Jan 1 01:00:07 kernel: Partition check:
Jan 1 01:00:07 kernel: p1 p2 p3
Jan 1 01:00:07 kernel: USB Mass Storage support registered.
Jan 1 01:00:13 kernel: kjournald starting. Commit interval 5 seconds
Jan 1 01:00:13 kernel: EXT3 FS 2.4-0.9.19, 19 August 2002 on sd(8,2), internal journal
Jan 1 01:00:13 kernel: EXT3-fs: recovery complete.
Jan 1 01:00:13 kernel: EXT3-fs: mounted filesystem with ordered data mode.
Jan 1 01:00:13 kernel: Adding Swap: 506008k swap-space (priority -1)
Jan 1 01:00:13 System log daemon exiting.
Jan 1 01:00:13 syslogd started: BusyBox v1.1.3
Jan 1 01:00:14 /opt/sbin/cron[134]: (CRON) STARTUP (V5.0)
Jan 1 01:00:14 xinetd[140]: xinetd Version 2.3.14 started with no options compi led in.
Jan 1 01:00:14 xinetd[140]: Started working: 1 available service
Jan 1 01:00:16 kernel: MSDOS FS: Using codepage 950
Jan 1 01:00:16 kernel: MSDOS FS: IO charset cp950
Jan 1 01:00:16 kernel: FAT: bogus logical sector size 64543
Jan 1 01:00:16 kernel: VFS: Can't find a valid FAT filesystem on dev 08:00.
Jan 1 01:00:16 kernel: FAT: freeing iocharset=cp950
Jan 1 01:00:16 kernel: VFS: Can't find ext3 filesystem on dev sd(8,1).
Jan 1 01:00:16 kernel: FAT: bogus logical sector size 0
Jan 1 01:00:16 kernel: VFS: Can't find a valid FAT filesystem on dev 08:01.
Aug 19 10:52:54 kernel: kjournald starting. Commit interval 5 seconds
Aug 19 10:52:54 kernel: EXT3-fs warning: maximal mount count reached, running e2 fsck is recommended
Aug 19 10:52:54 kernel: EXT3 FS 2.4-0.9.19, 19 August 2002 on sd(8,3), internal journal
Aug 19 10:52:54 kernel: EXT3-fs: recovery complete.
Aug 19 10:52:54 kernel: EXT3-fs: mounted filesystem with ordered data mode.
Aug 19 10:52:54 USB storage: ext3 fs mounted to /tmp/harddisk
Aug 19 10:53:04 ntp client: Synchronizing time with time.nist.gov ...
Aug 19 11:00:01 /opt/sbin/cron[605]: (admin) CMD (nice /opt/sbin/transmission_wa tchdog)
Aug 19 11:00:07 transmissiond[636]: Transmission daemon 0.72Z (r2474) started -
http://transmission.m0k.org/
Aug 19 11:00:07 transmission_watchdog: Transmission daemon restarted!
Aug 19 11:00:07 transmissiond[636]: chdir - No such file or directory
Aug 19 11:25:03 dropbear[643]: pubkey auth succeeded for 'admin' with key md5 34 :64:16:58:66:5b:9e:83:c6:e2:7d:6d:f2:23:2d:40 from ::ffff:192.168.1.252:49787
Aug 19 11:26:22 transmission_watchdog: Transmission daemon restarted!
Aug 19 11:26:22 transmissiond[682]: Transmission daemon 0.72Z (r2474) started -
Aug 19 11:26:22 transmissiond[682]: chdir - No such file or directory
