hi guys
I have a wl500gp and I had dd-wrt firmware installed, then I thought in changing it to Oleg's one. Before I had openWRT but someway I seem to have screw it up..
I can install oleg's version on my router but I can't login with the usual admin/admin or root/admin. I tried to install openWRT and the same hapens. In openwrt you first have to enter a password and none works (in open wrt in the fist configuration you have to set a password but I can't do that because it always says that it was unable to change password file)
I tried to install the official version of the firmware but the same problem appears... can't login anyway...
I tried to install again dd-wrt and it seems to work nice.. but when I change to another firmware it login still doesnt work (and the wireless ssid is set as dd-wrt)
my question is:
is there anyway I can solve this? maybe a nvram clear (I don't know what this is but I saw it somewhere)
I really need this asap
PLEASE GUYS I would be very thankful to you guys.
