Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
Thread: Twonky
    Jan 2007
    The Netherlands
    Quote Originally Posted by Michele Spinolo View Post
    ciao Marc,
    I have KFurge FW, and in rc.local I have exactly the same parameters you have (or at least posted) in yours.
    Yes, I thought so. But especially because you get errors with these, I would suggest that you revert to the way K.C.Furge has handled this:
    hdparm -B 164 ${internal_hdd}
    hdparm -B 114 ${internal_hdd}
    Is it maybe something due with PS3 then: what are you using as client with twonky?[/QUOTE]
    Ziova Clearstream CS510
    Pinnacle Soundbridge M1000 (not in use anymore)
    Noxon Audio
    I have nothing against playstations or Xboxes or WII's personally. But any apparatus entering our home should at least know about OGG, preferably about FLAC, and most urgently not having anything to do with MS (Windows).
    Regards,
    Marc
    Arrow
    Help pls to solve a problem.
    I start (wl-700g) ./twonkymedia
    In the answer I receive such message with an error
    /opt/lib/libpthread.so.0: no version information available (required by./twonkymedia)
    As it is possible to solve the given problem?
    Jan 2007
    The Netherlands
    Twonky needs the original library
    Quote Originally Posted by FastCat View Post
    Twonky does not like the versions of the library that it finds in /opt. So, you should start Twonky before the new library is activated.
    You can do that in rc.local (/opt/etc/rc.local) just before the new libpath is defined. See the bold section in this part of rc.local:
    # These items only run once at power up
    if [ ! -f /tmp/rc.local.done ]; then
     #Start Twonkymedia, werkt met originele library_path
     /opt/share/TwonkyMedia/twonkymedia &
     export PATH=/opt/bin:/opt/sbin:/bin:/sbin:/usr/bin:/usr/sbin
     export LD_LIBRARY_PATH=/opt/lib:/apps/lib:/apps/usr/gift-nasoc/lib
    Marc
    Arrow
    Many thanks. Your council has helped
  1. Twonky locks up my Asus WL500gx?
    By sebw in forum WL-500g Q&A
    Last Post: 04-03-2007, 13:05
  2. Oleg + twonky + VPN
    By bakman in forum WL-HDD Q&A
    Last Post: 15-12-2006, 09:48
  3. Twonky Vision
    By Skymannn in forum German Discussion - Deutsch (DE)
    Last Post: 27-09-2006, 13:56
  4. Internet toegang op WL-HDD via router
    By Jeroen van Omme in forum Dutch Discussion - Nederlands
    Last Post: 06-07-2006, 22:36
  5. twonky media server, network drive with oleg firmware
    Last Post: 22-03-2006, 07:15
