Read instructions at http://www.nslu2-linux.org/wiki/Optware/Amule
it seams does not start downloading.
After some time of working it fails with error: Bad system call
Any suggestions?
but the key"AcceptExternalConnections" had set to 1 in the amule.conf.Code:All PartFiles Loaded. ListenSocket: Ok. External connections disabled in config file *** Server UDP socket (TCP+3) at 0.0.0.0:4665 *** TCP socket (TCP) listening on 0.0.0.0:4662 *** Client UDP socket (extended eMule) at 0.0.0.0:4672 Empty dir /usr/local/root/.aMule/Incoming/ shared ERROR: aMule daemon cannot be used when external connections are disabled. To enable External Connections, use either a normal aMule or set the key"AcceptExternalConnections" to 1 in the file ~/.aMule/amule.conf Now, exiting main app... aMule OnExit: Terminating core. aMule shutdown completed.
Hi! It seams I found a problem with downloading large files..
Running with strace amule gives next error:
write(8, "\1PW\376\316\337\1\35\4\346\345\252\260u+\320\223 3\36\\"..., 10240) = 10240
_llseek(8, 455772160, [455772160], SEEK_SET) = 0
write(8, "\242\365a%\341/\211]\320}:\352\264\2763mGz\f\265\217\177"..., 10240) = 10240
_llseek(8, 1206272000, [1206272000], SEEK_SET) = 0
write(8, "Sa\307\226\3321\36\306Z\241J\nha\27M\330\3140\213 \374\350"..., 10392) = -1 EFBIG (File too large)
And crashes after this with "Bad system call"
File system is ext3, kernel (Linux my.router 2.4.20 #61 Mon Oct 9 21:51:36 MSD 2006 mips GNU/Linux)
Does this file size limit is a kernel issue or file system issue?
You need to add md5 passwords! Follow http://www.nslu2-linux.org/wiki/Optware/Amule
Take attention and add passwords as needed to EC section.
Both and neither. Your problem seems to be with _llseek. offset_high values are unreasonable high. I suspect amule! Read this excerpt:
int _llseek(unsigned int fd, unsigned long offset_high,
unsigned long offset_low, loff_t *result,
unsigned int whence);
DESCRIPTION
The _llseek() function repositions the offset of the open file associ‐
ated with the file descriptor fd to (offset_high<<32) | offset_low
bytes relative to the beginning of the file, the current position in
the file, or the end of the file, depending on whether whence is
SEEK_SET, SEEK_CUR, or SEEK_END, respectively. It returns the result‐
ing file position in the argument result.
here are mine configs:
amule.conf
remote.confPHP Code:
[eMule]
AppVersion=aMule 2.1.3
Nick=http://www.aMule.org
QueueSizePref=50
MaxUpload=0
MaxDownload=0
SlotAllocation=2
Port=4662
UDPPort=4672
UDPDisable=0
Autoconnect=1
MaxSourcesPerFile=300
MaxConnections=500
MaxConnectionsPerFiveSeconds=20
RemoveDeadServer=1
DeadServerRetry=2
ServerKeepAliveTimeout=0
Reconnect=1
Scoresystem=1
Serverlist=0
AddServersFromServer=1
AddServersFromClient=1
SafeServerConnect=0
AutoConnectStaticOnly=0
SmartIdCheck=1
ConnectToKad=1
ConnectToED2K=1
TempDir=/opt/share/amule/.aMule/Temp
IncomingDir=/opt/share/amule/.aMule/Incoming
ICH=1
AICHTrust=0
CheckDiskspace=1
MinFreeDiskSpace=1
AddNewFilesPaused=0
PreviewPrio=0
ManualHighPrio=0
FullChunkTransfers=1
StartNextFile=0
StartNextFileSameCat=0
FileBufferSizePref=16
DAPPref=1
UAPPref=1
OSDirectory=/opt/share/amule/.aMule/
OnlineSignature=0
OnlineSignatureUpdate=5
EnableTrayIcon=0
MinToTray=0
ConfirmExit=0
StartupMinimized=0
3DDepth=10
ToolTipDelay=1
ShowOverhead=0
ShowInfoOnCatTabs=0
ShowRatesOnTitle=0
VerticalToolbar=0
VideoPlayer=
VideoPreviewBackupped=1
StatGraphsInterval=3
statsInterval=30
DownloadCapacity=3
UploadCapacity=3
StatsAverageMinutes=5
VariousStatisticsMaxValue=100
SeeShare=2
FilterLanIPs=1
IPFilterAutoLoad=0
IPFilterURL=
FilterLevel=127
FilterMessages=0
FilterAllMessages=0
MessagesFromFriendsOnly=0
MessageFromValidSourcesOnly=1
FilterWordMessages=0
MessageFilter=
ShareHiddenFiles=0
AutoSortDownloads=0
NewVersionCheck=0
ExecOnCompletion=0
ExecOnCompletionCommand=sh -c '~/example.sh "%FILE" %HASH'
Language=
SplitterbarPosition=75
YourHostname=
DateTimeFormat=%A, %x, %X
IndicateRatings=1
AllcatType=0
ShowAllNotCats=0
DisableKnownClientList=0
DisableQueueList=0
MaxMessageSessions=50
PermissionsFiles=416
PermissionsDirs=488
Address=
SmartIdState=0
[FakeCheck]
Browser=0
BrowserTab=1
CustomBrowser=
[Proxy]
ProxyEnableProxy=0
ProxyType=0
ProxyName=
ProxyPort=1080
ProxyEnablePassword=0
ProxyUser=
ProxyPassword=
[WebServer]
Enabled=0
Password=oleo
PasswordLow=oleo
Port=4711
UseGzip=1
UseLowRightsUser=1
PageRefreshTime=120
Template=
[ExternalConnect]
AcceptExternalConnections=1
ECAddress=
ECPort=4712
ECPassword=d08c339bce3bea66c69e8735a89600e2
ShowProgressBar=1
ShowPercent=0
UseSrcSeeds=0
UseSecIdent=1
IpFilterOn=1
[Razor_Preferences]
FastED2KLinksHandler=1
FullQueueSources=0
HighQueueRankingSources=0
HighQueueRanking=1200
AutoDropTimer=240
NoNeededSourcesHandling=2
[SkinGUIOptions]
UseSkinFile=0
SkinFile=
[Statistics]
MaxClientVersions=0
TotalDownloadedBytes=121610531
TotalUploadedBytes=1119849112
Iam not using routing caps. But you can try with disabling firewall. Oleg config sometimes is fonfusion for me also on this issue. accept should be before forward, but ...PHP Code:
Locale=
[EC]
Host=localhost
Port=4712
[Webserver]
Port=-1
Template=php-default
UseGzip=0
AllowGuest=0
AdminPassword=d08c339bce3bea66c69e8735a89600e2
GuestPassword=d08c339bce3bea66c69e8735a89600e2
Startup script is a stock except without frolen message which is not critical.
And at last I must confess I do not use Amule
It is very useful to me. thank you very much!
Forward ports means that amule is ready to listen for connections at ports specified in config. Failing to do so will result in LOW ID indication.
If you are using gP as router. Go to NAT config and accept ports then at virtual server forward it to local server.
If you are using another router. Then forward ports to this gP.
If unable to setup as router and want to try just disable firewall.
when i reboot my device the issue come again.
OH, i know why now.
in the file /opt/etc/init.d/S57amuled
/opt/bin/amuled -f --even-if-lfroen-complains-this-will-stayCode:set backup=$HOME echo "Starting amuled..." echo "Configuration's setting are located in /opt/share/amule" export HOME=/opt/share/amule /opt/bin/amuled -f --even-if-lfroen-complains-this-will-stay export HOME=$backup echo "done"
change to
/opt/bin/amuled -f
it work no problem.
can't login via the amuleweb, i creat the remote.conf file, but can't longin.
any detail step for this funtion?
