Xwrt is OpenWRT whiterussian and uses 2.4.30 kernelroot@OpenWrt:/opt/share/torrent/work$ uname -a
Linux OpenWrt 2.4.30 #1 Fri Nov 24 23:16:54 EST 2006 mips unknown
Does xwrt use 2.4.20 kernel?
As said before I've compiled natively rrdtool and 1.0.50 work while 1.2.15 hangs.
Now I've prepared cross-compiled version of the rrdtool 1.0.50 and realised that it does not work either. I've tried several options without a success
I have also compared both configure logs And I cannot find the difference.
See http://pastebin.ca/288738 or attached diff --side-by-side -d
On the left is cross-compiled config.log | right native compile.
Later I've remembered that I was using gcc-4.1.1 native buildroot toolchain on rrdtool-1.0.50 and cross-compiling was gcc-3.4.6 . See line 325 on my prevous post.
So I've tried also with gcc-4.1.1 cross toolchain and got positive result with several rrdtool create ...
rrdtool-1.2.15 does not work native nor cross.
Tried 4.1.1 cross compiling gnuplot-4.2.rc2 which hung on 3.4.6 on some plots. Compiled with 4.1.1 gnuplot works.
It seems that this 4.1.1 is a way to go. I've tried wild compile of the whole Optware repository before and found some old sources fail to build though.
Solved problem with rrdtool 1.2.5 by removing -std=gnu99 compiler option. Users should try to upgrade uclibc-opt package too.
There is also rrdcollect package for collecting system statistics. I need some useful examples.
yesterday I switch to "oleg/cross/stable" feed, I've installed the latest rrdtool and uclibc-opt. I have no problem with database creation nor update, the rrdtools hangs on graph creation. But only when the the rr database contains gaps or zero.
I'm monitoring three interfaces: wan, lan and wlan. I don't use the wlan interface, it is disabled. So the database is filled by zeros and the graph was always "blank". Yesterday, after update to "oleg/cross/stable", the rddtool always hangs on creation of wlan graph. So I disabled wlan graph creation. Other two graphs were created without problems.
But then I went sleep and I switch off my computer. So the lan interface was down and cron started to fill the rr database with zero values. And again, it causes hang of lan graph creation. So today morning was the router overloaded because of many "rrdtool graph" commands was still running
I had to comment to the lan graph creation and I expected that one small gap or zero in wan database will cause hang of the wlan graph creation.
Command for graph creation:
last lines in strace outputCode:rrdtool graph /opt/share/www/rrd//landay.png.new -a PNG -s -86400 -w 550 -h 240 -v bytes/s DEF:ds1=/opt/var/lib/rrd//vlan0.rrd:in:AVERAGE DEF:ds2=/opt/var/lib/rrd//vlan0.rrd:out:AVERAGE LINE1:ds1#00FF00:Incoming Traffic GPRINT:ds1:MAX:Max %6.2lf %s GPRINT:ds1:MIN:Min %6.2lf %s GPRINT:ds1:AVERAGE:Avg %6.2lf %s GPRINT:ds1:LAST:Curr %6.2lf %s\n LINE1:ds2#0000FF:Outgoing Traffic GPRINT:ds2:MAX:Max %6.2lf %s GPRINT:ds2:MIN:Min %6.2lf %s GPRINT:ds2:AVERAGE:Avg %6.2lf %s GPRINT:ds2:LAST:Curr %6.2lf %s -t LAN COMMENT:\n COMMENT: Vytvoreno\: 19.01.2007 07\:20\:18
Code:[maros@wl-500gp tmp]$ tail -n 30 strace.out _llseek(3, 18444, [18444], SEEK_SET) = 0 _llseek(3, 18444, [18444], SEEK_SET) = 0 read(3, "\0\3\0\205\377\343\4L\5\360\0\v\0\27\0#\1\n@\32\3\245\t"..., 92) = 92 _llseek(3, 15212, [15212], SEEK_SET) = 0 _llseek(3, 18926, [18926], SEEK_SET) = 0 _llseek(3, 18926, [18926], SEEK_SET) = 0 read(3, "\0\3\0\205\377\343\4L\5\325\0\6\0005@\31\5%\2\3\2\3%\4"..., 66) = 66 _llseek(3, 15212, [15212], SEEK_SET) = 0 _llseek(3, 17792, [17792], SEEK_SET) = 0 _llseek(3, 17792, [17792], SEEK_SET) = 0 read(3, "\274\210\325*\274\210\325*\273\0\0\0H\4/\2{\1\0\0\300\0"..., 190) = 190 _llseek(3, 15212, [15212], SEEK_SET) = 0 _llseek(3, 18444, [18444], SEEK_SET) = 0 _llseek(3, 18444, [18444], SEEK_SET) = 0 read(3, "\200\1\0\0\0\0\0\0\5\325\0\6\0005@\31\5%\2\3\2\3%\4\0\0"..., 92) = 92 _llseek(3, 15212, [15212], SEEK_SET) = 0 _llseek(3, 18926, [18926], SEEK_SET) = 0 _llseek(3, 18926, [18926], SEEK_SET) = 0 read(3, "\200\1\0\0\0\0\0\0\4\'\0\3\0\7\0\33@\r\2\242\0\254\4\242"..., 66) = 66 _llseek(3, 15212, [15212], SEEK_SET) = 0 _llseek(3, 17530, [17530], SEEK_SET) = 0 _llseek(3, 17530, [17530], SEEK_SET) = 0 read(3, "\0\1\0\366\0\0\4F\5\325\0\n\0&@\24\0\0\0\0\0\0\0\0\0\0"..., 86) = 86 _llseek(3, 15212, [15212], SEEK_SET) = 0 _llseek(3, 17530, [17530], SEEK_SET) = 0 _llseek(3, 17530, [17530], SEEK_SET) = 0 read(3, "\0\1\0\366\0\0\4F\5\325\0\n\0&@\24\3\227\4\2\227\5\210"..., 86) = 86 close(3) = 0 ************HANG HERE********************* --- SIGINT (Interrupt) @ 0 (0) --- +++ killed by SIGINT +++
Bonus
Nice graph shows growing load caused by graph creation process hangs.
There are some kernel fpemu bugs in Oleg's 7f. Try 7g-pre1 available
at http://wl500g.dyndns.org/7g
This should solve your problems.
I would also like to have your scripts to for creating graphs as samples to include with
rrdtool. And rrdcollect scripts also.
Thanks, it works now.
The upgrade was a little bit complicated, first firmware flash failed and I spent two hours to fix it and I also lost my post-firewall script (Don't forget to backup your setting before flashing )
Sure. It is based on macsat rrdtool tutorial
I added cpu load and memory usage graphs and archiving.
Script is run each minute from cron. Graphs are in /opt/share/www/rrd/ directory.
There are some architectural problems with this rrdtool.sh although I must admit it is nice to start with single script.
Could you please restructure this script to use rrdcollect instead of using cron for update.
- Running script every minute is not very wise think to do in when low CPU and mem is available
- rrdcollect overcomes most of collect problems and acts as daemon without stressing the system for spawning and opening files for update.
- creating daily graphs for archiving can be done by cron
- for current graphs rrdcgi should be used on demand.
- crontab file should be configurable so user can comment out unwanted graphs
- system dependent thing could be in separate /opt/etc/stats.conf
- database creation should be done by package postinst/prerm scripts
If you are able to provide this I could include this in default rrdcollect package.
OK,
I can try, rrdcollect looks interesting. It will took some time.
Here are my minor changes to PATH in attached rrdtool.sh It runs from cron
with /opt/etc/cron.d/macsat
But as I said I don't like it. It could serve as example, though.Code:#minute hour mday month wday who command * * * * * admin /opt/bin/rrdtool.sh >>/opt/var/log/macsat.log
Did you put it to crontab?
(Note: "admin" is default user, must be changed if you are using different user)Code:*/1 * * * * admin nice /opt/bin/rrdtool.sh >> /opt/var/log/rrdtool.log 2>&1
Is there something interesting in log? (/opt/var/log/rrdtool.log)
Or you can try to run the script with command:
I'm working now on new, modular version, using rrdcollect program according to oleo comments. Maybe next week I will have first working version. Actually a module_cpuload is almost done and I need to made some nice cgi script and prepare other modules (memory, netload).Code:sh -x /opt/bin/rrdtool.sh
