Results 1 to 7 of 7
Thread: Firmware v9.8.1.9 BETA
    Nov 2003
    Eindhoven
    WARNING: BETA VERSION
    TRY AT YOUR OWN RISK!
    DO NOT UPGRADE UNLESS YOU KNOW WHAT YOU ARE DOING
    DOWNGRADE IS NOT EASILY POSSIBLE!!
    Changelog:
    nothing known yet
    WL500g_9.8.1.9_EN.zip
    i do not know the differences, normally this should be the beta of firmware 1.8.1.9 allthough it's out already !? but this one came later
    Well, this seems to be 1.8.1.9 based build, but with debug information turned on in the et driver. I guess, this should aim in tracking down WAN port die problem. So, everyone with 1.8.1.9 and having WAN problem, which can be workaround by renewing DHCP lease should try to flash this firmware and check the system log. It should contain debug info (if it does not - probably Asus has forgotted something). You then should kill your WAN port and copy the system log BEFORE rebooting/renewing lease. Post it here. I will try to check for any hints on problem.
    Also, just an idea - if it does not contain any debug info - try running
    dmesg
    via well known www backdoor.
    Nov 2003
    Eindhoven
    about the QOS stuff:
    found this in my nvram values:
    qos_enable_x=0
    qos_ipaddr_x=
    qos_priority_x=
    qos_maxbw_x=
    qos_dir_x=
    qos_minbw_x=
    qos_port_x=
    qos_rulenum_x=0
    see also pic attached
    Nov 2003
    Eindhoven
    system log
    Jan 1 00:00:01 klogd: CPU revision is: 00024000
    Jan 1 00:00:01 klogd: Loading BCM4710 MMU routines.
    Jan 1 00:00:01 klogd: Primary instruction cache 8kb, linesize 16 bytes (2 ways)
    Jan 1 00:00:01 klogd: Primary data cache 4kb, linesize 16 bytes (2 ways)
    Jan 1 00:00:01 klogd: Linux version 2.4.20 (root@localhost.localdomain) (gcc version 3.2.3 with Broadcom modifications) #124 Wed Sep 1 15:16:17 CST 2004
    Jan 1 00:00:01 klogd: Determined physical RAM map:
    Jan 1 00:00:01 klogd: memory: 01000000 @ 00000000 (usable)
    Jan 1 00:00:01 klogd: On node 0 totalpages: 4096
    Jan 1 00:00:01 klogd: zone(0): 4096 pages.
    Jan 1 00:00:01 klogd: zone(1): 0 pages.
    Jan 1 00:00:01 klogd: zone(2): 0 pages.
    Jan 1 00:00:01 klogd: Kernel command line: root=/dev/mtdblock2 noinitrd console=ttyS0,115200
    Jan 1 00:00:01 klogd: CPU: BCM4710 rev 0 at 125 MHz
    Jan 1 00:00:01 klogd: !unable to setup serial console!
    Jan 1 00:00:01 klogd: Calibrating delay loop... 82.94 BogoMIPS
    Jan 1 00:00:01 klogd: Memory: 14228k/16384k available (1448k kernel code, 2156k reserved, 208k data, 64k init, 0k highmem)
    Jan 1 00:00:01 klogd: Dentry cache hash table entries: 2048 (order: 2, 16384 bytes)
    Jan 1 00:00:01 klogd: Inode cache hash table entries: 1024 (order: 1, 8192 bytes)
    Jan 1 00:00:01 klogd: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
    Jan 1 00:00:01 klogd: Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Jan 1 00:00:01 klogd: Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
    Jan 1 00:00:01 klogd: Checking for 'wait' instruction... unavailable.
    Jan 1 00:00:01 klogd: POSIX conformance testing by UNIFIX
    Jan 1 00:00:01 klogd: PCI: Fixing up bus 0
    Jan 1 00:00:01 klogd: PCI: Fixing up bridge
    Jan 1 00:00:01 klogd: PCI: Fixing up bus 1
    Jan 1 00:00:01 klogd: Linux NET4.0 for Linux 2.4
    Jan 1 00:00:01 klogd: Based upon Swansea University Computer Society NET3.039
    Jan 1 00:00:01 klogd: Initializing RT netlink socket
    Jan 1 00:00:01 klogd: Starting kswapd
    Jan 1 00:00:01 klogd: devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
    Jan 1 00:00:01 klogd: devfs: boot_options: 0x1
    Jan 1 00:00:01 klogd: NTFS driver v1.1.22 [Flags: R/O]
    Jan 1 00:00:01 klogd: pty: 256 Unix98 ptys configured
    Jan 1 00:00:01 klogd: Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
    Jan 1 00:00:01 klogd: PPP generic driver version 2.4.2
    Jan 1 00:00:01 klogd: PPP Deflate Compression module registered
    Jan 1 00:00:01 klogd: PPP BSD Compression module registered
    Jan 1 00:00:01 klogd: Amd/Fujitsu Extended Query Table v1.1 at 0x0040
    Jan 1 00:00:01 klogd: Physically mapped flash: Swapping erase regions for broken CFI table.
    Jan 1 00:00:01 klogd: number of CFI chips: 1
    Jan 1 00:00:01 klogd: Flash device: 0x400000 at 0x1fc00000
    Jan 1 00:00:01 klogd: Physically mapped flash: cramfs filesystem found at block 1027
    Jan 1 00:00:01 klogd: Creating 4 MTD partitions on "Physically mapped flash":
    Jan 1 00:00:01 klogd: 0x00000000-0x00040000 : "pmon"
    Jan 1 00:00:01 klogd: 0x00040000-0x003f0000 : "linux"
    Jan 1 00:00:01 klogd: 0x00100f5c-0x003f0000 : "rootfs"
    Jan 1 00:00:01 klogd: 0x003f0000-0x00400000 : "nvram"
    Jan 1 00:00:01 klogd: sflash: chipcommon not found
    Jan 1 00:00:01 klogd: NET4: Linux TCP/IP 1.0 for NET4.0
    Jan 1 00:00:01 klogd: IP Protocols: ICMP, UDP, TCP
    Jan 1 00:00:01 klogd: IP: routing cache hash table of 512 buckets, 4Kbytes
    Jan 1 00:00:01 klogd: TCP: Hash tables configured (established 1024 bind 2048)
    Jan 1 00:00:01 klogd: ip_conntrack version 2.1 (128 buckets, 1024 max) - 344 bytes per conntrack
    Jan 1 00:00:01 klogd: ip_conntrack_pptp.c:init: ip_conntrack_pptp.c: registering helper
    Jan 1 00:00:01 klogd: ip_conntrack_pptp version 1.9 loaded
    Jan 1 00:00:01 klogd: ip_nat_pptp version 1.5 loaded
    Jan 1 00:00:01 klogd: ip_tables: (C) 2000-2002 Netfilter core team
    Jan 1 00:00:01 klogd: ipt_time loading
    Jan 1 00:00:01 klogd: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
    Jan 1 00:00:01 klogd: NET4: Ethernet Bridge 008 for NET4.0
    Jan 1 00:00:01 klogd: 802.1Q VLAN Support v1.7 Ben Greear reearb@candelatech.com>
    Jan 1 00:00:01 klogd: All bugs added by David S. Miller avem@redhat.com>
    Jan 1 00:00:01 klogd: VFS: Mounted root (cramfs filesystem) readonly.
    Jan 1 00:00:01 klogd: Mounted devfs on /dev
    Jan 1 00:00:01 klogd: Freeing unused kernel memory: 64k freed
    Jan 1 00:00:01 klogd: Warning: unable to open an initial console.
    Jan 1 00:00:01 klogd: eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 1.3.2.0
    Jan 1 00:00:01 klogd: eth1: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 1.3.2.0
    Jan 1 00:00:01 klogd: robosw_attach_ocp: no Robo device on OCP bus
    Jan 1 00:00:01 klogd: robosw_attach_pmii: no Robo switch detected
    Jan 1 00:00:01 klogd: Robo switch init failed
    Jan 1 00:00:01 klogd: unregister_netdevice: device eth2/802f7800 never was registered
    Jan 1 00:00:01 klogd: PCI: Enabling device 01:02.0 (0004 -> 0006)
    Jan 1 00:00:01 klogd: eth2: Broadcom BCM4320 802.11 Wireless Controller 1.3.2.0
    Jan 1 00:00:01 klogd: Algorithmics/MIPS FPU Emulator v1.5
    Jan 1 00:00:01 klogd: device eth0 entered promiscuous mode
    Jan 1 00:00:01 klogd: device eth2 entered promiscuous mode
    Jan 1 00:00:01 klogd: br0: port 2(eth2) entering listening state
    Jan 1 00:00:01 klogd: br0: port 1(eth0) entering listening state
    Jan 1 00:00:01 klogd: br0: port 2(eth2) entering learning state
    Jan 1 00:00:01 klogd: br0: port 1(eth0) entering learning state
    Jan 1 00:00:01 klogd: br0: port 2(eth2) entering forwarding state
    Jan 1 00:00:01 klogd: br0: topology change detected, propagating
    Jan 1 00:00:01 klogd: br0: port 1(eth0) entering forwarding state
    Jan 1 00:00:01 klogd: usb.c: registered new driver usbdevfs
    Jan 1 00:00:01 klogd: usb.c: registered new driver hub
    Jan 1 00:00:02 klogd: usb-ohci.c: USB OHCI at membase 0xb8004000, IRQ 2
    Jan 1 00:00:02 klogd: usb-ohci.c: usb-00:04.0, PCI device 14e4:4715
    Jan 1 00:00:02 klogd: usb.c: new USB bus registered, assigned bus number 1
    Jan 1 00:00:02 klogd: hub.c: USB hub found
    Jan 1 00:00:02 klogd: hub.c: 2 ports detected
    Jan 1 00:00:02 klogd: uhci.c: USB Universal Host Controller Interface driver v1.1
    Jan 1 00:00:02 klogd: lp0: using parport0 (polling).
    ------CUT------
    download attachment for full systemlog
    Well, that's the relevant part -
    Sep  5 01:13:20  klogd: A1 1 1 0 1
    Sep  5 01:13:21  klogd: A1 1 1 0 2
    Sep  5 01:13:24  klogd: A1 1 1 0 1
    Sep  5 01:13:25  klogd: A1 1 1 0 2
    Sep  5 01:13:26  klogd: A1 1 2 0 3
    Sep  5 01:13:26  ntp client: time is synchronized to time.nist.gov
    Sep  5 01:13:32  klogd: A1 1 1 0 1
    Sep  5 01:13:33  klogd: A1 1 1 0 2
    Sep  5 01:13:34  klogd: A1 1 2 0 3
    Sep  5 01:13:35  klogd: A1 1 2 0 4
    Sep  5 01:13:35  klogd: EEEE: RESET
    Sep  5 01:13:46  klogd: A1 1 6 0 1
    Sep  5 01:13:47  klogd: A1 1 17 0 2
    Sep  5 01:13:48  klogd: A1 1 18 0 3
    Sep  5 01:13:49  klogd: A1 1 18 0 4
    Sep  5 01:13:49  klogd: EEEE: RESET
    Sep  5 01:14:02  klogd: A1 1 1 0 1
    Sep  5 01:14:03  klogd: A1 1 1 0 2
    Sep  5 01:14:04  klogd: A1 1 2 0 3
    Sep  5 01:14:05  klogd: A1 1 2 0 4
    Sep  5 01:14:05  klogd: EEEE: RESET
    Sep  5 01:14:16  klogd: A1 1 17 0 1
    Sep  5 01:14:17  klogd: A1 1 17 0 2
    Sep  5 01:14:18  klogd: A1 1 18 0 3
    Sep  5 01:14:19  klogd: A1 1 18 0 4
    Sep  5 01:14:19  klogd: EEEE: RESET
    Sep  5 01:14:30  klogd: A1 1 17 0 1
    Sep  5 01:14:31  klogd: A1 1 17 0 2
    This is something added by ASUS, but incomplete...
    Try running this line
    et -i eth1 msglevel 15
    This should not produce output, but should enable debug messages on. Also, have you tried dmesg?
    http://192.168.1.1/Advanced_QOS_Content.asp
    QoS web setting is also avalible at official version 1.8.1.9.
    but the whatever setting, no useful at all.
    my download or upload speed still can reach the maximum.
    how to use that?
    will ASUS fix that and release the new firmware include that?
    Nov 2003
    Eindhoven
    Quote Originally Posted by shopping
    how to use that?
    well it's not implemented so nothing to fix yet..
    probably it will be in one of the next versions..
  1. Firmware v1.9.3.9 BETA
    By Antiloop in forum WL-530g Firmware Releases
    Last Post: 04-06-2006, 13:38
  2. Firmware v1.9.3.6 BETA
    By Antiloop in forum WL-300g Firmware Releases
    Last Post: 18-11-2005, 09:49
  3. Firmware v1.9.3.6 BETA
    Last Post: 27-04-2005, 07:54
  4. Firmware v1.9.3.6 BETA
    By Antiloop in forum WL-500gx Firmware Releases
    Last Post: 20-03-2005, 02:40
  5. Firmware v1.7.5.7 BETA
    Last Post: 12-05-2004, 23:03
