Results 31 to 45 of 83
Thread: Firmware to spin-down HDD?
    Feb 2005
    Germany - Frankfurt a.M.
    Quote Originally Posted by jolcese View Post
    Guys,
    After issuing the scsi-stop, I see that the HDD stops spinning but it starts again inmediately.
    Does it means it's not working?
    Where is your Swap located? on the HDD?
    The system often reads swap data.
    For me the best solution was to read all program data and swap from an usb-stick and all the other data from the hdd.
    Feb 2005
    Germany - Frankfurt
    @britnet:
    swap and opt on an usb stick? How long is this active until now? Any problems with the flash memory producing errors? Is it USB v1 or v2? What about performance?
    background: This were my first thoughts for the WL-HDD. But i didnt do it because of USB 1.1 and the limited rw cycles of flash chips.
    wengi
    Thumbs up Toshiba Gigastore 250 GB
    Working
    Host scsi0: usb-storage
    Vendor: Toshiba
    Product: GigaStore
    Serial Number: 00063A0550013BFA0
    Protocol: Transparent SCSI
    Transport: Bulk
    GUID: 09300b020063a0550013bfa0
    Attached: Yes
    Quote Originally Posted by Xander View Post
    Tutorial.
    3. If you were successful you maybe would want to use my script for automatic spindown:
    PERIOD=30
    BOUNDARY=1200
    SCSISTOP=/usr/local/sbin/scsi-stop
    LOGFILE=/tmp/scsi-stop.log
    Do:
    cd /usr/local/sbin
    cat > scsi-stop.sh
    <copy and paste the script>
    <press Ctrl-C>
    chmod a+x scsi-stop.sh
    To run script in background do, for example:
    ./scsi-stop.sh /dev/scsi/host0/bus0/target0/lun0/disc &
    I'm a little confused. I created the scsi-stop.sh script and executed the command.
    Now, how do I ensure this works properly after rebooting? Should I place this line:
    into my post-boot file?
    And how do I spin the drive up again? Or does a user just have to try accessing a directory via SAMBA?
    Thanks.
    when SAMBA is running, the box can not spin down.
    Doesnt work
    Vendor=1652 ProdID=6600 Rev= 2.01
    Vendor: Super Top
    Product: USB 2.0  IDE DEVICE
    Serial Number: ST  KILLER
    Transport: Bulk
    GUID: 16526600fffffffffffffff9
    Attached: Yes
    scsi-stop into post-boot
    I have tried to put it into post-boot, but nasty things happened when i tried to do it, my router couldn't get an IP at all after i've inserted this line into post-boot.
    My router was working perfectly before with samba and print sharing going on.
    At the end, i had to use the recovery mode of the router to flash the firmware again. For I had completely lost the router, it's not getting an IP (I had IP reserved for it), not replying to ping, completely blocked out from me.
    Now I had everything running again, but I am afraid to put that line into post-boot again. I fear I might brick the router if i do.
    Would the router support usb hubs? I want to have a usb memory stick to act as a swap memory for the router so that the HDD can stay quiet at night time.
    Right now I have a printer plugged in and a HDD, it would be nice if i can put a hub in and attach the USB memory stick as well.
    Edit: I have put that line of code into post-boot after the first attempt (disaster), it didn't crash this time. So I must have done something really wrong back then.
    This is what I put in that works
    /usr/local/sbin/scsi-stop.sh /dev/scsi/host0/bus0/target0/lun0/disc &
    To view how you can see if the process is running in the background, type
    ps | grep scsi
    Working
    HDD: Seagate 80Gb IDE
    Box: Welland ME-740 USB & Firewire
    cat /proc/scsi/usb-storage-0/0
           Vendor: Prolific Technology Inc.
          Product: ATAPI-6 Bridge Controller
    Serial Number: 8F7
        Transport: Bulk
             GUID: 067b350700000000000008f7
         Attached: Yes
    From cat /proc/bus/usb/devices : Vendor=067b ProdID=3507 Rev= 0.01
    Sarotech HardBox + Seagate Barracuda 7200.10
    Working
    Transport: Bulk
    Attached: Yes
    Oct 2007
    Not working
           Vendor: ASSMANN Electronic GmbH
          Product: Unknown
    Serial Number: 20040523AA603
        Transport: Bulk
             GUID: 067b350700020040523aa603
         Attached: Yes
    Nov 2006
    Quote Originally Posted by tj_spark View Post
    Not working
          Product: Unknown
        Transport: Bulk
         Attached: Yes
    This is strange, could you please post the VendorID and ProductID of your device. (lsusb or cat /proc/bus/usb/devices)
    According to this table your device should work if the GUID corresponds to the VID and PID.
    Okay, I just bought a 3,5''-Case which is not working (.. it was even already posted here: GUID: 05e307020000000000000000)
    But unfortunately in the list here, there a no prices or type names. I would like a cheap one - so can one recommend sth?
    this one would be really cheap - but which chipset in it?
    NOT WORKING !
    scsi-stop does not work for my usb to ide adapter !
    Vendor: Unknown
    roduct: USB TO IDE
    Serial Number: None
    Transport: Bulk
    Attached: Yes
    Nov 2007
    EU's border...
    Working:
          Product: Mass Storage Device
    Serial Number: 0
        Transport: Bulk
             GUID: 067b25060000000000000000
         Attached: Yes
    It's a cheap box (~15 Eur), Spire GigaPod VIII - SP105SL,
    http://www.spirecoolers.com/main/pro...sp?ProdID=601#
    Quote Originally Posted by QMax View Post
    It works !
    Vendor=0d49 ProdID=3210 Rev=77.f8
    Manufacturer=Maxtor Corporation
    Product=Maxtor 3200
    Host scsi1: usb-storage
    Vendor: Maxtor Corporation
    Product: Maxtor 3200
    Serial Number: 604010147425
    Transport: Bulk
    GUID: 0d4932100000604010147425
    Attached: Yes
    Max
    Hello,
    the Maxtor Personal Storage 3200 has an build in feature:
    after 1 hour the disk is spinning down, with out any scripts!
    Even when the drive isn't connected to the router or any other host system!
    Ciao
  1. Use copy-button to spin down hdd?
    By dome in forum WL-700g Q&A
    Last Post: 17-10-2007, 03:55
  2. WL 500Gp Keine HDD mehr nach Oleq Firmware Update
    By Greenhorn04 in forum German Discussion - Deutsch (DE)
    Last Post: 08-01-2007, 23:15
  3. twonky media server, network drive with oleg firmware
    Last Post: 22-03-2006, 08:15
  4. HDD spin down with 1.2.3.4 firmware - how to edit?
    By jpritzkat in forum WL-HDD Q&A
    Last Post: 01-05-2005, 23:08
    Last Post: 21-10-2004, 15:55
