Jan 1 10:00:03 syslogd started: BusyBox v1.1.3
Jan 1 10:00:03 kernel: 0x003f0000-0x00400000 : "nvram"
Jan 1 10:00:03 kernel: 0x003e0000-0x003f0000 : "flashfs"
Jan 1 10:00:03 kernel: sflash: found no supported devices
Jan 1 10:00:03 kernel: NET4: Linux TCP/IP 1.0 for NET4.0
Jan 1 10:00:03 kernel: IP Protocols: ICMP, UDP, TCP
Jan 1 10:00:03 kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
Jan 1 10:00:03 kernel: TCP: Hash tables configured (established 2048 bind 4096)
Jan 1 10:00:03 kernel: ip_conntrack version 2.1 (256 buckets, 2048 max) - 344 bytes per conntrack
Jan 1 10:00:03 kernel: ip_conntrack_pptp version 1.9 loaded
Jan 1 10:00:03 kernel: ip_nat_pptp version 1.5 loaded
Jan 1 10:00:03 kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 10:00:03 kernel: ipt_time loading
Jan 1 10:00:03 kernel: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Jan 1 10:00:03 kernel: IPv6 v0.8 for NET4.0
Jan 1 10:00:03 kernel: IPv6 over IPv4 tunneling driver
Jan 1 10:00:03 kernel: NET4: Ethernet Bridge 008 for NET4.0
Jan 1 10:00:03 kernel: 802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
Jan 1 10:00:03 kernel: All bugs added by David S. Miller <davem@redhat.com>
Jan 1 10:00:03 kernel: FAT: bogus logical sector size 62464
Jan 1 10:00:03 kernel: NTFS: Unable to set blocksize 512.
Jan 1 10:00:03 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 10:00:03 kernel: Mounted devfs on /dev
Jan 1 10:00:03 kernel: Freeing unused kernel memory: 72k freed
Jan 1 10:00:03 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 10:00:03 kernel: .90.37.0
Jan 1 10:00:03 kernel: PCI: Enabling device 01:03.0 (0004 -> 0006)
Jan 1 10:00:03 kernel: eth1: Broadcom BCM4320 802.11 Wireless Controller 3.90.37.0
Jan 1 10:00:03 kernel: vlan0: add 33:33:00:00:00:01 mcast address to master interface
Jan 1 10:00:03 kernel: vlan0: add 33:33:ff:92:08:33 mcast address to master interface
Jan 1 10:00:03 kernel: vlan0: dev_set_promiscuity(master, 1)
Jan 1 10:00:03 kernel: device eth0 entered promiscuous mode
Jan 1 10:00:03 kernel: device vlan0 entered promiscuous mode
Jan 1 10:00:03 kernel: device eth1 entered promiscuous mode
Jan 1 10:00:03 kernel: br0: port 2(eth1) entering listening state
Jan 1 10:00:03 kernel: br0: port 1(vlan0) entering listening state
Jan 1 10:00:03 kernel: br0: port 2(eth1) entering learning state
Jan 1 10:00:03 kernel: br0: port 1(vlan0) entering learning state
Jan 1 10:00:03 kernel: br0: port 2(eth1) entering forwarding state
Jan 1 10:00:03 kernel: br0: topology change detected, propagating
Jan 1 10:00:03 kernel: br0: port 1(vlan0) entering forwarding state
Jan 1 10:00:04 kernel: usb.c: registered new driver usbdevfs
Jan 1 10:00:04 kernel: usb.c: registered new driver hub
Jan 1 10:00:04 kernel: usb-uhci.c: $Revision: 1.275 $ time 10:25:12 Jun 17 2006
Jan 1 10:00:04 kernel: usb-uhci.c: High bandwidth mode enabled
Jan 1 10:00:04 kernel: PCI: Enabling device 01:02.0 (0000 -> 0001)
Jan 1 10:00:04 kernel: ECHI PCI device 30381106 found.
Jan 1 10:00:04 kernel: UCHI reg 0x41 = 10
Jan 1 10:00:04 kernel: UCHI reg 0x41 changed to = 0
Jan 1 10:00:04 kernel: usb-uhci.c: USB UHCI at I/O 0x100, IRQ 2
Jan 1 10:00:04 kernel: usb-uhci.c: Detected 2 ports
Jan 1 10:00:04 kernel: usb.c: new USB bus registered, assigned bus number 1
Jan 1 10:00:04 kernel: hub.c: USB hub found
Jan 1 10:00:04 kernel: hub.c: 2 ports detected
Jan 1 10:00:04 kernel: PCI: Enabling device 01:02.1 (0000 -> 0001)
Jan 1 10:00:04 kernel: usb-uhci.c: USB UHCI at I/O 0x120, IRQ 2
Jan 1 10:00:04 kernel: usb.c: new USB bus registered, assigned bus number 2
Jan 1 10:00:04 kernel: usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
Jan 1 10:00:05 kernel: PCI: Enabling device 01:02.2 (0000 -> 0002)
Jan 1 10:00:05 kernel: ehci_hcd 01:02.2: PCI device 1106:3104
Jan 1 10:00:05 kernel: ehci_hcd 01:02.2: irq 2, pci mem c00a7000
Jan 1 10:00:05 kernel: usb.c: new USB bus registered, assigned bus number 3
Jan 1 10:00:05 kernel: ECHI PCI device 31041106 found.
Jan 1 10:00:05 kernel: ECHI reg 0x49 = 80010f20
Jan 1 10:00:05 kernel: ECHI reg 0x49 changed to = 80010f00
Jan 1 10:00:05 kernel: ECHI reg 0x4b = 80010f09
Jan 1 10:00:05 kernel: ECHI reg 0x4b changed to = 80010f29
Jan 1 10:00:05 kernel: PCI: 01:02.2 PCI cache line size set incorrectly (0 bytes) by BIOS/FW, correcting to 32
Jan 1 10:00:05 kernel: ehci_hcd 01:02.2: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4
Jan 1 10:00:05 kernel: hub.c: USB hub found
Jan 1 10:00:05 kernel: hub.c: 4 ports detected
Jan 1 10:00:05 kernel: usb.c: registered new driver usblp
Jan 1 10:00:05 kernel: printer.c: v0.13: USB Printer Device Class driver
Jan 1 10:00:05 kernel: hub.c: connect-debounce failed, port 1 disabled
Jan 1 10:00:06 kernel: hub.c: new USB device 01:02.2-1, assigned address 2
Jan 1 10:00:06 kernel: printer.c: usblp0: USB Bidirectional printer dev 2 if 1 alt 0 proto 2 vid 0x04A9 pid 0x1707
Jan 1 10:00:06 kernel: printer.c: usblp0 Device ID string [107]='MFG:Canon;CMD:BJL,BJRaster3,BSCCe;SOJ:TXT01;MDL: MP780;CLS:PRINTER;DES:Canon MP780;VER:1.10;STA:10;FSI:03;'
Jan 1 10:00:06 kernel: printer.c: usblp1: USB Bidirectional printer dev 2 if 2 alt 0 proto 2 vid 0x04A9 pid 0x1707
Jan 1 10:00:06 kernel: printer.c: usblp1 Device ID string [76]='MFG:Canon;CMD:MultiPASS 2.1;MDL:MP780 FAX;CLS:PRINTER;DES:Canon MP780 FAX;'
Jan 1 10:00:06 kernel: usb.c: registered new driver audio
Jan 1 10:00:06 kernel: audio.c: v1.0.0:USB Audio Class driver
Jan 1 10:00:06 kernel: Linux video capture interface: v1.00
Jan 1 10:00:07 kernel: SCSI subsystem driver Revision: 1.00
Jan 1 10:00:07 kernel: Initializing USB Mass Storage driver...
Jan 1 10:00:07 kernel: usb.c: registered new driver usb-storage
Jan 1 10:00:07 kernel: USB Mass Storage support registered.
Jan 1 10:00:07 kernel: vlan1: Setting MAC address to 00 13 d4 92 08 33.
Jan 1 10:00:07 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
Jan 1 10:00:07 kernel: vlan1: add 33:33:00:00:00:01 mcast address to master interface
Jan 1 10:00:07 kernel: vlan1: add 33:33:ff:92:08:33 mcast address to master interface
Jan 1 10:00:09 pppd[104]: Plugin rp-pppoe.so loaded.
Jan 1 10:00:09 pppd[104]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2
Jan 1 10:00:09 pppd[105]: pppd 2.4.2 started by admin, uid 0
Jan 1 10:00:11 kernel: printer.c: usblp0 Device ID string [107/max 1552]='MFG:Canon;CMD:BJL,BJRaster3,BSCCe;SOJ:TXT01;MDL: MP780;CLS:PRINTER;DES:Canon MP780;VER:1.10;STA:10;FSI:03;'
Jan 1 10:00:11 kernel: printer.c: Parsing USBLPID...
Jan 1 10:00:44 pppd[105]: Timeout waiting for PADS packets
Jan 1 10:00:44 pppd[105]: Unable to complete PPPoE Discovery
Jan 1 10:01:49 pppd[105]: Timeout waiting for PADS packets
Jan 1 10:01:49 pppd[105]: Unable to complete PPPoE Discovery
Jan 1 10:02:04 kernel: printer.c: usblp0 Device ID string [107/max 1552]='MFG:Canon;CMD:BJL,BJRaster3,BSCCe;SOJ:TXT01;MDL: MP780;CLS:PRINTER;DES:Canon MP780;VER:1.10;STA:10;FSI:03;'
Jan 1 10:02:04 kernel: printer.c: Parsing USBLPID...
Jan 1 10:02:07 wan: connected manually
Jan 1 10:02:07 pppd[105]: Terminating on signal 15.
Jan 1 10:02:07 pppd[105]: Exit.
Jan 1 10:02:08 kernel: vlan1: del 33:33:ff:92:08:33 mcast address from master interface
Jan 1 10:02:08 kernel: vlan1: del 33:33:ff:92:08:33 mcast address from vlan interface
Jan 1 10:02:08 kernel: vlan1: del 33:33:00:00:00:01 mcast address from master interface
Jan 1 10:02:08 kernel: vlan1: del 33:33:00:00:00:01 mcast address from vlan interface
Jan 1 10:02:13 kernel: vlan1: Setting MAC address to 00 13 d4 92 08 33.
Jan 1 10:02:13 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
Jan 1 10:02:13 kernel: vlan1: add 33:33:00:00:00:01 mcast address to master interface
Jan 1 10:02:13 kernel: vlan1: add 33:33:ff:92:08:33 mcast address to master interface
Jan 1 10:02:13 pppd[154]: Plugin rp-pppoe.so loaded.
Jan 1 10:02:13 pppd[154]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2
Jan 1 10:02:13 pppd[155]: pppd 2.4.2 started by admin, uid 0
Jan 1 10:02:48 pppd[155]: Timeout waiting for PADS packets
Jan 1 10:02:48 pppd[155]: Unable to complete PPPoE Discovery
