Results 1 to 3 of 3
Thread: /etc/passwd problem!!!
    I almost have everything working without enabling USBA modus.
    I took kfurge advice to make a /opt/home/root. I added a .profile file (trough nano, "ipkg install nano"). This solves the problem below:
    export PATH=/opt/bin:${PATH}
    export LD_LIBRARY_PATH=/opt/lib:${LD_LIBRARY_PATH}
    I changed /etc/passwd (nano /etc/passwd), now i use:
    root:blabla:0:4200:root:/opt/home/root:/opt/bin/bash
    guest::35000:42000:guest:/:/bin/sh
    MYSHARE1:blabla:35007:42000:MYSHARE1:/dev/null:/bin/false
    This all works perfectly. I can use ctorrent etc.
    Now my last problem, when i reboot the router the new /etc/passwd is gone. i can only find the default one. So i have to edit /etc/passwd again.
    Is there a way to fix this???
    Sollie.
    PS: i love this project, hehe
    perhaps in rc.local you could copy the proper passwd over the original so each time you boot passwd is being overwritten...
    /regards
    Henrik
    http://wl700g.info/showthread.php?t=7778
    Here is the answer.
    Thanks for all.
  1. Problem with Berkeley db utilities at execution
    By Rodion in forum WL-500g Q&A
    Last Post: 22-12-2006, 16:23
  2. WL-500gP and Asus support experience
    Last Post: 03-12-2006, 12:59
  3. Problem with dieing AIR-connection
    By BòóN in forum WL-500g Q&A
    Last Post: 26-10-2004, 12:04
