Page 4 of 6 FirstFirst ... 23456 LastLast
Results 46 to 60 of 76
Thread: Trouble with RRDTool and updated uClibc
  1. #46
    Jun 2005
    The Netherlands, Haarlem
    Quote Originally Posted by maros View Post
    OK, finally (maybe ;-) )
    1) You should don't use the run-parts script before rrdtool.sh command.
    Change the line to:
    */1 * * * * root nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1
    2) The script is still run each 5 minute. You must remove the rrdtool.sh call from the "/opt/etc/cron.5mins" directory.
    is still not working, only the weekly is updated but thats it.
    removed rrdrun.sh now nothing is working anymore.
  2. #47
    Quote Originally Posted by Devil-Strike View Post
    What are the logs say now?
  3. #48
    Hm. I have the same problems with rrdtool that you have. Only blank white graphics and no one point.
  4. #49
    Jun 2005
    This is the rrdlog:
    rddtool.sh started at Thu Jan 25 10:30:01 MET 2007
    LOAD: 0.00
    MEM  -> USED: 10604544, CACHE: 16252928, FREE: 3973120
    SWAP -> USED: 327680, FREE: 345124864
    Updating Network Load Databases...
    WAN -> in: 9566949   out: 1414566
    LAN -> in: 1662314   out: 13726954
    WLAN -> in: 0   out: 0
    Network Daily Graphs creating.....
    647x347
    647x347
    647x347
    rddtool.sh finished at Thu Jan 25 10:31:04 MET 2007
    rddtool.sh started at Thu Jan 25 10:35:01 MET 2007
    LOAD: 0.03
    MEM  -> USED: 10989568, CACHE: 16527360, FREE: 3313664
    SWAP -> USED: 323584, FREE: 345128960
    WAN -> in: 80345046   out: 4113369
    LAN -> in: 3969596   out: 85482804
    rddtool.sh finished at Thu Jan 25 10:35:03 MET 2007
    not updated anymore after i removed rrdrun.sh
    and this is my syslog:
    Jan 25 15:09:57 ntp client: Synchronizing time with time.nist.gov ...
    Jan 25 15:10:03 /opt/sbin/cron[1051]: (root) CMD (run-parts /opt/etc/cron.5mins ^M)
    Jan 25 15:10:03 /opt/sbin/cron[1052]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    Jan 25 15:11:01 /opt/sbin/cron[1059]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    Jan 25 15:12:01 /opt/sbin/cron[1061]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    Jan 25 15:13:01 /opt/sbin/cron[1063]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    Jan 25 15:14:01 /opt/sbin/cron[1065]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    Jan 25 15:15:01 /opt/sbin/cron[1068]: (root) CMD (run-parts /opt/etc/cron.5mins ^M)
    Jan 25 15:15:02 /opt/sbin/cron[1069]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    Jan 25 15:16:01 /opt/sbin/cron[1076]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    Jan 25 15:17:01 /opt/sbin/cron[1078]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    Jan 25 15:18:01 /opt/sbin/cron[1080]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    Jan 25 15:19:01 /opt/sbin/cron[1082]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    Jan 25 15:20:01 /opt/sbin/cron[1085]: (root) CMD (run-parts /opt/etc/cron.5mins ^M)
    Jan 25 15:20:01 /opt/sbin/cron[1086]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    Jan 25 15:21:01 /opt/sbin/cron[1093]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    Jan 25 15:22:01 /opt/sbin/cron[1095]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    Jan 25 15:23:01 /opt/sbin/cron[1097]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    Jan 25 15:24:01 /opt/sbin/cron[1099]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    Jan 25 15:25:01 /opt/sbin/cron[1102]: (root) CMD (run-parts /opt/etc/cron.5mins ^M)
    Jan 25 15:25:01 /opt/sbin/cron[1103]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    Jan 25 15:26:01 /opt/sbin/cron[1110]: (root) CMD (nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1^M)
    its very strange
  5. #50
    This is the rrdlog:
    LOAD: 0.00
    647x347
    647x347
    647x347
    LOAD: 0.03
    its very strange
    Could you post here the content of the rrdrun.sh script? There is probably wrong path to rrdtool.sh in cron.
    To check use:
    [maros@wl-500gp root]$ type rrdtool.sh
    rrdtool.sh is /opt/bin/rrdtool.sh
    The path in crontab must be changed to be the same.
  6. #51
    Jun 2005
    To check use:
    this is my rrdrun.sh
    /opt/usr/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1
    and this is the the outbut of type rrdtool
    [root@Devil-Strike bin]$ type rrdtool
    rrdtool is /opt/bin/rrdtool
  7. #52
    Ok, as you can see, you have the rrdtool.sh script placed in "/opt/usr/bin/", but path in crontab is only "/opt/bin/". Update the crontab to:
    */1 * * * * root nice /opt/usr/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1
    And it should works.
  8. #53
    Jun 2005
    Ok i will try.
  9. #54
    rrdtool 1.0.50 ipk
    Can anyone point me to a rrdtool 1.0.50 ipk file, the one that doesn't freeze when rendering certain graphics? All the repositories I've seen seem to include only recent versions.
  10. #55
    Jun 2005
    Slovenia
    Install http://wl500g.dyndns.org/7g/ and then try again
  11. #56
    Oleg's firmware 1.9.2.7-7g-pre1 seems to make rrdtool work much better. I'm generating 7 different graphics in about 50 seconds, and no more hang up rrdtool's left behind. See this if you're willing to give 7g-pre1 a spin.
  12. #57
  13. #58
    I try understand how rrdcollect works.
    I created a rrd base via rrdtool.
    rrdtool create eth0.rrd \
    	DS:bytes_in:DERIVE:600:0:12500000 \
    	DS:bytes_out:DERIVE:600:0:12500000 \
    	DS:pkts_in:DERIVE:600:0:12500000 \
    	DS:pkts_out:DERIVE:600:0:12500000 \
    	RRA:AVERAGE:0.5:1:576 \
    	RRA:AVERAGE:0.5:6:672 \
    	RRA:AVERAGE:0.5:24:732 \
    	RRA:AVERAGE:0.5:144:1460
    than i run rrdcollect with default config file.
    # Net: statistics
    #file:///proc/net/dev
    " eth0: %d %d %*d %*d %*d %*d %*d %*d %d %d"    eth0.rrd:bytes_in,pkts_in,bytes_out, pkts_out
    So, it`s update rrdbase every minute, but the value is "NAN".
    I use Oleg's firmware 1.9.2.7-7g-pre1 as recommended.
  14. #59
    FWIW, you've set up the database for a step of 5 minutes. You need the -s parameter to rrdtool create, and the default is 300 seconds. Otherwise, the database definition looks good, so you can rule that out.
    Why rrdcollect? I prefer rrdupdate, and collect the numbers myself, this way I can see what's going on. Perhaps you're not getting the numbers you think you are. Or maybe it doesn't run once a minute like you think it is.
    And then there's the graph where you could go wrong. How did you define that?
  15. #60
    Quote Originally Posted by _Denis_ View Post
    # Net: statistics
    Just remove the space after colon (":").
  1. RRDTool Traffic Graph Tutorial - Extremely easy to follow !
    By macsat in forum WL-500gP Tutorials
    Last Post: 09-06-2009, 21:34
