Results 1 to 3 of 3
Thread: automount USB mass storage device
    What have to be done to get the WL-HDD mount an USB stick or USB HDD connected to the ASUS? How to mount it?
    (Oleg FW is on ASUS running)
    And - the 1000$ question: How can this be managed dynamicly? (ASUS is on, than plug USB stick - AUTOmount - unplug USB stick, plug USB-HDD -> AUTOmount it ... )
    1k thanks for any help
    cannot mount external USB HDD either
    Hi, I am also experiencing the same issue. I am using the lastest firmware version from Oleg on my WL-HDD and for some reason cannot see the external HDD.
    I look into the /dev/ directory and sub-directories but cannot see the USD HDD (was looking for a SCSI directory or something like that).
    I checked the syslogs and it doesn't show the external HDD being mounted at anytime.
    Would really appreciate some help on this.
    Cheers
    Aug 2006
    Hangover
    Try to follow this tutorial http://www.sprayfly.com/wiki/Automount to mount the internal hd to /opt, if done, the stick or any other mass storage will be automatically mounted to /tmp/harddisk. To unmount you can use the 'eject usb' on the webinterface.
    Last Post: 14-03-2012, 15:28
  2. Unstable boot from USB
    Last Post: 20-08-2008, 15:19
  3. Problem mit Printer und HD am Usb Hub...
    By Sidd in forum German Discussion - Deutsch (DE)
    Last Post: 29-03-2006, 17:53
  4. WL500g 2 USB Drucker und ein LPT
    By Trebron in forum German Discussion - Deutsch (DE)
    Last Post: 27-01-2006, 23:48
  5. Wl500g > 2 USB and 1 LPT Printer
    By Trebron in forum WL-500g Q&A
    Last Post: 27-01-2006, 22:17
