Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
Thread: Netatalk for Apple Shares?
    How can I edit the Samba config file in System Command?
    I can only view it using cat /etc/smb.conf but I'm not able to edit it.
    Please help me someone.
    Thanks
    Quote Originally Posted by blaeberries View Post
    Rather than have Your Mac send unencrypted passswords, edit your samba config to allow encrypted passwords.
    $ nano /etc/smb.conf
    $ cat /etc/smb.conf
    [global]
    interfaces = br0
    bind interfaces only = yes
    workgroup = Workgroup
    server string = WLHDD
    guest account = nobody
    security = share
    browseable = yes
    guest ok = yes
    guest only = yes
    log level = 1
    max log size = 100
    encrypt passwords = yes
    preserve case = yes
    short preserve case = yes
    [share]
    path = /opt/share/share
    writable = yes
    force user = admin
    $ flashfs save && flashfs commit && flashfs enable
    i do it as you suggest in your post and it works great but after reboot it still goes to encrypt passwords = no and i have to edit the file every time. it seems that this saving to router flash doesn't work!! somebody suggested to add a line to /use/local/.files pointing to /etc/smb.conf and it dosn't work as well after restart.
    what am i doing wrong?
    Feb 2011
    Waw/PL
    What would be steps before this solution (described below) on fresh install of Olegs firmware (1.9.2.7-d-r2624) ?
    1. I understand that I would attach usb flash or usb hdd formated in ext3? How big should this drive/partition be ?
    2. As what share shall I mount it? /opt ? Is /opt the full track I should use for ounting?
    3. What packages should I install prior to avahi ? Eg. ipkg ? On my system I can find only ipkg.sh - is it ok?
    4. At what stage i do flash commit?
    Samba and OSX Lion - no more file sharing
    Hello,
    In new OSX Lion they have changed samba service and the one configured acording to wengi's tutorial no longer works. The native solution for OSX sharing is netatalk. I have installed it with ipkg but I have no clue how to configure it to make it work and start automatically after restart? Some users suggest to add something like a bonjour deamon call avahi, which after install does't start (it says there is no user).
    So my question is:
    1) is it possible to configure samba to work with OSX Lion (on the router side)
    2) if not, anybody managed to set afp (netatalk) file sharing for OSX
  1. Shares disk (Samba) afschermen met firewall.
    By Ikke in forum Dutch Discussion - Nederlands
    Last Post: 15-01-2007, 12:18
  2. Can't delete shares/ erase disk
    By dome in forum WL-700g Q&A
    Last Post: 03-01-2007, 20:40
  3. Replies: 0
    Last Post: 28-10-2006, 11:29
  4. Edit Samba Shares
    By Chellenger in forum WL-500g Q&A
    Last Post: 19-03-2006, 20:47
  5. Samba shares only accessable from LAN
    By Arnoldm in forum WL-500g Q&A
    Last Post: 28-03-2005, 08:26
