Code:########################################################### # # esniper # ########################################################### # You must replace "esniper" and "ESNIPER" with the lower case name and # upper case name of your new package. Some places below will say # "Do not change this" - that does not include this global change, # which must always be done to ensure we have unique names. # # ESNIPER_VERSION, ESNIPER_SITE and ESNIPER_SOURCE define # the upstream location of the source code for the package. # ESNIPER_DIR is the directory which is created when the source # archive is unpacked. # ESNIPER_UNZIP is the command used to unzip the source. # It is usually "zcat" (for .gz) or "bzcat" (for .bz2) # # You should change all these variables to suit your package. # Please make sure that you add a description, and that you # list all your packages' dependencies, seperated by commas. # # If you list yourself as MAINTAINER, please give a valid email # address, and indicate your irc nick if it cannot be easily deduced # from your name or email address. If you leave MAINTAINER set to # "NSLU2 Linux" other developers will feel free to edit. # ESNIPER_SITE=http://$(SOURCEFORGE_MIRROR)/sourceforge/esniper ESNIPER_VERSION=2-15-0 ESNIPER_SOURCE=esniper-$(ESNIPER_VERSION).tgz ESNIPER_DIR=esniper-$(ESNIPER_VERSION) ESNIPER_UNZIP=zcat ESNIPER_MAINTAINER=NSLU2 Linux <nslu2-linux@yahoogroups.com> ESNIPER_DESCRIPTION=Describe esniper here. ESNIPER_SECTION= ESNIPER_PRIORITY=optional ESNIPER_DEPENDS= ESNIPER_SUGGESTS= ESNIPER_CONFLICTS= # # ESNIPER_IPK_VERSION should be incremented when the ipk changes. # ESNIPER_IPK_VERSION=1 # # ESNIPER_CONFFILES should be a list of user-editable files ###ESNIPER_CONFFILES=/opt/etc/esniper.conf /opt/etc/init.d/SXXesniper # # ESNIPER_PATCHES should list any patches, in the the order in # which they should be applied to the source code. # ### ESNIPER_PATCHES=$(ESNIPER_SOURCE_DIR)/configure.patch # # If the compilation of the package requires additional # compilation or linking flags, then list them here. # ESNIPER_CPPFLAGS= ESNIPER_LDFLAGS= # # ESNIPER_BUILD_DIR is the directory in which the build is done. # ESNIPER_SOURCE_DIR is the directory which holds all the # patches and ipkg control files. # ESNIPER_IPK_DIR is the directory in which the ipk is built. # ESNIPER_IPK is the name of the resulting ipk files. # # You should not change any of these variables. # ESNIPER_BUILD_DIR=$(BUILD_DIR)/esniper ESNIPER_SOURCE_DIR=$(SOURCE_DIR)/esniper ESNIPER_IPK_DIR=$(BUILD_DIR)/esniper-$(ESNIPER_VERSION)-ipk ESNIPER_IPK=$(BUILD_DIR)/esniper_$(ESNIPER_VERSION)-$(ESNIPER_IPK_VERSION)_$(TARGET_ARCH).ipk .PHONY: esniper-source esniper-unpack esniper esniper-stage esniper-ipk esniper-clean esniper-dirclean esniper-check # # This is the dependency on the source code. If the source is missing, # then it will be fetched from the site using wget. # $(DL_DIR)/$(ESNIPER_SOURCE): $(WGET) -P $(DL_DIR) $(ESNIPER_SITE)/$(ESNIPER_SOURCE) # # The source code depends on it existing within the download directory. # This target will be called by the top level Makefile to download the # source code's archive (.tar.gz, .bz2, etc.) # esniper-source: $(DL_DIR)/$(ESNIPER_SOURCE) $(ESNIPER_PATCHES) # # This target unpacks the source code in the build directory. # If the source archive is not .tar.gz or .tar.bz2, then you will need # to change the commands here. Patches to the source code are also # applied in this target as required. # # This target also configures the build within the build directory. # Flags such as LDFLAGS and CPPFLAGS should be passed into configure # and NOT $(MAKE) below. Passing it to configure causes configure to # correctly BUILD the Makefile with the right paths, where passing it # to Make causes it to override the default search paths of the compiler. # # If the compilation of the package requires other packages to be staged # first, then do that first (e.g. "$(MAKE) <bar>-stage <baz>-stage"). # # If the package uses GNU libtool, you should invoke $(PATCH_LIBTOOL) as # shown below to make various patches to it. # $(ESNIPER_BUILD_DIR)/.configured: $(DL_DIR)/$(ESNIPER_SOURCE) $(ESNIPER_PATCHES) make/esniper.mk $(MAKE) openssl-stage libcurl-stage rm -rf $(BUILD_DIR)/$(ESNIPER_DIR) $(ESNIPER_BUILD_DIR) $(ESNIPER_UNZIP) $(DL_DIR)/$(ESNIPER_SOURCE) | tar -C $(BUILD_DIR) -xvf - if test -n "$(ESNIPER_PATCHES)" ; \ then cat $(ESNIPER_PATCHES) | \ patch -d $(BUILD_DIR)/$(ESNIPER_DIR) -p0 ; \ fi if test "$(BUILD_DIR)/$(ESNIPER_DIR)" != "$(ESNIPER_BUILD_DIR)" ; \ then mv $(BUILD_DIR)/$(ESNIPER_DIR) $(ESNIPER_BUILD_DIR) ; \ fi (cd $(ESNIPER_BUILD_DIR); \ $(TARGET_CONFIGURE_OPTS) \ CPPFLAGS="$(STAGING_CPPFLAGS) $(ESNIPER_CPPFLAGS)" \ LDFLAGS="$(STAGING_LDFLAGS) $(ESNIPER_LDFLAGS)" \ ./configure \ --build=$(GNU_HOST_NAME) \ --host=$(GNU_TARGET_NAME) \ --target=$(GNU_TARGET_NAME) \ --prefix=/opt \ --disable-nls \ --disable-static \ ) ###$(PATCH_LIBTOOL) $(ESNIPER_BUILD_DIR)/libtool touch $(ESNIPER_BUILD_DIR)/.configured esniper-unpack: $(ESNIPER_BUILD_DIR)/.configured # # This builds the actual binary. # $(ESNIPER_BUILD_DIR)/.built: $(ESNIPER_BUILD_DIR)/.configured rm -f $(ESNIPER_BUILD_DIR)/.built $(MAKE) -C $(ESNIPER_BUILD_DIR) touch $(ESNIPER_BUILD_DIR)/.built # # This is the build convenience target. # esniper: $(ESNIPER_BUILD_DIR)/.built # # If you are building a library, then you need to stage it too. # ###$(ESNIPER_BUILD_DIR)/.staged: $(ESNIPER_BUILD_DIR)/.built rm -f $(ESNIPER_BUILD_DIR)/.staged $(MAKE) -C $(ESNIPER_BUILD_DIR) DESTDIR=$(STAGING_DIR) install touch $(ESNIPER_BUILD_DIR)/.staged ###esniper-stage: $(ESNIPER_BUILD_DIR)/.staged # # This rule creates a control file for ipkg. It is no longer # necessary to create a seperate control file under sources/esniper # $(ESNIPER_IPK_DIR)/CONTROL/control: @install -d $(@D) @rm -f $@ @echo "Package: esniper" >>$@ @echo "Architecture: $(TARGET_ARCH)" >>$@ @echo "Priority: $(ESNIPER_PRIORITY)" >>$@ @echo "Section: $(ESNIPER_SECTION)" >>$@ @echo "Version: $(ESNIPER_VERSION)-$(ESNIPER_IPK_VERSION)" >>$@ @echo "Maintainer: $(ESNIPER_MAINTAINER)" >>$@ @echo "Source: $(ESNIPER_SITE)/$(ESNIPER_SOURCE)" >>$@ @echo "Description: $(ESNIPER_DESCRIPTION)" >>$@ @echo "Depends: $(ESNIPER_DEPENDS)" >>$@ @echo "Suggests: $(ESNIPER_SUGGESTS)" >>$@ @echo "Conflicts: $(ESNIPER_CONFLICTS)" >>$@ # # This builds the IPK file. # # Binaries should be installed into $(ESNIPER_IPK_DIR)/opt/sbin or $(ESNIPER_IPK_DIR)/opt/bin # (use the location in a well-known Linux distro as a guide for choosing sbin or bin). # Libraries and include files should be installed into $(ESNIPER_IPK_DIR)/opt/{lib,include} # Configuration files should be installed in $(ESNIPER_IPK_DIR)/opt/etc/esniper/... # Documentation files should be installed in $(ESNIPER_IPK_DIR)/opt/doc/esniper/... # Daemon startup scripts should be installed in $(ESNIPER_IPK_DIR)/opt/etc/init.d/S??esniper # # You may need to patch your application to make it use these locations. # $(ESNIPER_IPK): $(ESNIPER_BUILD_DIR)/.built rm -rf $(ESNIPER_IPK_DIR) $(BUILD_DIR)/esniper_*_$(TARGET_ARCH).ipk $(MAKE) -C $(ESNIPER_BUILD_DIR) DESTDIR=$(ESNIPER_IPK_DIR) install-strip install -d $(ESNIPER_IPK_DIR)/opt/etc/ install -m 644 $(ESNIPER_SOURCE_DIR)/esniper.conf $(ESNIPER_IPK_DIR)/opt/etc/esniper.conf install -d $(ESNIPER_IPK_DIR)/opt/etc/init.d install -m 755 $(ESNIPER_SOURCE_DIR)/rc.esniper $(ESNIPER_IPK_DIR)/opt/etc/init.d/SXXesniper sed -i -e '/^#!/aOPTWARE_TARGET=${OPTWARE_TARGET}' $(XINETD_IPK_DIR)/opt/etc/init.d/SXXesniper $(MAKE) $(ESNIPER_IPK_DIR)/CONTROL/control install -m 755 $(ESNIPER_SOURCE_DIR)/postinst $(ESNIPER_IPK_DIR)/CONTROL/postinst sed -i -e '/^#!/aOPTWARE_TARGET=${OPTWARE_TARGET}' $(XINETD_IPK_DIR)/CONTROL/postinst install -m 755 $(ESNIPER_SOURCE_DIR)/prerm $(ESNIPER_IPK_DIR)/CONTROL/prerm sed -i -e '/^#!/aOPTWARE_TARGET=${OPTWARE_TARGET}' $(XINETD_IPK_DIR)/CONTROL/prerm echo $(ESNIPER_CONFFILES) | sed -e 's/ /\n/g' > $(ESNIPER_IPK_DIR)/CONTROL/conffiles cd $(BUILD_DIR); $(IPKG_BUILD) $(ESNIPER_IPK_DIR) # # This is called from the top level makefile to create the IPK file. # esniper-ipk: $(ESNIPER_IPK) # # This is called from the top level makefile to clean all of the built files. # esniper-clean: rm -f $(ESNIPER_BUILD_DIR)/.built -$(MAKE) -C $(ESNIPER_BUILD_DIR) clean # # This is called from the top level makefile to clean all dynamically created # directories. # esniper-dirclean: rm -rf $(BUILD_DIR)/$(ESNIPER_DIR) $(ESNIPER_BUILD_DIR) $(ESNIPER_IPK_DIR) $(ESNIPER_IPK) # # # Some sanity check for the package. # esniper-check: $(ESNIPER_IPK) perl scripts/optware-check-package.pl --target=$(OPTWARE_TARGET) $(ESNIPER_IPK)
