Originally Posted by
Maxxx7
I installed my WL-100g on my Asus L3500D and it worked fine. But after about 6 hours while transfering data the IP connection suddenly wont work anymore. I've no further software installed meanwhile.
I figured out that the WL-100g has a link and sees the WLan Router but no IP connection is possible. The Wlan Utility hangs if I call the IP-Config. Neither booting the PC nor deinstalling / installing the driver helps. Also the manually configuration of the IP does not help. I figured out, that when I install the WL-100g on the second PCMCIA the Network works suddenly. It can be repeated: the WLAN card works not in PCMCIA slot 1 but in slot2. So what can I do that the card works again in slot 1?
