I have
DLink wireless and wired router 604T
Asus 500g premium
512k ADSL connection on AOL
I have tried connecting the 500g to the pc ethernet port, the cable from the dlink to the WAN port on the 500g
Hit the easy setup button, it goes to 100% and doesn't pick it up, the 500g picks up via 192.168.1.1 but again it won't pick the Dlink router.
I have tried removing the connection of the 604T to the 500g premium, and it won't even pick up the wireless, and its not protected in anyway.
I want the 604T to be able to pick up the asus 500g. The 604T was used for connection to the internet normally.
The main feature i want to use is the download manager when your pc is off, and i can download stuff off the net.
What are your setups for wireless routers ?
anyone using an existing wireless adsl router with the 500gp ?
