designed for use in embedded systems libusb - 0.1.12-1 - Library for interfacing to the USB subsystem. mc - 4.6.1-3 - Midnight Commander File Manager nano - 2.0.6-1 - A pico like editor ncurses - 5.6-1 - NCurses libraries ncursesw - 5.6-1 - NCurses libraries with wide char support. openssl - 0.9.7m-2 - Openssl provides the ssl implementation in libraries libcrypto and libssl, and is needed by many other applications and librari par2cmdline - 0.4-3 - tool to apply the data-recovery capability concepts of RAID-like systems to the posting & recovery of multi-part archives on Us py-celementtree - 1.0.5-20051216-4 - A toolkit that contains a number of light-weight components for working with XML (C implementation). py-cheetah - 2.0rc7-2 - Cheetah - The Python-Powered Template Engine. py-cherrypy - 2.2.1-2 - A pythonic, object-oriented web development framework. py-elementtree - 1.2.6-20050316-3 - A toolkit that contains a number of light-weight components for working with XML. python - 2.4.4-3 - This is a package that sets up the default python. python24 - 2.4.4-5 - Python is an interpreted, interactive, object-oriented programming language. readline - 5.2-2 - The GNU Readline library provides a set of functions for useby applications that allow users to edit command lines as they are rrdtool - 1.2.23-2 - Round-Robin Database tool. Database collator and plotter sane-backends - 1.0.18+cvs20061127-1 - SANE is a universal scanner interface slang - 2.1.1-1 - S-Lang is a multi-platform library designed to allow a developer to create robust multi-platform software. uclibc-opt - 0.9.28-12 - micro C library for embedded Linux systems unrar - 3.6.8-2 - unrar is an application that can decompress files and archives created using the RAR compression scheme unzip - 5.52-1 - A (de)compression library for the ZIP format xinetd - 2.3.14-6 - Highly configurable, modular and secure inetd zlib - 1.2.3-2 - zlib is a library implementing the 'deflate' compression system
Before installing buildroot, I downloaded it to router.
Solar inverter monitoring with Asus wl500gx http://solar.reinieren.net (dutch)
hi,
@sorin7486
my unrar tells the complete story other also have, however, unrar doesn't work for me.
When I run something with unrar, I always get the following error.
Code:terminate called after throwing an instance of 'int' Aborted
@Raas
Are you sure you're using the correct commands to run Unrar?
I ran a quick test for you:
As you see, I get the "aborted" message too, but only if I give unrar wrong, or no options/commands. Commands should be without a dash! ( - )Code:[myself@router2 tmp]$ UNRAR 3.60 freeware Copyright (c) 1993-2006 Alexander Roshal Usage: unrar <command> -<switch 1> -<switch N> <archive> <files...> <@listfiles...> <path_to_extract\> <Commands> e Extract files to current directory l[t,b] List archive [technical, bare] p Print file to stdout t Test archive files v[t,b] Verbosely list archive [technical,bare] x Extract files with full path <Switches> - Stop switches scanning ad Append archive name to destination path ap<path> Set path inside archive av- Disable authenticity verification check c- Disable comments show cfg- Disable read configuration cl Convert names to lower case cu Convert names to upper case dh Open shared files ep Exclude paths from names ep3 Expand paths to full including the drive letter f Freshen files id[c,d,p,q] Disable messages ierr Send all messages to stderr inul Disable all messages kb Keep broken extracted files n<file> Include only specified file n@ Read file names to include from stdin n@<list> Include files in specified list file o+ Overwrite existing files o- Do not overwrite existing files or Rename files automatically ow Save or restore file owner and group p[password] Set password p- Do not query password r Recurse subdirectories sl<size> Process files with size less than specified sm<size> Process files with size more than specified ta<date> Process files modified after <date> in YYYYMMDDHHMMSS format tb<date> Process files modified before <date> in YYYYMMDDHHMMSS format tn<time> Process files newer than <time> to<time> Process files older than <time> ts<m,c,a>[N] Save or restore file time (modification, creation, access) u Update files v List all volumes ver[n] File version control vp Pause before each volume x<file> Exclude specified file x@ Read file names to exclude from stdin x@<list> Exclude files in specified list file y Assume Yes on all queries terminate called after throwing an instance of 'int' Aborted [myself@router2 tmp]$ unrar l logfile.rar UNRAR 3.60 freeware Copyright (c) 1993-2006 Alexander Roshal Archive logfile.rar Name Size Packed Ratio Date Time Attr CRC Meth Ver ------------------------------------------------------------------------------- logfile.csv 21 21 100% 05-09-07 01:03 ....... 479263E8 m0b 2.9 ------------------------------------------------------------------------------- 1 21 21 100% [myself@router2 tmp]$ unrar e logfile.rar UNRAR 3.60 freeware Copyright (c) 1993-2006 Alexander Roshal Extracting from logfile.rar Extracting logfile.csv OK All OK
Rarfile created with WinRar 3.41
@Mistraller..
yeah... stupid me.... made a big mistake when entering the parameters to unrar..
unrar is actually working in a telnet session.
then why is it not working for Sab.. or Hella...
I dont get it...
well..
figured it out
i used the post boot script.. to run a script which starts SAB or Hella (currently Hella... more stable)
but if it's started automatically directly after boot. the unrar package is not found.
however. when I start it manually after the boot it does find the package and then it unrars perfectly after download..
The prettiest thing of all is that this behaviour is written up on the first page off the SAB tutorial.. stupid me.. /me should do better reading..
