I've attached my config I'm using.
# Configuration
# NOTE: no spaces around the = sign
# the config will be sourced (eg. . transmission.conf)
SOURCE=/opt/torrents/source
WORK=/opt/torrents/work
TARGET=/opt/torrents/target
#MAILTO=torrent@somedomain.com
#MAILFROM=torrent@somedomain.com
MAILOPT="-smail.somedomain.com -f"
USER=admin
GROUP=root
DATE_FORMAT="%d %h %H:%M"
# Transmission daemon variables
PIDFILE=/opt/var/run/transmission.pid
ACTIVE=/opt/torrents/active-torrents.txt
HOME=/opt/torrents
WATCHDOG=300
LISTENING_PORT=65534
# set SPEED in kB/s or -1 for unlimited
UPLOAD_SPEED=-1
DOWNLOAD_SPEED=-1
#UPLOAD_SPEED=41
#DOWNLOAD_SPEED=180
# change SYSLOG from /tmp/syslog.log to
SYSLOG=/opt/var/log/messages
#Uncomment the following for UPNP NAT traversal
#NAT_TRAVERSAL=--nat-traversal
# Seed torrent after completition (YES or NO)
AUTOSEED="YES"
# Creating graphical log of transfer with gnuplot
# can be very site specific issue. See transmission.cgi
# how this variables are used.
GNUPLOT=/opt/bin/gnuplot
GNUPLOT_COMMAND=${WORK}/transfer.gnuplot
GNUPLOT_DATA=${WORK}/transfer.data
GNUPLOT_OUTPUT=/opt/share/www/transfer.png
HTTP_IMG_LOCATION=../transfer.png
#TZ offset in seconds. Use +- sign. DST manually
TIMEZONE_OFFSET=+3600
#Colors for command line. # comment out if not needed
GREEN="\033[32;1m"
#NC="\033[0m"
#BACK_UP="\033[1K\033[0G"
NORMAL="\033[0m"
WARN="\033[33;1m"
BAD="\033[31;1m"
BOLD="\033[1m"
GOOD="\033[32;1m"
I'm using a new install of the 1.9.2.7-7f firmware. I have a usb flash drive setup and mapped to /opt and also used for swap that I'm testing this with before I get an enclosure.
I'm using the default unslung ipkg feed from: http://ipkg.nslu2-linux.org/feeds/unslung/wl500g
I also have the following packages installed.
expat - 2.0.0-6 - XML Parser library
fontconfig - 2.3.2-4 - Font configuration library
freetype - 2.1.10-4 - Free truetype library
gconv-modules - 2.2.5-6 - Provides gconv modules missing from the firmware. These are used by glibc's iconv() implementation.
gnuplot - 4.2.rc2-5 - Command-line driven interactive data and function plotting utility
ipkg - 0.99.149-2 - lightweight package management system
libgd - 2.0.33-3 - An ANSI C library for the dynamic creation of images
libjpeg - 6b-2 - collection of jpeg tools
libpng - 1.2.15-2 - Portable Network Graphics Libraries
libstdc++ - 0.2.0-6 - =Standard C++ library, wrapped for uClibc++
libuclibc++ - 0.1.12-4 - C++ standard library designed for use in embedded systems
nano - 2.0.2-1 - A pico like editor
ncurses - 5.6-1 - NCurses libraries
openssl - 0.9.7l-3 - Openssl provides the ssl implementation in libraries libcrypto and libssl, and is needed by many other applications and librari
readline - 5.2-2 - The GNU Readline library provides a set of functions for use by applications that allow users to edit command lines as they are
transmission - 0.6+r1378-4 - lightweight BitTorrent client and daemon with WWW interface
zlib - 1.2.3-2 - zlib is a library implementing the 'deflate' compression system.
Any idea on what the problem could be?
drwxr-xr-x 5 admin root 4096 Jan 18 19:30 torrents
drwxr-xr-x 2 admin root 4096 Jan 18 19:30 source
drwxr-xr-x 2 admin root 4096 Jan 18 19:30 target
drwxr-xr-x 2 admin root 4096 Jan 18 19:30 work
