Results 1 to 15 of 76
Thread: Trouble with RRDTool and updated uClibc
    Sep 2005
    Slovakia
    RrdTool - I donīt need graph
    I donīt need graph generated by rrdtool, i need only a simple webpage whit this:
    ................Today.......This week.......This month
    wlan...........64MB...........564MB............2354MB
    pc1............47MB...........345MB............1005MB
    pc2............09MB...........123MB............0547MB
    pc3............08MB...........096MB............0802MB
    Aug 2004
    Modify the package on your own ?
    Seems no one else is interrested in this at the moment.
    For my own, i would like to see something like text stats inbuild to the web interface, but at the moment, no interrest to do it .
    Greets
    Post Trouble with RRDTool and updated uClibc
    I had some problems with rrdtool and updated uClibc. So what i am done.
    1. Prepared my harddrive for extended packages.
    2. Update ipkg as said on http://www.nslu2-linux.org/wiki/FAQ/Optware-uClibcBuild
    3. Using tutorial on http://wl500g.info/showpost.php?p=18494&postcount=1 install rrdtool
    All step done without errors. But when rrtool.sh script try create rrd data file it`s freezed down. I figure out that rrdtool.sh stopped on `rrdtool create "${1}" etc.`.
    Anyone can help me with it or recommend some alternative programms for statistics collection?
    Jun 2005
    Slovenia
    rrdtool is the only one giving me a trouble. I am looking for a ways to resolve this issue, but it looks like that isnan() function is constantly called in a loop.
    I supose there is a bug in rrdtools or some building info or maybe uclibc problem.
    I have native compiled libpng, libart_lgpl, freetype, zlib and rrdtool but produced the same resulting lock up.
    Strangely
    rrdtool create load.rrd DS:sysload:GAUGE:600:U:U RRA:AVERAGE:0.5:1:48
    works, while
    rrdtool create loadavg.rrd --step 60 DS:load1:GAUGE:120:0:U \
    DS:load5:GAUGE:120:0:U DS:load15:GAUGE:120:0:U RRA:AVERAGE:0.5:1:2160
    locks up
    oleo, thanks for reply.
    But when call rrdtool with different params, it create a file.
    For example.
    rrdtool create temperature.rrd --step 300 \
    DS:temp:GAUGE:600:-273:5000 \
    RRA:AVERAGE:0.5:1:1200 \
    RRA:MIN:0.5:12:2400 \
    RRA:MAX:0.5:12:2400 \
    RRA:AVERAGE:0.5:12:2400
    Do you know some similar packages for collect statistic data?
    Jun 2005
    Slovenia
    Could you possibly find isolated example that fails. Currently I am creating debug version of rrdtools natively to be debuged on router. And I need minimal example.
    What do you mean by isolated example?
    Work
    rrdtool create test.rrd \
    DS:inERIVE:600:U:U \
    RRA:AVERAGE:0.5:1:600
    not work
    rrdtool create test1.rrd \
    DS:inERIVE:600:0:125000000 \
    May be some problems in min max value?
    ps
    it doesnt like MIN = 0
    rrdtool 1.0.50 ipk
    Can anyone point me to a rrdtool 1.0.50 ipk file, the one that doesn't freeze when rendering certain graphics? All the repositories I've seen seem to include only recent versions.
    Jun 2005
    Slovenia
    Install http://wl500g.dyndns.org/7g/ and then try again
    Jul 2008
    Sweden
    RRDTool won't run
    Hi!
    My problem is that the log file is empty and the directories "RRD" under: "/opt/share/www" and "/opt/var/lib/" aren't created. I therefore cannot monitor
    I've installed RRDTool via ipkg and that works. I have followed macsats cronguide and tested with the 5 minutes test script in the same guide.
    That test script works as well (i have it placed in /opt/etc/cron.5mins/).
    I was unable to use the default dir "/opt/usr/bin" since it didn't exist. I've tried although by creating that dir and placing the script there but that didn't help.
    I've also tried changing the default dir to "/opt/bin" in the script and also placing the script in there. No luck there I'm afraid.
    I have the "rrdrun.sh" script inside /opt/etc/cron.5mins/ and I it's executable.
    I'm using lighttpd and perhaps that affects everything?
    Since I'm unable to copy text from Putty I have included a printscreen of my currently running processes.
    I hope someone might know what this is. Would love to get this working please!
    Nov 2007
    EU's border...
    Quote Originally Posted by tzd99 View Post
    I can only help you with your putty problem...
    Select what you want to copy and press Ctrl+Insert. And then paste it in putty with "Shift+Insert", or Ctrl+V in Windows.
    Or use, for example:
    ps axf > /opt/ps.txt
    Jul 2008
    Sweden
    I can paste into putty but not the other way around (copy from putty). Tried via ctrl+insert but taht didn't help I'm afraid. Thanks for your reply though
    UPDATE: just found out there's some issues with the linux version. Also found out i could use Konsole instead..... now that was a lot easier than puTTY
    Exclamation Wl-700g and RRDTOOL
    Has installed on wl-700 rrdtool.
    The Server lighttpd and php and cron are installed and work.
    I try to start this script
    # macsat RRDTool script for ASUS WL-500g (Deluxe) v1.1 (18-07-2005)
    # (c) 2005 by macsat@macsat.com
    # Feel free to distribute and improve :-)
    # Configuration Start
    # Directory for storing RRD Databases
    RRDDATA=/opt/var/lib/rrd/
    # Directory for storing webpages / images
    RRDIMG=/opt/share/www/rrd/
    # Configuration End
    #Output date for log...
    date
    if [ ! -d "${RRDDATA}" ]
    	then
    		echo "RRD Database dir: $RRDDATA does not exist...Creating Now...."
    		mkdir -p "${RRDDATA}"
    if [ ! -d "${RRDIMG}" ]
    	then
    		echo "RRD Image / web dir: $RRDIMG does not exist....Creating Now...."
    		mkdir -p "${RRDIMG}"
    # $1 = html file $2 = Period
    CreateHTML ()
    echo "<HTML><HEAD><TITLE>macsat.com demo RRDTool Traffic Graph Page </TITLE></HEAD><BODY> <h3>Traffic Graphs - ${2} </h3>" > "${1}"
    echo "<center><a href='index.html'>Daily Graphs</a> | <a href='week.html'> Weekly Graphs </a> | <a href='month.html'> Monthly Graphs </a> | <a href='year.html'> Yearly Graph </a>" >> "${1}"
    echo "<br><br><img src='wan${2}.png'><br><img src='lan${2}.png'><br><img src='wlan${2}.png'><br></CENTER></BODY></HTML>" >> "${1}"
    echo "Create started..."
    if [ ! -f "${RRDIMG}/index.html" ]
            then
                    echo " index.html does not exist.....Creating Now...."
    		CreateHTML "${RRDIMG}/index.html" day
    if [ ! -f "${RRDIMG}/week.html" ]
            then
                    echo " week.html does not exist.....Creating Now...."
    		CreateHTML "${RRDIMG}/week.html" week
    if [ ! -f "${RRDIMG}/month.html" ]
            then
                    echo " month.html does not exist.....Creating Now...."
    		CreateHTML "${RRDIMG}/month.html" month
    if [ ! -f "${RRDIMG}/year.html" ]
            then
                    echo " year.html does not exist.....Creating Now...."
    		CreateHTML "${RRDIMG}/year.html" year
    WANIF=`nvram get wan_ifname`
    LANIF=`nvram get lan_ifnames | awk '{print $1}'`
    WLANIF=`nvram get wl0_ifname`
    #debug lines
    echo "WAN Interface: ${WANIF}"
    echo "LAN Interface: ${LANIF}"
    echo "WLAN Interface: ${WLANIF}"
    WANRRD="${RRDDATA}/${WANIF}.rrd"
    LANRRD="${RRDDATA}/${LANIF}.rrd"
    WLANRRD="${RRDDATA}/${WLANIF}.rrd"
    CreateRRD ()
    	rrdtool create "${1}" \
    	DS:in:DERIVE:600:0:12500000 \
    	DS:out:DERIVE:600:0:12500000 \
    	RRA:AVERAGE:0.5:1:576 \
    	RRA:AVERAGE:0.5:6:672 \
    	RRA:AVERAGE:0.5:24:732 \
    	RRA:AVERAGE:0.5:144:1460
    if [ ! -f "${WANRRD}" ]
    	then
    		echo "RRD file : ${WANRRD} does not exist...Creating Now..."
    		CreateRRD "${WANRRD}"
    if [ ! -f "${LANRRD}" ]
            then
                    echo "RRD file : ${LANRRD} does not exist...Creating Now..."
    		CreateRRD "${LANRRD}"
    if [ ! -f "${WLANRRD}" ]
            then
                    echo "RRD file : ${WLANRRD} does not exist...Creating Now..."
    		CreateRRD "${WLANRRD}"
    WANIN=`ifconfig "${WANIF}" |grep bytes|awk -F ":" '{print $2}'|awk '{print $1}'`
    WANOUT=`ifconfig "${WANIF}" |grep bytes|awk -F ":" '{print $3}'|awk '{print $1}'`
    LANIN=`ifconfig "${LANIF}" |grep bytes|awk -F ":" '{print $2}'|awk '{print $1}'`
    LANOUT=`ifconfig "${LANIF}" |grep bytes|awk -F ":" '{print $3}'|awk '{print $1}'`
    WLANIN=`ifconfig "${WLANIF}" |grep bytes|awk -F ":" '{print $2}'|awk '{print $1}'`
    WLANOUT=`ifconfig "${WLANIF}" |grep bytes|awk -F ":" '{print $3}'|awk '{print $1}'`
    # Debug
    echo "WAN -> in: ${WANIN}   out: ${WANOUT} "
    echo "LAN -> in: ${LANIN}   out: ${LANOUT}"
    echo "WLAN -> in: ${WLANIN}   out: ${WLANOUT}"
    # Update the Databases
    `rrdupdate "${WANRRD}" -t in:out N:"${WANIN}":"${WANOUT}"`
    `rrdupdate "${LANRRD}" -t in:out N:"${LANIN}":"${LANOUT}"`
    `rrdupdate "${WLANRRD}" -t in:out N:"${WLANIN}":"${WLANOUT}"`
    # $1 = ImageFile , $2 = Time in secs to go back , $3 = RRDfil , $4 = GraphText
    CreateGraph ()
      rrdtool graph "${1}.new" -a PNG -s -"${2}" -w 550 -h 240 -v "bytes/s" \
      'DEF:ds1='${3}':in:AVERAGE' \
      'DEF:ds2='${3}':out:AVERAGE' \
      'LINE1:ds1#00FF00:Incoming Traffic' \
      GPRINT:ds1:MAX:"Max %6.2lf %s" \
      GPRINT:ds1:MIN:"Min %6.2lf %s" \
      GPRINT:ds1:AVERAGE:"Avg %6.2lf %s" \
      GPRINT:ds1:LAST:"Curr %6.2lf %s\n" \
      'LINE1:ds2#0000FF:Outgoing Traffic' \
      GPRINT:ds2:MAX:"Max %6.2lf %s" \
      GPRINT:ds2:MIN:"Min %6.2lf %s" \
      GPRINT:ds2:AVERAGE:"Avg %6.2lf %s" \
      GPRINT:ds2:LAST:"Curr %6.2lf %s" \
      -t "${4}"
      mv -f "${1}.new" "${1}"
    # Set time-variables
    MTIME=`date "+%M"`
    HTIME=`date "+%H"`
    # Update Daily graphs every 10 mins
    if [ "${MTIME}" = 00 ] || [ "${MTIME}" = 10 ] || [ "${MTIME}" = 20 ] || [ "${MTIME}" = 30 ] || [ "${MTIME}" = 40 ] || [ "${MTIME}" = 50 ];
    then
    # 1 Day Graph
    echo "Daily Graphs created....."
    CreateGraph "${RRDIMG}/wanday.png" 86400 "${WANRRD}" WAN
    CreateGraph "${RRDIMG}/landay.png" 86400 "${LANRRD}" LAN
    CreateGraph "${RRDIMG}/wlanday.png" 86400 "${WLANRRD}" WLAN
    # Update Weekly graph once an hour
    if [ "${MTIME}" = 00 ];
    then
    # 1 Week Graph
    echo "Weekly Graphs created....."
    CreateGraph "${RRDIMG}/wanweek.png" 604800 "${WANRRD}" WAN
    CreateGraph "${RRDIMG}/lanweek.png" 604800 "${LANRRD}" LAN
    CreateGraph "${RRDIMG}/wlanweek.png" 604800 "${WLANRRD}" WLAN
    # Update  Monthly and Yearly graphs once a day (maby twice a day on 12h settings)
    if [ "${HTIME}" = 04 ] && [ "${MTIME}" = 15 ];
    then
    # 1 Month Graph
    echo "Monthly Graphs Created...."
    CreateGraph "${RRDIMG}/wanmonth.png" 2678400 "${WANRRD}" WAN
    CreateGraph "${RRDIMG}/lanmonth.png" 2678400 "${LANRRD}" LAN
    CreateGraph "${RRDIMG}/wlanmonth.png" 2678400 "${WLANRRD}" WLAN
    # 1 Year Graph
    echo "Yearly Graphs Created...."
    CreateGraph "${RRDIMG}/wanyear.png" 31536000 "${WANRRD}" WAN
    CreateGraph "${RRDIMG}/lanyear.png" 31536000 "${LANRRD}" LAN
    CreateGraph "${RRDIMG}/wlanyear.png" 31536000 "${WLANRRD}" WLAN
    echo " <------------------------------------------------------------->"
    echo " "
    The Directory for storage pics with schedules and for.rrd files this script has created.
    And all... In a broad gull a file rrdtool only such messages
    Sat Sep 6 10:07:53 UTC 2008
    RRD Database dir:/opt/var/lib/rrd/does not exist... Creating Now....
    RRD Image / web dir:/opt/share/www/rrd/does not exist.... Creating Now....
    syntax error
    Sat Sep 6 10:07:56 UTC 2008
    syntax error
    Sat Sep 6 10:07:58 UTC 2008
    syntax error
    Sat Sep 6 10:10:39 UTC 2008
    syntax error
    That was not pleasant to this script ?
    Help pls...
    Arrow
    The problem has started to dare gradually.
    To begin with, what a script (my first message) though see as that has started to work on wl-700g. Its first line should be changed to the
    #!/opt/bin/sh
    Once again we try to start a script.
    [root@WL700gE bin]$ ./rrdtool.sh
    Sun Sep  7 19:27:01 UTC 2008
    RRD Database dir: /opt/share/www/lighttpd/rrd/ does not exist...Creating Now....
    Create started...
    Create started...
    Create started...
    Create started...
    WAN Interface: eth0
    LAN Interface: vlan0
    WLAN Interface: eth1
    RRD file : /opt/share/www/lighttpd/rrd/eth0.rrd does not exist...Creating Now...
    Directory rrd it has created and.html files too has created. And here.rrd and pictures he does not wish to create files. A script it is necessary to "hang" (while it violently not to interrupt) with the message which "fat" is allocated (in broad gulls rrdtool anything is not present).
    That is interesting. A kind command:
    it is carried out perfectly. rrd the file is created.
    From here it is possible to draw a conclusion that with program adjustment of mine wl-700g all is good. And a problem in the script.
    Help pls to adapt the given script under wl-700g
  1. RRDTool Traffic Graph Tutorial - Extremely easy to follow !
    By macsat in forum WL-500gP Tutorials
    Last Post: 09-06-2009, 21:34
