hello
i've just installed amule on my wl500gp with partial success so i'd like to ask your help to eliminate the remaining errors
i access the server trough remote-gui from my notebook (zenwalk, amulegui hand-compiled)
amule downloads the server list and i can connect to any server (at least all that i've tried) with highid without problem. on the other hand i can only connect to kad in firewalled mode (i saw this is a problem for many of you guys but i couldn't see anyone having a solution) and after a time i get disconnected from kad (the average users number decreases constantly). connecting to kad also takes ages
my second problem is that if i make a local/global search for a keyword that usually produces countless results (like britney spears or so ) i get only a few results - less than a hundred that is definitely a sign of a problem for me
and for the last one: is it normal that amulegui doesn't work the same as it worked when amule was on my local computer? i mean that eg. it doesn't show the amule log and server info in the networks page, in preferences under sharing files i see my local computers hard drive (and not the one attached to the router), the preferences page doesn't seem to be 100% in sync with the config file on the router (in my preferences i see the name i set in the config file but EC is shown as disabled but obviously it is enabled as i use it..) etc. (btw could anyone tell me please how can i share files this way? only by using amulecmd?)
i compiled amulegui on my local computer with these settings:
./configure --enable-amule-gui --disable-monolithic --enable-wxcas --enable-cas --enable-verbose --enable-alc --enable-alcc --enable-ccache
and i have these rules in iptables (all the other chains are left at the default settings)
i inserted the 2 udp rules before the invalid state rule as i've read that some of you had misterious problems with that invalid state rule but this didn't help kad
Chain INPUT (policy DROP)
target prot opt source destination
ACCEPT udp -- anywhere anywhere udp dpt:4665
ACCEPT udp -- anywhere anywhere udp dpt:4672
DROP all -- anywhere anywhere state INVALID
ACCEPT tcp -- anywhere anywhere tcp dpt:666 flags:SYN,RST,ACK/SYN
ACCEPT tcp -- anywhere anywhere tcp dpt:4662 flags:SYN,RST,ACK/SYN
ACCEPT tcp -- anywhere anywhere tcp dpt:65534 flags:SYN,RST,ACK/SYN
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
ACCEPT all -- anywhere anywhere state NEW
ACCEPT udp -- anywhere anywhere udp spt:bootps dpt:bootpc
ACCEPT tcp -- anywhere anywhere tcp dpt:ftp
thanks in advance,
adam
