Results 1 to 5 of 5
Thread: Speed of moving external USB data to IDE WL700ge
    Hi there,
    I am new here and glad to know that so many ppl are using the enhanced firmware on their Asus.
    The HDD spin down is really a plus to me as it is so so hot if it continues to run.
    My question is it takes like 15 - 20 minutes to move a 700MByte file from the external USB2.0 harddrive to the internal IDE. I have used the file explorer (drive x: to drive y and also use "cp -r path1 path2", both yield the "slow" speed.
    How could I know if my USB2.0 drive really get connected as USB2.0 and not USB1.1 ? Will that be the reason of the slowness ?
    Thks in advance for any idea.
    Rgds,
    wwong
    That's *very* slow. My internal HDD is raided to my external USB drive. The external USB HDD also contains a temporary share. Copying a 700'ish MB file from the temp share to the internal raided share took around 2.75 minutes:
    [kfurge@WL700gE]$ ls -l data.bin
    -rw-r--r-- 1 kfurge 42000 719187968 Mar 7 2005 data.bin
    [kfurge@WL700gE]$ time cp data.bin /shares/MYVOLUME1/MYSHARE1/tmp
    real 2m41.997s
    user 0m0.820s
    sys 1m29.360s
    This configuration should be slower than yours. Additionally, you should notice a dramatic speed difference between copying the file locally versus over a network share.
    - K.C.
    Hi Kfurge,
    Thks for looking into this.
    But I am really getting the "slow" result, using command line "cp external_usb internal_hd", I shall try to "time" the operation.
    For the time being, what should I check, such as is the USB drive being recognised as USB 2.0 device ?
    Thks
    I'd recommend trying different combinations of USB ports, cables, and HDDs to try and narrow down the problem.
    - K.C.
    Hi kfurge,
    Will do, thks for your suggestion.
    William
    Last Post: 14-03-2012, 16:28
  2. Unstable boot from USB
    Last Post: 20-08-2008, 16:19
  3. WL500g 2 USB Drucker und ein LPT
    By Trebron in forum German Discussion - Deutsch (DE)
    Last Post: 28-01-2006, 00:48
  4. Wl500g > 2 USB and 1 LPT Printer
    By Trebron in forum WL-500g Q&A
    Last Post: 27-01-2006, 23:17
  5. WL-HDD copy data TO a USB Card Reader?
    By cominss in forum WL-HDD Q&A
    Last Post: 29-04-2005, 19:07
