WARNING:
TRY AT YOUR OWN RISK!
DO NOT UPGRADE UNLESS YOU KNOW WHAT YOU ARE DOING
DOWNGRADE IS NOT EASILY POSSIBLE!!
Changelog:
important!!1. Fixed: Remote Port Pringting
2. Fixed: Port Range Issue
3. Fixed: Web Camera May Sleep When There is no motion.
Find file for download here: http://files.wl500g.info/asus/wl500g..._WL500g_CN.zipWhen upgrading from 1.7.x.x based firmware: Reset your WL500g to defaults via the restore button at the back after upgrading to this firmware!
you do not have to do this when you upgrade from 1.8.x.x based firmware!
