Page 1 of 6 123 ... LastLast
Results 1 to 15 of 76
Thread: Trouble with RRDTool and updated uClibc
    Sep 2005
    Slovakia
    RrdTool - I donīt need graph
    I donīt need graph generated by rrdtool, i need only a simple webpage whit this:
    ................Today.......This week.......This month
    wlan...........64MB...........564MB............2354MB
    pc1............47MB...........345MB............1005MB
    pc2............09MB...........123MB............0547MB
    pc3............08MB...........096MB............0802MB
    Aug 2004
    Modify the package on your own ?
    Seems no one else is interrested in this at the moment.
    For my own, i would like to see something like text stats inbuild to the web interface, but at the moment, no interrest to do it .
    Greets
    Post Trouble with RRDTool and updated uClibc
    I had some problems with rrdtool and updated uClibc. So what i am done.
    1. Prepared my harddrive for extended packages.
    2. Update ipkg as said on http://www.nslu2-linux.org/wiki/FAQ/Optware-uClibcBuild
    3. Using tutorial on http://wl500g.info/showpost.php?p=18494&postcount=1 install rrdtool
    All step done without errors. But when rrtool.sh script try create rrd data file it`s freezed down. I figure out that rrdtool.sh stopped on `rrdtool create "${1}" etc.`.
    Anyone can help me with it or recommend some alternative programms for statistics collection?
    Jun 2005
    Slovenia
    rrdtool is the only one giving me a trouble. I am looking for a ways to resolve this issue, but it looks like that isnan() function is constantly called in a loop.
    I supose there is a bug in rrdtools or some building info or maybe uclibc problem.
    I have native compiled libpng, libart_lgpl, freetype, zlib and rrdtool but produced the same resulting lock up.
    Strangely
    rrdtool create load.rrd DS:sysload:GAUGE:600:U:U RRA:AVERAGE:0.5:1:48
    works, while
    rrdtool create loadavg.rrd --step 60 DS:load1:GAUGE:120:0:U \
    DS:load5:GAUGE:120:0:U DS:load15:GAUGE:120:0:U RRA:AVERAGE:0.5:1:2160
    locks up
    oleo, thanks for reply.
    But when call rrdtool with different params, it create a file.
    For example.
    rrdtool create temperature.rrd --step 300 \
    DS:temp:GAUGE:600:-273:5000 \
    RRA:AVERAGE:0.5:1:1200 \
    RRA:MIN:0.5:12:2400 \
    RRA:MAX:0.5:12:2400 \
    RRA:AVERAGE:0.5:12:2400
    Do you know some similar packages for collect statistic data?
    Jun 2005
    Slovenia
    Could you possibly find isolated example that fails. Currently I am creating debug version of rrdtools natively to be debuged on router. And I need minimal example.
    What do you mean by isolated example?
    Work
    rrdtool create test.rrd \
    DS:inERIVE:600:U:U \
    RRA:AVERAGE:0.5:1:600
    not work
    rrdtool create test1.rrd \
    DS:inERIVE:600:0:125000000 \
    May be some problems in min max value?
    ps
    it doesnt like MIN = 0
    Apr 2005
    Vienna, Austria
    Both commands work for me (WL-500gx, OpenWrt Kamikaze, rrdtool 1.0.50-1).
    If prefer rrdtool 1.0 over 1.2 because it's a lot faster generating graphs (2-3secs vs. 30secs) with cgi. I can do without the antialiasing features of rrdtool 1.2.
    Is it possible that OpenWrt binaries do work on Olegs firmware?
    It will depend on the runtime libaries used, I think...
    Oleo:
    ...does work too.
    Apr 2005
    Vienna, Austria
    my /usr/bin/rrdtool binary links with /lib/ld-uClibc.so.0 which is a symlink to /lib/ld-uClibc-0.9.28.so
    Jun 2005
    Slovenia
    It looks like this is not uClibc problem.
    I've compiled 1.0.50 and it works while 1.2.15 does not.
    Shall we downgrade (easy) or find a bug in 1.2.15 (hard)?
    Everything in the nature takes easy way.
    And as said MMCM rrdtool 1.0.50 is much faster in use.
    Yes, downgrade to stable version. Newer does not always means better...
    Jun 2005
    Slovenia
    I like doing things hard way and started more research on the hang issue of the following one liner with rrdtool-1.2.5:
    rrdtool create test1.rrd DS:in:DERIVE:600:0:125000000 RRA:AVERAGE:0.5:1:600
    Here are results:
    1. nslu2 feed/nslu2 firmware - works
    2. oleg feed/oleg firmware - fail
    3. ddwrt feed/oleg firmware - fail
    4. ddwrt feed/Xwrt firmware - works
    5. oleg feed/Xwrt firmware - works
    I was doing more research as I've hit to similar problem when upgraded gnuplot from 4.0.0 to 4.2rc2. On oleg firmware gnuplot hang on some plots,
    while exactly the same gnuplot worked on OpenWRT (Xwrt).
    ipkg-0.99.163 is more restrictive on packages that came from different package feeds! Removing gnuplot record from /opt/lib/ipkg/lists/optware is necessary!
    root@OpenWrt:/opt/tmp$ wget http://ipkg.nslu2-linux.org/feeds/optware/oleg/cross/stable/gnuplot_4.2.rc2-1_mipsel.ipk
    Connecting to ipkg.nslu2-linux.org[140.211.166.82]:80
    gnuplot_4.2.rc2-1_mi 100% |*****************************|   890 KB 00:00:00 ETA
    root@OpenWrt:/opt/tmp$ /opt/bin/ipkg install gnuplot_4.2.rc2-1_mipsel.ipk
    Installing gnuplot (4.2.rc2-1) to opt...
    Nothing to be done
    Successfully terminated.
    Collected errors:
    Package gnuplot md5sum mismatch. Either the ipkg or the package index are corrupt. Try 'ipkg update'.
    root@OpenWrt:/opt/tmp$ vi /opt/lib/ipkg/lists/optware
    Configuring gnuplot
    Same results were obtained also for gnuplot 4.2rc2 hang problem. Downgrading to 4.0.0 on oleg firmware with
    wget http://ipkg.nslu2-linux.org/feeds/op...0-1_mipsel.ipk
    ipkg install -force-downgrade gnuplot_4.0.0-1_mipsel.ipk
    restored normal gnuplot bahaviour.
    The difference between oleg and ddwrt is just in kernel headers. All packages are built upon exactly the same toolchain and config.
    My conclusion is, that the problem is within Oleg firmware and not the packages itself. More precisely; I do not blame linux 2.4.20 kernel sources for this. I thing that the problem is that oleg firmware is built with old 0.9.19 uClibc built with old 3.2.3 toolchain.
    Having all this in mind I must repeat the question:
    Shall we downgrade (easy), or find a bug (hard)?
    That' strange: your apps are linked against your uclibc, so my firmware is not involved at all. Btw, have you tried using linux headers from the broadcom toolchain?
    Jun 2005
    Slovenia
    Headers were extracted from broadcom toolchain when I was creating buildroot toolchain.
    They are located at http://www.wlan-sat.com/boleo/optware/
    See http://trac.nslu2-linux.org/optware/...e/buildroot.mk
    for details.
    On Xwrt you can install either package (oleg|ddwrt) and it works. So the problem must be with firmware itself.
  1. RRDTool Traffic Graph Tutorial - Extremely easy to follow !
    By macsat in forum WL-500gP Tutorials
    Last Post: 09-06-2009, 21:34
