Results 1 to 13 of 13
Thread: custom ftp
    custom ftp
    could somebody tell me how i can set up a custom ftp server on the wl-700?
    i have tried to follow this guide:
    http://www.macsat.com/macsat/content/view/25/29/
    but how do i set up the xinetd? and how do i get the custom ftp started with the rc.local?
    would be nice if somebody could help me!
    thanks
    grat182
    If you only want to reconfigure the existing ftp server, you don't need to run xinetd. Just add these lines to rc.local:
    killall vsftpd
    /sbin/vsftpd /opt/etc/vsftpd.conf &
    You can copy /etc/vsftpd.conf to /opt/etc/vsftpd.conf and customize as necessary for your setup.
    - K.C.
    Thanks Kfurge, this is what i was looking for.
    Sollie.
    thanks kfurge thats it...
    but i have one question:
    the vsftpd now starts with the opt/etc/vsftpd.conf
    i have copied the original asus vsftpd.conf from etc to opt/etc and i have modified nothing.
    but when i start the vsftpd with the opt/etc/vsftpd.conf i get the following error when i connect to the router:
    [R] 220 Welcome to the WL700gE FTP service.
    [R] USER myusername
    [R] /dev/nvram: No such file or directory
    [R] 331 Please specify the password.
    [R] PASS (hidden)
    [R] 230 Login successful.
    [R] SYST
    [R] 215 UNIX Type: L8
    [R] FEAT
    [R] 211-Features:
    [R] EPRT
    [R] EPSV
    [R] MDTM
    [R] ICNV
    [R] PASV
    [R] REST STREAM
    [R] SIZE
    [R] TVFS
    [R] 211 End
    [R] PWD
    [R] 257 "/"
    [R] TYPE A
    [R] 200 Switching to ASCII mode.
    [R] PASV
    [R] 227 Entering Passive Mode (192,168,1,1,133,31)
    [R] Opening data connection IP: 192.168.1.1 PORT: 34079
    [R] LIST -al
    [R] 150 Here comes the directory listing.
    [R] 226 Transfer done (but failed to open directory).
    [R] List Complete: 0 bytes in 0,05 seconds (0,0 KB/s)
    does somembody knows a solution?
    thanks
    grat182
    The error messages you're seeing are very interesting. A little investigation revealed that Asus has messed a little bit with the base vsftpd source code. They added code to check to see if the router is ubsa mode in a number of places by querying the nvram. For some reason the queries don't seem to be working for you.
    I tested a little bit further on my box and vsftpd works OK for me when started as root from the command line as shown.
    A few questions come to mind:
    Are you starting it as root? If you're starting if from rc.local can you try just starting it from a command line instead and see if it works better?
    Finally, it's wierd that it can't find /dev/nvram. Are you running it in a chrooted environment?
    - K.C.
    thanks for help kfurge.
    its started as root... (manually started) but its the same whith the rc.local
    631 root 688 S /sbin/vsftpd /opt/etc/vsftpd.conf
    what do you mean with that?
    i have only added the two things in the rc.local
    killall vsftpd
    i think i have a chrooted enivornment.
    2 weeks ago i have changed the permissions in the opt/home/username dir to chmod 755. because dropbear won't worked anymore. (and i hadn't changed the permissions earlier!) now dropbear works but i don't know if i made something wrong....
    grat182
  1. mount HDD without FTP?
    By reuzel in forum WL-500g Q&A
    Last Post: 17-01-2007, 08:08
  2. FTP in PBSA Mode - Possible??
    By Musk in forum WL-700g Q&A
    Last Post: 30-08-2006, 16:13
  3. Custom Firmware v1.1.2.7
    Last Post: 11-12-2004, 12:26
  4. How to get FTP workig on my WL500G
    By Driek in forum WL-500g Q&A
    Last Post: 20-10-2004, 20:03
