Please Read the manual!
Your disk is the bottleneck! Most 2,5"are not fast enough to transfer the date!
NOTE: 100Mbit/sec network = 12,5Megabytes/sec.
The USB = USB 1.1 (not fast USB 2)
at first:sorry for bad english
i have some problems with my new wl-hdd:
1: only the orange Led for Networkspeed is burning/flashing but it's connectet to a 10/100 Switch which always shows a 100 Mbit connection...but the real speed is very slow...ca 20Mbit max.
2: the auto copy function for usb-sticks is horrible...after a long time (for a 128MB USB-Stick) i have 18/36 Partitions/Folders but only one has all the data...the other folders are filled with garbage...filenames/empty Folders.
3: is it possible to mount a USB-Device directly w/o that copy-function
cu,
peter
i have that http://www.baber.com/drives/internal...1gas_specs.htm one.Originally Posted by funsje
..i know that..i only have 2 Megabyte/sec...wired connection with 100Mbit Switch...NOTE: 100Mbit/sec network = 12,5Megabytes/sec.
..and therefore i'll get 18/36 folders with garbage? i dn't not worry about the USB-Speed...there must be something wrong in my opinion...The USB = USB 1.1 (not fast USB 2)
cu,
peter
About the actual speed, about a year ago I bought a very nice system with two 80 GB Seagate SATA disks. Supplier installed Suse 7.x and also Serial ATA support which wasn't included in the SUSE distro at that time. When I did a hpdarm -T I got only 2Mb/s. (PIO4 I think) I found out the thing required a number hdparm and other settings to get normal r/w speed results for this config. You may be facing a similar problem with the WL-HDD.Originally Posted by petgun
Perhaps you can check your disk speed with hdparm -Tt or something like that and see what you get
Brubber
WL-500g, WL-138g, WL-160g
AFAIK using hdparm isn't possible as the usb-storage driver presents every connected disk as SCSI device.
hi,
sorry, i am a little bit confused about the answer...we are talking about the HD _inside_ the WL-HDD not about a external USB-Storage Device....AFAIK there is only a automatc copy function (which i don't like) for connected USB-Sticks/USB-HD/???? wich dosen't work properly in my opinion.Originally Posted by wtzm
At the moment i think the firmware 1.1.2.2 is very buggy....and i wait for a new one...
cu,
peter
Well, yes, my comment was only related to external usb-hdds.Originally Posted by petgun
You could also take a look at /proc/ide/hda/settings to find out if dma is enabled for your disk (if hdparm isn't available on the wl-hdd).
hi,
thank you. i'll try that tonight...i hope that's possible with the WL-HDD Hardware...a Promise DMA HD Controller alone is not enough...is there a circuit diagram availiable ?Originally Posted by wtzm
cu,
peter
PS:
the path was /proc/ide/ide0/hda/settings
and 'using_dma' was set to 1. Are the ohter values ok?Code:name value min max mode ---- ----- --- --- ---- acoustic 0 0 254 rw address 0 0 2 rw bios_cyl 116280 0 65535 rw bios_head 16 0 255 rw bios_sect 63 0 63 rw breada_readahead 8 0 255 rw bswap 0 0 1 r current_speed 66 0 69 rw failures 0 0 65535 rw file_readahead 124 0 16384 rw ide_scsi 0 0 1 rw init_speed 66 0 69 rw io_32bit 1 0 3 rw keepsettings 0 0 1 rw lun 0 0 7 rw max_failures 1 0 65535 rw max_kb_per_request 128 1 255 rw multcount 16 0 16 rw nice1 1 0 1 rw nowerr 0 0 1 rw number 0 0 3 rw pio_mode write-only 0 255 w slow 0 0 1 rw unmaskirq 0 0 1 rw using_dma 1 0 1 rw wcache 0 0 1 rw
Seems to me it's set to ATA33. If you get 20 Mb/s I think that's OK with this setting
You may want to set init_speed to 69 (ATA100) if your HD supports this speed (would be hdparm -X69)
You may also try to increase your breada_readahead to 16 (do not set higher then multcount)
Changing the max_kb_per_request settings also may improve speed for some disks (try 15)
Brubber
hm.. okOriginally Posted by brubber
is there another way than using hdparm? (this is not default on the wl-hdd, also the full busybox doesn't carry it)
thank you! I'll try that tonight, but i fear that it won't boost the performance....i think the bottleneck is the Network/CIFS/Samba/buggy Firmware....if i try to write a testfile via the Backdoor cmdline from /dev/zero to the mounted Device the WL-HDD goes to Nirwana :-(Originally Posted by brubber
cu,
peter
Any results on the speed tests yet? I'm curious about the r/w speeds when using Samba or FTP. Ethernet allows for a maximum of 12 MB/s, but will the WL-HDD match this? There are 2.5" HDD capable of 12 MB/s sustained (average) throughput around and 3.5" disks, ofcourse, are way beyond that. It is interesting if the WL-HDD is capable of handling such amounts of data...
The WL-500g reaches only about 600 KB/s which is not enough to stream DIVX video for example.
