If you can reach the Router Config Website from wan you can try it, but THIS IS ALL NOT SUPORTED so be warned. Why are you all asking about it ??
And from the wan, upgrade is possible ?
yes it's possible.. but be warned if you have a slow connection (a 10Mbps connection will do the job probably), upgrade WILL fail and your unit will 'die'Originally Posted by chris.delarue
Yes you are right...my ASUS died!! Can anybody help me to get it alive again...
I try the reset button without any result...
PLEASE HELP ME
Hooooray !!!!
What a miracle .
Have you set boot_wait in the nvram before ?
If not, you have to time it very good.
Put an UTP cable into Lan1, set up a tftp client with your firmware, start transfer and imidiatly power on the router. If you are quick, it will Flash. And Flash some older Asus Firmware and Upgrade than, better dont Flash direktly some modified Version because of limitations of the pmon in the router.
Okay..I will try...what about the FTP client? I'm now using restoring utility of ASUS. Do you have another way to do this...
With the restore tool it first give .. not a valid IP adress..after some time the LAN1 led blinks a little, then I press upload again...It gives after 30 seconds..no device in recovery mode..
So if you can give mee some more specifiec details about that TP thing...I would be thankfull...
Originally Posted by WlanMan
uhm.. it's not an WRT54g, afaik wl500g has boot_wait already set to ON standard:
~ # nvram show|grep boot
boot_wait=on
says mine
Any other options left...to get it back to an other version... (reset button pressed while powering on don't gives the blinking powerled (router in restore mode)
out of this post I assume you have flashed the unit wirelessy ?Originally Posted by Pandabeer
No I did it with the cable on LAN1 ..but I've another topic runing in this board.."How to get my WL500B Back to live". Technik thinks I've dammaged the NVRAM
If somebody likes to hobby with electronics and software for me...; somewhere in the Netherlands and the price is not to high...please let me know...I want really this unit back to live again...I bought a linksys WRT54G now, I like this unit...but I can't use this unit for a printerserver and USB Storrage
See my topic running in Questions & Answers:
http://wl500g.info/showthread.php?t=768
See post from Technik, how my unit can live again?! (but I'm not so expert in this kind of stuff...):
http://wl500g.info/showthread.php?t=587
i know, but as you posted it here too that it died, I was a bit confused..Originally Posted by Pandabeer
anyway the only advantage of the WRT54g is that the WAN port doesn't die..
Sorry, but at that moment I was very SAD that this happened with my Router..It's a scream for help....SO let the topic run under "Questiosn and Answers" ... "Bring my WL500 B Back to Live"...If somebody wants to help me...Please contact me... P_boermans@hotmail.com
Hi all,
A'm also the owner of a WL-500g and I just flashed (1.8.1.7) it last weekend. It worked fine here at home. At work I had a problem. I was connected to my PC at home by Remote desktop client. It worked fine and I even started a download on usenet
But after 1 or 2 hours I lost connection to my PC at home. First I thought it was the connection but a friend of mine told me that er was no problem at that time.
When I came home the router was stuck. The WAN AIR LAN1 and LAN2 where flashing. But no traffic could come in or go out. I couldn't login anymore. After a soft and then hard reset, the router came back to life again. But the logfile was gone so I can't find out what went wrong.
Anybody any idea what could be wrong here?
Hi, is there anyone who has any experience with client mode settings in newest firmware 1.8.1.7? I would like to connect my Asus to other AP. This AP is able to give IP via DHCP. Then I need to connect my PCs to Asus LAN ports. Is it possible? Is there an updated documentation for this new firmware? I haven't found any description what "Limited client mode" means.
Thank you for replies.
Hy,
whay I cant login in WL-500g via SSH or TELNET in that firmware release 1.8.1.7.
Help me!
