Results 1 to 4 of 4
Thread: Problem with WL-100g and Asus Notebook
    I installed my WL-100g on my Asus L3500D and it worked fine. But after about 6 hours while transfering data the IP connection suddenly wont work anymore. I've no further software installed meanwhile.
    I figured out that the WL-100g has a link and sees the WLan Router but no IP connection is possible. The Wlan Utility hangs if I call the IP-Config. Neither booting the PC nor deinstalling / installing the driver helps. Also the manually configuration of the IP does not help. I figured out, that when I install the WL-100g on the second PCMCIA the Network works suddenly. It can be repeated: the WLAN card works not in PCMCIA slot 1 but in slot2. So what can I do that the card works again in slot 1?
    Nov 2003
    Eindhoven
    Quote Originally Posted by Maxxx7
    probably you have removed the WL100g card without the windows removal tool (that thing with the arrow in your systray) somehow registry get's fucked up then and deinstalling/reinstalling won't help in that case
    if you're an advanced user you could probably (if this is the problem ofcourse) fix it yourself: remove EVERYTHING that has something to do with the wl100g from your registry (deinstall card first)
    also remove all .INF files at your harddrive that have something to do with the wl100g (cache dirs too etc)
    probably it's the best to do it in safe mode of windows..
    hope this helps you, it helped me once since then i never hot-removed the device anymore and hadn't this problem ever since
    Thanks a lot. I think youre right. I'll try to delete all registry keys regarding to the WL-100g. The strange thing is that the problems occour while transfering data over IP. Yesterday I had the same problem with the PCMCIA slot 2. Suddenly I got no IP response while surfing in the internet. Changing the card back to PCMCIA slot 1 and reinstalling the drivers solved the problem. I hope it's not necessary to change the card after beeing some hours online...
    I solved the problem using the new Broadcom driver 3.70.12.0 and the utility from Belkin (F5D7010-V2.4.5UK.exe). I think the problem was the ASUS utility. I notice also that the card comes up faster from the supend mode.
  1. Asus V6V notebook, Checkmail led
    By Antiloop in forum Notebook A2H, V6V Q&A
    Last Post: 17-05-2006, 09:23
  2. ASUS WL500G and Acer Notebook Mini Pci Card
    By chaosms in forum WL-500g Q&A
    Last Post: 09-02-2005, 20:24
  3. Difference Asus WL-100g and WL-107g
    By erik_bies in forum WL-100g/WL-100gDeluxe/WL-103b/WL-120b/WL-120g [Broadcom Chipset]
    Last Post: 29-08-2004, 11:59
  4. Problem installing WL-100 g on notebook WinMe
    By Willem in forum WL-100g/WL-100gDeluxe/WL-103b/WL-120b/WL-120g [Broadcom Chipset]
    Last Post: 26-08-2004, 18:59
  5. Asus notebook A2500H WLAN no AES encryption ?
    By Antiloop in forum WL-500g Q&A
    Last Post: 27-01-2004, 01:08
