I try to install gallery 2.3.1, but at step 4 (storage creation) the installation is crashing with the server.
I would like to take valuable traces from the web server or php, to know if the problem comes from my server configuration, a missing ipkg that is needed by a basic dev function of the gallery installer, or the gallery installer itself.
After the click, it is like the webserver is freezed (no action: page is loading, no error page) and after 6-10minutes, the page becomes empty/released meanwhile the thttpd process is stopped.
Here is the last line of the only server traces with no relevant information /opt/var/log/thttpd.log in our case:
192.168.3.254 - - [28/Feb/2010:23:28:34 +0100] "GET /gallery2/install/index.php?step=4 HTTP/1.1" 200 8493 "http://xxxxxxxxxx/gallery2/install/index.php?step=3" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; MS-RTC LM 8; .NET CLR 2.0.50727; .NET CLR 3.0.04506.648; .NET CLR 3.5.21022)"
Is there a way to increase level of traces of php-thttpd webserver ?
And/or do you have an idea of a missing ipkg?
ANNEXES
Here are my ipkg
apr - 1.3.12-1
apr-util - 1.3.9-1
autoconf - 2.63-1
automake - 1.10-2
bash - 3.2.49-1
bison - 2.4.1-1
buildroot - 4.1.1-13
bzip2 - 1.0.5-2
coreutils - 8.4-1
cyrus-sasl-libs - 2.1.23-1
diffutils - 2.9-1
e2fslibs - 1.41.9-1
enhanced-ctorrent - dnh3.3.2-11
expat - 2.0.1-1
ffmpeg - 0.svn20080409-2
file - 5.04-1
findutils - 4.2.32-1
flex - 2.5.35-1
freetype - 2.3.6-1
gawk - 3.1.7-1
gdbm - 1.8.3-2
groff - 1.19.2-2
gzip - 1.2.4a-4
imagemagick - 6.5.5.10-1
ipkg-opt - 0.99.163-10
libart - 2.3.17-2
libdb - 4.2.52-3
libidn - 1.16-1
libjpeg - 6b-3
liblcms - 1.15-1
libpng - 1.2.42-1
libtiff - 3.9.2-1
libtool - 1.5.26-1
libuclibc++ - 0.2.2-8
libxml2 - 2.7.6-1
libxslt - 1.1.26-1
m4 - 1.4.13-1
make - 3.81-2
microperl - 5.8.8-11
mysql - 4.1.22-3
nano - 2.2.1-1
ncurses - 5.7-1
ncursesw - 5.7-1
neon - 0.29.3-1
openldap-libs - 2.3.43-1
openssh-sftp-server - 5.3p1-1
openssl - 0.9.7m-5
optware-devel - 6.8-10
patch - 2.6.1-1
pcre - 8.01-1
perl - 5.8.8-23
php - 5.2.12-1
php-mbstring - 5.2.12-1
php-mysql - 5.2.12-1
php-pgsql - 5.2.12-1
php-thttpd - 2.25b-5.2.12-1
pkgconfig - 0.15.0-2
postgresql - 8.2.13-2
python25 - 2.5.5-2
readline - 6.1-1
rrdtool - 1.2.30-1
rsync - 3.0.7-1
screen - 4.0.3-2
sed - 4.2.1-1
sqlite - 3.6.22-1
svn - 1.6.9-1
tar - 1.22-2
tcl - 8.4.19-2
termcap - 1.3.1-2
uclibc-opt - 0.9.28-13
wget-ssl - 1.12-2
zlib - 1.2.3-3
php-curl php-dev php-fcgi php-gd php-imap php-ldap php-mbstring php-pear php-xmlrpc
Gallery suspected function causing thttpd crash:
(otherwise probe html file would have been deleted)
install/steps/StorageSetupStep.class
function _isStoragePathWebAccessible
* Try to protect the given folder with a .htaccess file from direct web-access.
* And then check if the given folder is web-accessible either way.
* Precondition: gallery and g2data folders exist.
* @return array(boolean false if check procedure failed due to platform issues,
* boolean true if the folder is accessible from the web (=insecure))
function _isStoragePathWebAccessible($dir) {
/* Check if we can use fsockopen. Else we can't test it at all. */
if (!function_exists('fsockopen')
|| in_array('fsockopen', preg_split('/,\s*/', ini_get('disable_functions')))) {
return array(false, false);
/* Add a .htaccess file. */
if (!secureStorageFolder($dir)) {
/* Add a probe file. */
$probeFileName = 'probe_' . substr(md5(uniqid(rand())), 0, 10) . '.html';
$probeFilePath = $dir . $probeFileName;
$checkString = md5(rand());
$fh = @fopen($probeFilePath, 'w');
if ($fh) {
$contents = "<html><head><title>Probe</title><body>$checkString</body></html>";
fwrite($fh, $contents);
fclose($fh);
if (!file_exists($probeFilePath)) {
/* Try to guess the URL to the g2data folder. */
$storageUrlCandidates = array();
/* Get the URL of the G2 folder. */
$galleryUrl = getGalleryDirUrl();
/* Get the relative path of the g2data folder to the gallery dir. */
$storagePath = realpath($dir);
$galleryPath = realpath(dirname(dirname(dirname(__FILE__))));
if (strpos($storagePath, $galleryPath) === 0) {
/* The g2data folder is within the gallery folder. */
$relativeStoragePath = substr($storagePath, strlen($galleryPath) + 1);
$relativeStoragePath = str_replace("\\", '/', $relativeStoragePath);
$storageUrlCandidates[] = $galleryUrl . $relativeStoragePath . '/';
} else {
* The g2data folder is in another directory tree.
* Try to remove the common part of the paths and then construct a URL.
$galleryPathElements = explode(DIRECTORY_SEPARATOR, $galleryPath);
$storagePathElements = explode(DIRECTORY_SEPARATOR, $storagePath);
$max = 30;
/* Before: e.g. /foo/bar/gallery2/ and /foo/bar/g2data/. */
while (!empty($galleryPathElements) && !empty($storagePathElements) && $max-- > 0
&& $galleryPathElements[0] == $storagePathElements[0]) {
array_shift($storagePathElements);
array_shift($galleryPathElements);
/* After, e.g. /g2data/ (common part removed). */
$relativeStoragePath = implode('/', $storagePathElements);
$storageUrlCandidates[] = getBaseUrl() . '/' . $relativeStoragePath . '/';
if (preg_match('!^.*?://.*?/[^/]+!', $galleryUrl, $matches)) {
$storageUrlCandidates[] = $matches[0] . '/' . $relativeStoragePath . '/';
/* Also try the default path and other common paths. */
$storageUrlCandidates[] = $galleryUrl . basename($dir) . '/';
$storageUrlCandidates[] = getBaseUrl() . '/' . basename($dir) . '/';
/* Try to fetch the probe file. */
$isAccessible = false;
foreach ($storageUrlCandidates as $storageFolderUrl) {
$url = $storageFolderUrl . $probeFileName;
list ($urlFetched, $isAccessible) = $this->_isUrlAccessible($url, $checkString);
if ($urlFetched && $isAccessible) {
$isAccessible = true;
break;
/* Cleanup: Delete the probe file. */
unlink($probeFilePath);
return array(true, $isAccessible);
