Results 1 to 4 of 4
Thread: Desperately searching for an external antenna
    Please, need help.
    For a long time now I am searching for an external directional antenna
    for my wl-300g. Something like you can find here: http://www.multimediacenter.nl/websh...=90-IAEAN1000- . Where can I order (e.g. in Germany) this antenna. Or at least an 'optional connection adapter RP-SMA' as mentioned so many times on the Asus Product pages (see http://de.asus.com/products.aspx?l1=...94&modelmenu=1 ).
    Your help will be appreciated.
    Quote Originally Posted by el_diablo View Post
    Please, need help.
    hi:
    i don't know the situation of Germany. but at taiwan i just call ASUS to order the
    adapter, and get it in the support center near by. the adapter cost about 10 US dollars. the adapter use to be out of stock. but it is on stream again now. so i think maybe you can get it in Germany now.
    Regards,
    tbsky
    Rp-sma
    Hah
    Thats sweet I want one of those too! if you find one please post it in this thread
    In norway i could just find this shit , not as cool as the white parabel
    @ Rp-sma: For the antenna above, it is just enough do buy an 'optional connection adapter RP-SMA', to connect it with the wl300g. With this adapter, it is possible to connect any standard wlan-antenna. But i even don't know, where to buy such an adapter. I can't understand, why ASUS has implemented such an exotic connection to that router...
  1. Replies: 5
    Last Post: 15-12-2008, 11:01
  2. External antenna connector
    By larsv in forum WL-300g Q&A
    Last Post: 14-11-2005, 14:35
  3. Wl-500g as an ap with external antenna?
    By san in forum WL-500g Q&A
    Last Post: 28-07-2005, 22:24
  4. Use of external antenna
    By Theo in forum WL-500g Q&A
    Last Post: 27-06-2005, 17:35
  5. External antenna: extension cable?
    By nigelmercier in forum WL-500g Q&A
    Last Post: 09-05-2004, 22:11
