Mar 6 11:53:29 kernel: hub.c: new USB device 01:03.2-1, assigned address 2
Mar 6 11:53:29 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Mar 6 11:53:29 kernel: Vendor: C-ONE Model: 128MB Tiny Rev: 2.00
Mar 6 11:53:29 kernel: Type: Direct-Access ANSI SCSI revision: 02
Mar 6 11:53:29 kernel: Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
Mar 6 11:53:29 kernel: SCSI device sda: 256000 512-byte hdwr sectors (131 MB)
Mar 6 11:53:29 kernel: sda: Write Protect is off
Mar 6 11:53:29 kernel: Partition check:
Mar 6 11:53:29 kernel: p1 p2 p3 p4
Mar 6 11:53:31 kernel: VFS: Can't find ext3 filesystem on dev sd(8,0).
Mar 6 11:53:31 kernel: MSDOS FS: Using codepage 852
Mar 6 11:53:31 kernel: MSDOS FS: IO charset cp852
Mar 6 11:53:31 USB storage: vfat fs mounted to /tmp/harddisk
Mar 6 11:54:06 kernel: usb_control/bulk_msg: timeout
Mar 6 11:54:21 kernel: usb_control/bulk_msg: timeout
Mar 6 11:54:26 kernel: usb_control/bulk_msg: timeout
Mar 6 11:54:31 kernel: usb_control/bulk_msg: timeout
Mar 6 11:54:36 kernel: usb_control/bulk_msg: timeout
Mar 6 11:54:41 kernel: usb_control/bulk_msg: timeout
Mar 6 11:54:46 kernel: usb_control/bulk_msg: timeout
Mar 6 11:54:51 kernel: usb_control/bulk_msg: timeout
Mar 6 11:54:56 kernel: usb_control/bulk_msg: timeout
Mar 6 11:55:01 kernel: usb_control/bulk_msg: timeout
Mar 6 11:55:06 kernel: usb_control/bulk_msg: timeout
Mar 6 11:55:11 kernel: usb_control/bulk_msg: timeout
Mar 6 11:55:11 kernel: scsi: device set offline - not ready or command retry failed after bus reset: host 0 channel 0 id 0 lun 0
Mar 6 11:55:11 kernel: SCSI disk error : host 0 channel 0 id 0 lun 0 return code = 70000
Mar 6 11:55:11 kernel: I/O error: dev 08:01, sector 2
Mar 6 11:55:11 kernel: I/O error: dev 08:00, sector 504
Mar 6 11:55:11 kernel: I/O error: dev 08:00, sector 548
Mar 6 11:55:11 kernel: I/O error: dev 08:00, sector 4
Mar 6 11:55:11 kernel: I/O error: dev 08:00, sector 254
Mar 6 11:55:11 kernel: EXT3-fs: unable to read superblock
Mar 6 11:55:11 kernel: Directory sread (sector 0x1f8) failed
Mar 6 11:55:12 kernel: I/O error: dev 08:00, sector 4
Mar 6 11:55:12 kernel: bread in fat_access failed
Mar 6 11:55:12 kernel: I/O error: dev 08:00, sector 504
Mar 6 11:55:12 kernel: Directory sread (sector 0x1f8) failed
Mar 6 11:55:12 FTP server: daemon is started
Mar 6 11:55:16 kernel: usb_control/bulk_msg: timeout
Mar 6 11:55:21 kernel: usb_control/bulk_msg: timeout
Mar 6 11:55:44 kernel: I/O error: dev 08:00, sector 505
Mar 6 11:55:44 kernel: I/O error: dev 08:00, sector 552
